Question about Toshiba 40SL412U LCD TV
My toshiba 40sl412u turns on for a second then off
I have unplugged TV to solve problem but still does the same ill press the power on and green light turns on then a small dim flash and turns off.
    Problem Solver:
  • 16 Answers
You more than likely have faulty capacitors on the power board. the caps won't let the power build up.
the general steps are
  1. unplug your tv.
  2. lay it glass side down on a soft thick blanket to protect the glass.
  3. remove the rear panel.
  4. identify the board with the power connector.
  5. remove it.
  6. find replacements for the electrolytic caps, the cylinders looking ones.
  7. unsoldier, then resoldier the caps.
  8. put the TV back together
This will generally cost $10 for the caps and less than $50 for the soldiering equipment. You tube has a vast number of videos on this.
a tv repair shop locally should cost less than $100. should be even less if you remove the board and bring it to them. there are companies that you can send the board in and they will repair and send it back.
Mind you $100 is cheep VS a new tv. I replaced the caps in mine for 10 bucks and a few hours of time, but I'm a highly qualified electronics repair tech.
Posted on Feb 09, 2014
4 Suggested Answers
  • 4090 Answers
SOURCE: Flashing power button tv won't turn on
yes call the tech and have the power board replaced. In future have the TV plugged into an anti surge board to protect it ( and you from expensive repair.) I suspect you will need a new power supply fitted
Please rate the help to keep us online
Posted on Aug 17, 2009
  • 8457 Answers
SOURCE: 42" Toshiba Plasma TV wonn't turn on
Power board require changing.It dead.
Posted on Jan 08, 2010
welcomejee
  • 10594 Answers
SOURCE: Toshiba Regza 42RV535U 42 in.
TV needs back light inverter board replacement as discussed in chat session, required board is available with shopjimmy.com
Thanks.
Posted on Jan 25, 2011
I lost the base stand screws to my Toshiba 40SL412U TV - what size are they so I can replace them?
Sorry but you must take it to a parts store or hardware store and see what fits.
Nov 08, 2016 | Toshiba 40SL412U LCD TV
Sharp Aquos LC-60E79U has flashing green power light and OPC light but won't turn on
Try to I unpluged the power, push volume and channel down, pluged power again
While it's flashing unplug your TV from the main power source for 15 seconds,Then press Valume Up and Channel Up, while holding it plug the TV back in, you should see the TV Turn on. How to Reset Your Sharp LCD TV TV Repair
Jun 15, 2013 | Televison & Video
Toshiba 50HP95 timer/Rex light blinking green. Tv wont turn back on.
place to begin if you are able is examine the power board for puffed up caps and or voltages coming into the board and out of it.
Aug 27, 2012 | Toshiba 50HP95 50 in. Plasma Television
I have a Mitsubishi WD-62525 HDTV that suddenly wont turn on. Just has a green blinking light when you hit the power button. Any ideas?
I found this on another website, most likely it is your power supply capacitors.
  1. Press the "reset" button and hold for 10 seconds .... Does TV turn on and blinking green light turn to solid green.
  2. Unplug the TV from it's power source for various times, ranging between 5 minutes and 24 hours..... Does blinking green light continue upon plugging in the TV.
  3. Disconnect ALL devices from the TV; DVD, Tuner, Cable Box, unplug the TV for various duration times .... Does blinking green light continues upon plugging in the TV.
  4. Press Power and Menu buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  5. Press Power and Display buttons simultaneously and hold depressed for 20 seconds .... Does blinking green light continue to flash.
  6. Insure that no front panel buttons are inadvertently stuck in an "engaged" position.
Diagnosis: If none of the above test resolve the issue, then the failure lies in one of the following:
  1. DM Module Capacitors have FAILED.
  2. DM Module is defective.
  3. EEPROM Board failure
  4. Power Supply failure.
Feb 28, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Our CAL232 TV will not turn on. When pressing the power button, you can see a red light and a green light, but the screen doesn't start up as normal. The TV then tries again after about 20 seconds, but...
My LOEWE CAL 232 will not power up. When the power button is pressed, the monitor turns on, with the LOEWE on the monitor, then the TV continues with the previous activity (antenna, DVD, VCR etc.). Now all that happens is
1. the red light comes on
2.after about 1 second the green light turns on for about 12 seconds
3. the the green light turns off for about 1 second
4. then the green light turns on again for about 12 seconds
and this continues until the power button is pressed to turn the TV off. During this time, the monitor does not turn on and the only sound I hear seems to eminate from the power button.
Any thoughts?
Oct 19, 2010 | Loewe CAL232 TV
Turn tv off wont turn back on ! Model#32AV502R TOSHIBA
Notes from user manual: http://www.tacp.toshiba.com/tacpassets-images/models/37av502r/docs/37av502r_om_e.pdf
Unplug the TV for about an hour to see if it will reset itself, if not, try:
TV stops responding to controls:
If the TV stops responding to the controls on the remote
control or TV control panel and you cannot turn off the
TV, press and hold the POWER button on the TV control
panel for 5 or more seconds to reset the TV.
Reset Factory Defaults
To reset all settings and channels to their factory
default values:
Press and open the Setup menu.
Highlight Installation and press . A new set of
Installation menu icons will appear.
Open the System Status menu, highlight System
Information
, and press .
Press tu to scroll through the menu bar to select
Factory Defaults.
Enter your PIN code (or 0000 if no PIN code has been set).
Highlight Yes and press . The TV will turn off
automatically after a few seconds. After the TV turns off,
unplug the TV power cord and then plug it in again to
complete the reset process.
To cancel the reset:
Highlight No and press .
Otherwise you may jhave bigger problem inside the TV.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 23, 2010 | Toshiba 32AV502R LCD TV
Toshiba Rear Projection TV Problem
common problems on toshiba are the stk ic and it is not ease to replace them you will need a technician
Sep 15, 2008 | Toshiba TZ50V51 50" Rear Projection...
Won't come on
hy i got a toshiba 42" LCD tv ,when i press the power boton
iget the red light,& it stay that way ontil i pressthe power back off
thanks for any help
Jun 26, 2008 | Toshiba 62HM95 62" HDTV
Toshiba 62HM14
What are the labels on the lights? Timer/Lamp/Service and what color is wich?
Jun 03, 2007 | Toshiba TheaterWide 62HM94 62" Rear...
Toshiba 40SL412U LCD TV Logo
67 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
