Amana XRBR206BB I have a XRBR 206BB refrigerator. The plastic on the bottom of the door (not the shelf part) is scrapping on the bottom of the fridge on the inside and the door needs an extra push to close properly. Is there a way of adjusting the door to raise it about 2-3 mm so that the door clears the base of the fridge. I have checked the manual and there is nothing related to this. Thank you for your help.
    Top Expert:
  • Heating & Co... Master
  • 34,188 Answers
The bottom hinge may have to be adjusted or shimmed.
Posted on Feb 09, 2014
Fisher & Paykal Refrigerator. E 522 B Plastic piece in door hinge fell out . Door now travels around and has big dent in front panel. I need to replace outer stainless door panel and plastic piece in...
The plastic piece that is moulded to the inner door that holds up the shelf on a fisher & paykel fridge has cracked and no longer holds the shelf. Can I buy a new door liner or does the whole door need to be replaced?
Jan 29, 2011 | Fisher and Paykel E522BRXFD Stainless...
Freezer door opens when fridge door closes
if you are worried that the freezer is empty....fill it with plastic bottles of water...remember tho,don't fill the bottles completely as frozen water expands.
Jul 20, 2010 | Amana ATB1832AR Top Freezer Refrigerator
When you shut the ref. doors the right one stays open. there is nothing in the way. you have to go back and shut it.
First I would look on the inside bottom of the refrigerator, where the door closes into and see if you can see any scrap or drag marks on the plastic. some doors will drop just enough to grab the plastic right befor the door closes.
your hinge could be bent causing this.
take a look at the top of the doors when their closed, and see if the right door is a little lower.
some of the doors can be adjusted at the top hinge moving the door to the right lifting it in the center.
Jan 11, 2010 | Amana AFD2535DES French Door Refrigerator
I need shelves for the fridge and the plastic shelf at the bottom of the door is broken and needs replacing.
hi there......you havent stated the manufacturer of your fridge...however obtaining shelves for your fridge should be no problem..provided you have the model and serial number and if possible the product code.(a) contact your local your local domestic apliance repair/spares shop....(b) go online to the manufacturers web site...(c) go on line to google enter your fridge details this will provide you with information where to obtain your parts...
the door shelf may be a different issue...if the shelf is part of the door lining then you will need a relpacemant door
regards Sir Galahad
Aug 13, 2009 | Kenmore 91493 Stainless Steel Compact...
We have an Amana side by side that is only cold on the bottom in both the freezer and fridge. Also the top shelf of the fridge is hot from the light, which does not seem to go off when the door is shut....
amana runs power to the fan thru the defrost sensor that is mounted on the evaporator coil. these sensors will get moisture inside of them and short out causing intermittent fan operation. replace then sensor and your frig will return to normal. thanks for using FixYa peyton
Feb 17, 2009 | Amana ASD 2624 Side by Side Refrigerator
Amana bottom freezer refrigerator
Make sure that is not hot air getting inside the ref.
close the door and take a look at the gasket
May 08, 2008 | Refrigerators
Bottom hinge on fridge door broken
Yes, there is supposed to be a plastic bushing/washer under there. Usually 1/8 inch thick. If a dealer is not handy you may cut some out of plastic to put there. Then undo the top hinge, and carefully lift the door off (you might want to empty the shelfs). Put your spacer on the hinge pin, and replace the door and the top hinge.
Jan 28, 2008 | Liebherr Premium CTP 3153 Top Freezer...
Heating & Cooling Logo
20 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
