Question about Tribeca Queen-size Bed
No instruction manual included with the Tribeca Camelia scroll bed
Tribecca full size camelia scroll bed has no instruction manual?
Hi Camelia, you've remembered your phone number. Nothing to do with desktop pc problems though.
Nov 01, 2013 | Acer Computers & Internet
Looking for manual or instructions for legacy child craft crib, can't locate model number
F32701.03 is the model for your crib. Are you trying to convert it into a full size bed? Baby's Own Room sells the full size conversion kits.
Aug 15, 2012 | Child Craft Crib 'n Double Bed
4-1 crib instructions
Email us at parts@productsamerica.com. We can supply you with the instruction manual that shows you how to convert to the full-size bed.
Apr 09, 2012 | Dream On Me 618W Crib
How do you replace the side view mirror on B9 Tribecca
hi you have to pop the surround peice off on the interior on the other side of the mirror there you will find the screws that hold the mirror on, undo them and the electric plug and repeat to reinstall
Apr 06, 2012 | 2008 Subaru B9 Tribeca
We have a Morigeau-Lepine convertable crib-day bed-full size bed, but we are missing the instructions to convert it to the full-size. It's model number is DA722-BC & the model is somewhere between...
I can't offer the exact answer, but hopefully my suggestions will be helpful...
Converting the crib to a full-size bed should actually be a fairly simple process of detaching the 4 sides that make the crib, and replacing the 2 short sides with the full-size bed rails that were sold separately in a conversion kit. The 2 long sides of the crib become the headboard and footboard of the full-size bed.
Unfortunately, it's only a simple process if you already have the full-size conversion kit bed rails. And since Morigeau-Lepine went out of business, they aren't making any more conversion kits. If you don't have the full-size bed rails, then this could be quite difficult.
It's possible that some stores that used to sell Morigeau-Lepine cribs might still have a conversion kit hidden somewhere in the back of their stock room or warehouse. You could try calling around to a few of your local stores to ask if they would check for you. It's a long shot, but it doesn't hurt to ask.
If you have the rails, or are lucky enough to find them, then it should be as simple as locating the screws that hold the crib sides together, removing them (most likely with an appropriatly sized hex-key,) and putting the screws back through the headboard and footboard into the bed rails. (I'm really just assuming that it works the same as the Babi Italia conversion.) If no screws are visible, or if removing them doesn't detach the crib sides, then they are probably also held together with locking bed rail fasteners. To release the fasteners, remove any visible screws, then push upwards on the short side rail while pushing down on the long side rail. You might have to tap the rail up with a rubber mallot to get it moving.
If you don't have the full-size bed rails, and you can't find them anywhere, your only option may be to build them yourself, or find a woodworker to build them for you. Search online for "Bed Rail Fasteners" and you'll see several options for hardware, but they might require modifying the headboard and footboard as well. Full-size matresses are 75 inches long, so you'll want the length of your rails to accomodate (ours are 77 inches long.)
I hope I've been helpful. Good luck!
Jan 19, 2011 | Baby Gear
Delta soho 5 in 1 crib where can I get the conversion kit for the toddler bed and where can I get the rails for the full size bed
You can find Delta soho 5 in 1 crib conversion kit on amazon. Click here Amazon com Delta rails and take a look. I hope this was helpful. cheers
Jun 29, 2010 | Delta Soho Crib
Building the full size bed
http://www.milliondollarbaby.com/instructions
Click on your model and usually on the last page of the manual
Jun 25, 2010 | DaVinci Emily Crib
TRying to change into full size bed with no instructions do i need special rails or standard ones?
The fourth stage is where the bed can be turned into a full size bed. The "front side" and the "back side" are turned into the headboard and footboard. However, at this point a steel full-size bed frame would need to be bought (from any mattress store) to turn it into a full-size bed. You used to be able to get matching wood side rails from Simplicity but since they went out of business you can't. you could have them made if you found matching wood or stain from lowes. not that hard. that's what we did.
May 31, 2009 | Simplicity for Children Prescott 4-in-1...
Aspen 870 Crib Instructions
PLEASE READ THIS WEBSITE INFO ASAP! The model 38740 WAS RECALLED! Please check your serial number with this wepage! http://www.consumeraffairs.com/recalls04/2007/simplicity_cribs2.html
Also, you can call Simplicity Inc, who made this model with Graco at 1-800-858-8323. If your model is not recalled, I'm sure they can instruct you on obtaining a manual! Good luck!! :)
Aug 30, 2008 | Graco Apsen 3-in-1 8740 Crib
Converting crib to full size bed
I did not solve the problem but I can not afford to pay your premium for one set of instructions.
May 27, 2008 | Simplicity for Children 4-in-1 Convertible...
Tribeca Queen-size Bed Logo
Top Tribeca Furniture Experts
Dan Webster
Dan Webster
John Tripp
John Tripp
Are you a Tribeca Furniture Expert? Answer questions, earn points and help others
