Question about Casio Watches
Replace battery casio watch prt 40
Hi a small spring has come adrift from my casio prt 40 watch could you please advise me to where it goes,the other 2 srings are in place very close to each other,I changed the batteries ect.cheers Steve
SOURCE: Casio spf 40 Module 2273
Your Watch is in Auto or demo mode. Hold down the "Mode" button for 3 - 5 seconds and it will return to time keeping mode.
Cheers,
Murray
Posted on Dec 29, 2007
SOURCE: Battery replacement prg 40 model 2271
The silver spring goes in a very small hole in the plastic casing on the bottom side of the watch located next to the wristband under the sensor. Hope this helps
Posted on Sep 11, 2008
  • 183 Answers
SOURCE: Changing the battery on My Casio watch module 1848. Two
The contact springs most likely have nothing to do with your screen being black.
The watch will have an "AC" or all clear function that needs to be performed. Check the back lid for AC or reset instructions. If there are no instructions there then you will have to visit a watch repairman/technician to have this procedure performed as it involves touching the AC pad on the circuit board to the back of the battery already installed. The circuit board is easily damaged if not performed properly.
Posted on Sep 17, 2009
escapement
  • 2334 Answers
SOURCE: POD watch battery replacement.
Unscrew the screws holding that contact. Memorize where each screw was - they can be different in length. Fit new battery, put contact back in place and screw all screws back exactly where they were. After that you may need to shortcut battery's+ and AC point (marked on movement) for resetting your watch. Use tweezers to do that. Rate me, plz.
Posted on Feb 02, 2010
  • 15 Answers
SOURCE: Casio DBCW150-1 Databank watch (battery change)
DONT THROW IT AWAY THAT IS A COLLECTORS ITEM... You can get it taken care of at www.casiowatchrepair.com or call them toll free 877.659.0761 and have them take care of it, the watch will be as good as new.
Posted on Feb 23, 2010
Casio prt 41
If you have that kind of problem with your Casio Watch, there are 2 possible problems here:
-Battery is leak
-They did not reset the watch properly if the battery was replaced.
Best you can do is take it to an official Casio dealer, they will handle your Casio watch properly.
You can find any spare you need for your Casio in our website. At TicTacArea.com we are official Casio dealers and we will be glad to help you with this and any other problem you may find related to your Casio Watch. Casio Watches Casio Multi Task Gear Watches
Apr 10, 2014 | Casio Watches
When replacing the battery in my Citizen 8946-095604-ta a small spring fell out ,could you please tell me where it goes, thanks
it goes in a small hole in the back of the movement of the watch and connects to the back plate when replaced to operate the alarm.
Nov 28, 2012 | Casio G-Shock GW500A-1V Wrist Watch
Casio PAG 40 I took it apart to replace bateries and a spring came out and I don't know where it goes. The 2 gold ones are in place.
It's probably the small spring which makes electrical contact between the watch aluminum back and the outer housing, presumably to provide an electrical ground connection to the outside triple sensor. I've attached a photo with the location indicated by the yellow circle and arrow. It goes in the little hole and will fall out if you're not careful.11_14_2012_6_41_27_pm.jpg
Nov 06, 2012 | Casio PRG-40T-7 Pathfinder
How di i change the batteries in my Casio Pathfinder 2782
  • Choose a quiet, well-lit room where you can replace the battery in your Casio Pathfinder watch. Prepare a table, desk or other clean, flat surface where you can perform your watch repair. Put down a soft cloth or piece of craft felt to protect the face of your Casio Pathfinder watch from being scratched during the battery installation process.
  • 2
    Set your Casio Pathfinder watch face-down on the soft cloth or craft felt. Use an optical-sized Philips screwdriver to remove the four screws that secure the watch back to the body of the watch. Set the screws aside, but don't lift the watch back.
  • 3
    Slide the watch back off of the body of the watch very slowly. There are three important springs held underneath the watch back; it is essential to remove the watch back slowly to avoid losing them.
  • 4
    Lift the three springs out of your Casio Pathfinder watch using a small pair of metal tweezers. Take note of the length and placement of the springs as you remove them. Set the springs aside with the other disassembled watch components.
  • 5
    Take the black rubber protective disk out of your Casio Pathfinder to reveal an identically-shaped white plastic disk. Remove the white plastic disk and set it and the black rubber disk aside. Use your metal tweezers, if necessary, to lift out the rubber and plastic disks.
  • 6
    Release the battery strap that holds the battery in place in your Casio Pathfinder watch by pushing the battery strap latch to the left. Remove the old battery from your Casio Pathfinder using a pair of small plastic tweezers.
  • 7
    Pick up your replacement watch battery with the small plastic tweezers and insert it into the battery compartment of your Casio Pathfinder watch. Replace the battery strap and push it gently with the tip of your plastic tweezers to snap the latch in place.
  • 8
    Touch the "-" and "AC" terminals on your Casio Pathfinder watch with the tips of your metal tweezers for at least two seconds. This helps ensure that your watch will work properly once reassembled.
  • 9
    Put your Casio Pathfinder back together to complete the new battery installation. Start by replacing the white plastic disk, followed by the protective black rubber disk. Use your small metal tweezers to replace the small watch springs in their correct locations. Replace the back cover of your Casio Pathfinder, insert the four screws and tighten them with your optical-sized Philips screwdriver.
  • Best regards. Jewel
    Sep 20, 2010 | Casio PRG-40T-7 Pathfinder
    How do I replace the batteries on my Casio Pathfinder PAG40B-2V watch?
    Thank you for contacting FixYa.
  • 2
  • 3
  • 4
  • 5
  • 6
  • 7
  • 8
  • 9
    Sep 19, 2010 | Casio Pathfinder PAG40B-2V wristwatch
    How to change the battery in a CASIO CA53W-1 Watch with Calculator
    open up the watch. there is a small spring that could fall out. dont lose it. use a small pin to pull battery clip off. put new battery in, replace strap and pink plastic. short the tiny contact labeled AC with the + on the battery. check that the clock now operates. lastly, reassemble
    there is a spring inside that goes betweeen one of the contact holes. dont know which.
    Jun 03, 2010 | Casio Watches
    Casio prt-10 and i broke the display. where i can buy lcd?
    http://www.casio.com/support/buyparts/
    You're probably going to have to replace the complete guts. Lots of these digital watches have the little buttons on the sides of the case. Those buttons press small springs which makes contact with the button on the "movement". Be careful that the little springs aren't lost when you remove the movement. It's not hard to do, you just need the right parts. A small phillips screwdrive and a sharp probe makes things easier.
    In some cases, you will need to force the stainless steel back past the rubber wrist band. These watches are nearly indestructible, so you can apply some force. Just don't apply it to the guts of the watch.
    Jun 14, 2009 | Casio G3011 Duplex LCD Watch
    Casio SPF 40 beeper not working after battery change
    There is this little spring which fits in one of the small holes in the watch. When I tested my watch without the spring, there was no beep. With the spring in place the sound worked nice again. So (IMO) apparently the little spring is used as contact between the watch en the "speaker" placed at the back of the watch.
    regards,
    Pieter
    Oct 04, 2008 | Casio PRG-40T-7 Pathfinder
    Aug 20, 2008 | Casio PRG-40T-7 Pathfinder
    Watches Logo
    71 people viewed this question
    Top Casio Watches Experts
    Kazim ERGUNEY
    Kazim ERGUNEY
    Ansel Alberto
    Ansel Alberto
    Are you a Casio Watch Expert? Answer questions, earn points and help others
