Question about HP LaserJet 1300 Printer
Cleaning corona How do I clean the corona wire
3 Suggested Answers
  • 217 Answers
SOURCE: I have specks along the left side of the printout
There is no corona wire in this machine. The most common cause is a defective tonercartridge. Did you try an other one??
Posted on Jan 06, 2010
SOURCE: ask to clean corona wire . where the wire?
The corona wire is on the drum unit (photoconductor)
Posted on Feb 17, 2011
How to clean corona wire on brother 7840W
Corona wires are in the drum cartridge, small screen or grid over them. usually there is a colored slide that you can move back and forth to clean coronas.
Jul 23, 2014 | Brother MFC 7840W Printer
Where do you find corona wires on Brother 7840W printer?
The wire is on the drum (where the toner cartridge fits in). The green or blue piece slide cleans the coroner wire.
Describe your how to clean the corona wire on hplaserjet 3050 Problem
Laserjet 3050 does not use corona wires. HP uses a PCR roller which applies the charge to the drum unit. HP stopped using corona wires on most units years ago. What print problem are you having that makes you think that you need to clean the corona wire?
May 01, 2011 | Office Equipment & Supplies
Copies are black and where is this corona wire? I
Your cartridge has two sections, the drum and the toner section. The corona wire is on the drum section. There should be a blue tab on the top left hand side of your drum unit. Slide this tab across the cartridge one or two times, returning the tab to its original position. There should be an arrow on the blue tab that will match up with an arrow on the drum unit when the tab is in its resting position. Performing this action cleans the corona wire inside the cartridge. If this doesn't fix it you may need to purchase a new drum unit.
Dec 22, 2009 | Brother IntelliFAX 2800 Laser Fax
Get a clean the corona wire. Have removed the
Try using canned air to blow out that corona area, and then a Q-tip moist with alcohol to gently wipe the corona wire, if all that fails you will need a new drum.
Also press the go button 3 times so you get a printout and check that you are getting a clean the drum error or something else.
Dec 18, 2009 | Brother HL 2140 Laser Printer
Black lines through printed pages have cleaned unit and replaced black drum unit.....still have black lines
Clean the charge corona wire/charge corona roller and the charge corona wire gride,and the transfer/separation corona wire/roller.After clean the units and clean the optical section perform the auto image adjust mode.
Sep 28, 2009 | Sharp AR-BC260 Color Copier
How to clean MFC 8820 corona wire of drum
simple solution for cleaning any corona wires Use a lead pencil eraser Gently clean the corona wire, with light even strokes, Best solution (recommended to me by my Copier tech teacher)
Jul 09, 2009 | Brother MFC-8220 Fax
Cleaning the drum unit corona
Message is telling me that the drum is dusty. It says to clean the corona with the wire. I don't know what the corona is and I cannot find a wire that might help me know how to clean the corona
Aug 18, 2008 | Brother Office Equipment & Supplies
Corona wire
I was getting the clean the corona wire problem message even after repeated cleanings.  Before this problem occured the toner light was flashing warning of low toner. When I got the clean the wire pop up the toner light was on all the time indicating the toner was depleated.  So, I thought I would try replacing the toner cartridge and see what happened. I opened the new toner box and noticed on the foil packege specific instructions to clean the corona wire when installing the new toner.  I installed the new toner and cleaned the wire one more time. I then reinstalled the drum and toner assembly into the printer and the clean the corona wire message did not come up again.  The printer now works fine.
Aug 08, 2008 | Brother HL 2140 Laser Printer
HP LaserJet 1300 Printer Logo
Seeker5211
Seeker5211
