Question about Insignia Kix NS-1A10F MP3 Player
Open battery how to replace the battery
How do you replace battery in chamberlain remote, garage door model 2487355
Do you have the Chamberlain 248735S garage door opener? Chamberlain doesn't have a 2487355 garage door opener; there are the 248735 and 248735S openers.
Most of the Chamberlain remotes are simple to open. Use the visor clip or a flat blade screwdriver to pry the two parts of the remote housing apart. There should be an open space on one edge of the short sides of the remote where you can insert the blade to begin separating the remote housing. Once started, you may be able to separate the rest of the housing by pulling the two sections apart with your hands. See page 32 of the user manual to see a picture of the separated remote or http://support.chamberlain.com/articles/How_To/How-do-I-remove-and-replace-the-battery-in-my-remote-control-1484145519292/?q=change+battery+in+remote&l=en_US&c=Brand%3AChamberlain&fs=Search&pn=1 for the procedure. Replace the battery with a 2032 coin cell battery, if you have the 248735S. Replace the battery with the correct replacement coin cell battery for other garage door opener models. Make sure that the side of the battery with the + faces the section of the remote housing with the buttons. The manual for the 248735S is currently here: https://www.chamberlain.com/CatalogResourcesV3/en-us/shared/files/tucmanuals/114A4256.pdf . Support and manuals for other models of Chamberlain garage door openers can be found from their support page: https://www.chamberlain.com/parts-and-support .
I hope this helps.
Jul 30, 2017 | Building Materials
How do I open my Apple G3 I phone
There is no way to get to your battery. Apple makes their phones really closed. To replace a battery you must have special tools and special skills. and to replace the battery, you first have to buy one. You won't find these batteries in a phone store.
If you insist in doing it yourself, feel free to visit ifixit.com, to see how they open an iPhone for repair and battery replacement.
Jul 13, 2014 | Apple iPhone Smartphone
Can't open to change battery
Google the model number for "manual" which if found will have instructions for replacing the battery or take it to some place like walmart who will open and replace it for you.
Nov 05, 2012 | Watches
How do I change the batteries on my WW60X? I can't find my manual but was able to open the battery cover to get the number for the batteries. Now I can't get the batteries out of the scales. ...
Your Instruction Manual is here:
http://www.conaircanada.ca/pdf/en/ibs/en_WW60XC.pdf
Battery Replacement Instructions
1. Turn over the scale and open the battery door. (Push ribbed switch and pull up)
2. Replace old batteries with two new 3V Lithium batteries (CR2032).
3. Close battery door.
4. Properly dispose of old batteries.
There is nothing holding the batteries in place once the battery door is opened. If the batteries are difficult to remove, use a small screwdriver to gently pry up on the battery or simply after opening battery door invert the scale and shake.
Mar 10, 2011 | Conair WW60X memory electronic Weight...
We need to chage the battery in our 2006 corvette key fob. How do you open it?
There should be a slot on one end that you can put a penny into or something similar, and it should pop open.
Jan 21, 2011 | 2006 Chevrolet Corvette
How do i open the key fob to replace the battery
For 2009 Cadillac CTS
Remove the hidden key by slipping a small screwdriver or knife under the metal endcap and lift. The key will come out. To replace the battery, pry the two halves of the main plastic housing apart, exposing the CR 2032 battery.
May 17, 2010 | Cars & Trucks
How to open to replace battery?!
Check the manuel for opening the battery cover. Otherwise go through the product review in the company website.
Dec 09, 2009 | Laser Logitech O - Mx400 Performance ...
Hello, Ineed to change the battery of the time and date. I want hnow the number of the battery to buy one and changing. Regards Josephine.
Sounds like you uwant to change your CMOS battery. You should bring this to a professional so as to not damage your computer. If you don't know what you are doing to will cause more damage than a worn out CMOS battery
Sep 13, 2009 | Compaq Presario Notebook
How to open for battery replacement
Found this link that may help you out. Seems like they are made to be used then tossed out. What a waste. Anyway the battery replacement issue is a common problem... http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
May 25, 2009 | Remington R-9190 Electric Shaver
Braun 7526 battery problem
Open the shaver:
1) Use a small flat screw driver pry off the bottom (where the cord plugs in)
2) Remove the silver sides
3) Using a small torq driver remove the 4 scews
4) Open shaver
5) Remove circuit board with batteries
6) Remove and replace circuit board with batteries (or solder in the new batteries)
Oct 25, 2008 | Braun Syncro 7526 Electric Shaver
Insignia Kix NS-1A10F MP3 Player Logo
19 people viewed this question
Top Insignia Audio Players & Recorders Experts
Alan Matzke
Curt Larson
Level 1 Expert
Are you an Insignia Audio Player and Recorder Expert? Answer questions, earn points and help others
