Question about Whirlpool LTE6234D Top Load Stacked Washer/Dryer
Broken control knob shaft duet washer
I know the control panel has to be removed with a small torques S
2 Suggested Answers
jsrock516
  • 5911 Answers
SOURCE: How to remove the washer cycle selection/start-stop knob on a Whilpool Heavy Duty Thin Twin stacked washer dryer
I believe the selector knob on a Whirpool just has to be turned counter-clockwise with the selector pushed in. It will spin off the shaft and then the outer indicator dial will pull off. The shaft also has a keyed slot that will only allow the dial to be removed and installed one way, so there should be no question as to how it goes back on.
Was there a reason as to why you are removing the washer selector knob? If this is a simple matter of replacing a broken water temperature selector, you shouldn't have to remove any of the control knobs to gain access to the selector. The entire front panel comes off by removing the screws holding it in place. That way you can access the broken selector from behind the front panel much easier. Just remove the panel right above the washer top (under the dryer) and it should expose the front panel mounting screws. Remove these screws and the front panel comes off. Just make sure the unit is unplugged before you begin. I hope this helps you. Let me know if you need further assistance.
Posted on Apr 22, 2008
Trying to remove light and washer wiper knobs from 1001 Ford F150.
Headlight knobs are attached to a long stem into rueastat switch (dash light dimmer ) push the small button spring loaded of headlight switch behind dash panel. Knob with stem will come out. Careful not to turn on headlights & run battery dead.
Wiper knob has a release tang behind knob push up tang with a small screw driver ( pocket type flat ) or look for a small set screw on knob
Speedometer cable may be broken,loose from dashboard connection,loose from transmission or broken cable gear in trans. Not sure when ford swicthed to magnetic sensors. Possible lost pick up sensor on drive shaft
Mar 08, 2012 | 1991 Ford F150
Control Panel Installation
this is force fit knob, just pull that right up and it wil get loosed by itself, or you can use a negative screw driver to help a bit
cheers
Aug 25, 2008 | Bosch Nexxt Premium WFMC6400UC Front Load...
Tip
How to disassemble a washing machine
The washer cabinet usually must be disassembled for repairs and some maintenance. The washer is connected to both the electric power outlet and to the water supply. Make sure the power cord and water hoses are disconnected before you disassemble the cabinet or tip it over for service. To disassemble a washer:
-To remove the control panel, remove retaining screws spaced around the panel. They are usually located under a piece of molding or trim that can be pried off. On some machines, you'll have to remove the back of the control panel, also held by retaining screws, to get at the working parts of the controls. Knobs on the control panel are usually friction-fit and will pull off. Some knobs are held by small setscrews at the base of the knob. Loosen the setscrews with a screwdriver or Allen wrench and pull the knobs straight off the shafts.
- To remove the service panel, remove its retaining screws, then spread an old blanket on the floor to protect the washer's finish. Make sure the machine and hoses are drained of water. Tip the washer over on its front or side to gain access through the bottom of the machine. The bottom of the machine generally doesn't have a service panel because it is usually open.
- To remove the top of the cabinet, insert a stiff-bladed putty knife into the joint between the top and side panels and give the knife a rap with your fist. This should release the spring clips so that the top can be removed.
on Jan 16, 2010 | Washing Machines
The set knob on my kenmore 70 series top load washer is stripped and I can't figure out how to remove it. The knob just spins and will not move inner set arrow to proper load cycle
flip up the controls
The timer has a hollow shaft. The tip of the shaft has
ears on it. To keep the knob on there a small rod is shoved up into the hollow shaft. The rod spreads the tip and retains the knob. To remove the knob pull out the rod a half inch and the knob and skirt is easily removed.
This video shows how to get into the machine:
May 03, 2011 | Washing Machines
How do you access the control panel the knob that sets the wash cycles is broken and needs replaced
The topside control panel has four small torx screws that hold the control panel to the rear. The timer has a small U clip under the knob that needs to be removed with needle nose and then the knob comes off so the timer can be replaced. I have your washer's training manual HERE
Apr 20, 2010 | GE WJSR2070B Top Load Washer
Can't remove control timer knob on kitchenaid washer
The shaft go'es all the way thru the timer on most and you can keep it from spinning there.
Mike
Oct 16, 2017 | KitchenAid Washing Machines
I need to get the drum out of my Hoover washer to replace the bearings.
hi Step 1: To remove the control panel, remove retaining screws spaced around the panel. They are usually located under a piece of molding or trim that can be pried off. On some machines, you'll have to remove the back of the control panel, also held by retaining screws, to get at the working parts of the controls. Knobs on the control panel are usually friction-fit and will pull off. Some knobs are held by small setscrews at the base of the knob. Loosen the setscrews with a screwdriver or Allen wrench and pull the knobs straight off the shafts.
Step 2: To remove the service panel, remove its retaining screws, then spread an old blanket on the floor to protect the washer's finish. Make sure the machine and hoses are drained of water. Tip the washer over on its front or side to gain access through the bottom of the machine. The bottom of the machine generally doesn't have a service panel because it is usually open.
Step 3: To remove the top of the cabinet, insert a stiff-bladed putty knife into the joint between the top and side panels and give the knife a rap with your fist. This should release the spring clips so that the top can be removed.
Sep 13, 2008 | Washing Machines
Take apart washer
just remove back ...don't remember seeing broken belt on duet except the sport version..as far as control panel remove top a couple of screws top front and snaps in at bottom but IF AIN'T BROKE DON'T FIX IT
Aug 20, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Apr 22, 2008 | Whirlpool LTE6234D Top Load Stacked...
Whirlpool LTE6234D Top Load Stacked Washer/Dryer Logo
53 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
