Question about Reddy HEATER RLP30 30,000-BTU PORTABLE LP PROPANE FORCED AIR HEATER
Where do I buy hose and regulator for RLP30 reddy heater
It seems to a strange size hose.1/4 female flare and acme for tank
Buffalo12980
  • 625 Answers
SOURCE: forced air propane heater won't stay lit
two items come into play here - 1) the hot surface cutout and 2) the flame detect Cd cell. Check alignment of the Cd cell or just replace it. The hot surface cutout has two terminals that plug into the two tabs on the millivolt generator.
Posted on Aug 22, 2007
Therinnaiguy
  • 1420 Answers
SOURCE: reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Posted on Oct 26, 2007
  • 10865 Answers
SOURCE: I have a Reddy Heater 70,000BTU without a
hello. Your reddy heater is dirty and needs a good cleaning. Also, here are a few other possible reasons why it won't operate properly. Pressure not adjusted to 5.1 psi, dirty outlet filter, clogged inlet filter, bad or dirty photo cell, defective reset switch, pump going bad, dirty injector nozzle, dirty fuel filter, contaminated fuel. Check yours out and do what you can to address each area of concern. Regards, Joe
Posted on Jan 21, 2010
  • 2597 Answers
SOURCE: Need hose and regulator assembly
rona, homehardware , most home DIY shops .
Posted on Dec 10, 2010
  • 185 Answers
SOURCE: I have a 40,000 BTU propane reddy heater. I just
Did they over fill the tank and you are getting pure liquid to the heater..... Sounds like when you use a propane bottle hand torch and tip it up side down the flame turns orange and goes out. Also the regulator vent may have gotten plugged with dirt or ice. May try and bleed some of the propane pressure off of the top of the tank....... But make sure you have it outside and plenty of ventaltion and no open flame any where...... Propane is lighter than air so it settles down on the ground at the lowest point.....hope this helps..... Or you could take it back to your suppler and get a different tank.
Posted on Feb 01, 2011
Have an rlp30 reddy heater, have spark and gas but will not light.
wile red button is pushed no flame or turns off when the button is released the flame dies ? if no flame tank is too small or spark isn't in far enough to catch gas . if flame is present with button down then the over heat switch on the in line thermal coupler could b bad u can check the over heat switch with a jumper between the two wires and if it stays lit you got it if it goes out then its the thermal coupler that's bad
Dec 12, 2013 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Rlp35 reddy heater runs few minutes flames out, fan continues to run?
clean the sensor so that the control can have confirmation of ignition
Nov 11, 2012 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
I have a wall mount vent free heater and a 10 gal propane tank how do hook it up so it will work
First off, Dave, the tank cannot be inside the house, motor home, camper, garage, etc. By the way, I believe your 10 gallon tank, is what's called a 40LB cylinder. Anyway, 10 gallons is not going to last very long, if the heater you plan to install is 20,000 Btu output or higher. If it's going in a bedroom, the maximum Btu output can not exceed 10,000 Btu's.
To install one, you'll need 1/2" flexible copper gas piping. An in-line LP Gas regulator, that has the capacity to carry whatever the maximum Btu output of you heater is. In addition, you will need a 1/2 NPT to 3/8" Flare nipple to go into the back of the heater. Assorted Flare Nuts in assorted sizes for the gas line connections.
Tools needed: Flaring tool, 2 adjustable wrenches, Phillips Head Screw Driver & Leak Detector Solution. To make sure it's done correctly, a Mechanical/Plumbing Permit from you city or county's Building Inspection Department. And last, but not least, a friend that has a lot of knowledge in the installation of Vent-free Supplemental Gas Heating Appliances.
If installed properly, these appliances are very safe. If installed improperly, they can be very dangerous.
Mar 04, 2011 | Heating & Cooling
Lights while holding primer/pilot button then runs out of propane within seconds. If you wait a minute it builds up then does the same thing like the propane tank is empty but it is full.
Turn off the propane tank and disconnect the heater hose from the tank. Wait 5 minutes and reconnect the heater hose/regulator to the propane t. Turn the tank valve on very, very slowly until it's completely open again. Now, try lighting the heater. If you are using a 20lb LP grill type tank, that should solve your problem.
Hope that helped.
Feb 12, 2011 | Reddy Heater-30-55,000 BTU Variable
I have a 40,000 BTU propane reddy heater. I just refilled the tank and attached it to the heater like I normally do but now when I start it it will run fine then it will flare up and shoot out orange flame...
Feb 01, 2011 | Reddy Heater RLP100 Portable Forced Air...
Can i convert my rlp 30 to natural gas
No you can not convert this unit to natural gas. They do not make a conversion kit or give us any sizes to drill out any orifices.
Dec 27, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Forced air propane heater won't stay lit
Feb 06, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Heating & Cooling Logo
63 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
