Question about Onkyo Audio Players & Recorders
How to remove platter on Onkyo CP1100A - Onkyo Audio Players & Recorders
2 Suggested Answers
Grubhead
  • 5151 Answers
SOURCE: turntable wont spin
If the mat lifts up to reveal a hole then you might get at the belt that way. I would have thought that the platter will lift up anyway. It might be held by a clip washer, around the spindle, from the top, sometimes hidden under a glued plastic piece. If you can't get in that way unscrew the base.
Posted on Jul 12, 2009
How to remove Platter on JVC L-A120 Turntable
Hi Jeff...
The platter on the JVC LA-10 does not come off as most turntable platters do. It is attached to the spindle with a Philips head screw.
Here are the steps:
Remove dust cover from turntable. Unscrew hinges and lift.
00.jpg" alt="Remove dustcover at hinges.">Remove dustcover at hinges.
  • Secure tonearm to prevent stylus damage.
    00.jpg" alt="Secure the tonearm.">Secure the tonearm.
  • Remove slipmat from platter.
    00.jpg" alt="Remove slipmat.">Remove slipmat.
  • Turn the turntable on its side and remove screws that hold the top to its base. Remove platter by unscrewing the bottom plate from the turntable. The spindle bearing is held in place with a Philips head screw. Loosen it and the platter will separate easily from the spindle.
    00.jpg" alt="Separate the spindle from the platter by loosening with a Philips head screwdriver.">Separate the spindle from the platter by loosening with a Philips head screwdriver.
  • Loop replacement band around the pulley cylinder in the motor. Replace platter and bottom plate. Tighten spindle screw. Test the new belt by turning the platter clockwise two or three rotations. Belt should fit snugly and turn with little resistance.
    00.jpg" alt="Test the replacement belt by turning the platter clockwise.">Test the replacement belt by turning the platter clockwise.
  • Feb 05, 2016 | JVC Audio Players & Recorders
    Automatic turntable adjustments
    The Service Manual may be downloaded at:
    http://www.vinylengine.com/library/onkyo/cp-1055f.shtml
    You will have to register (free) before downloading.
    Mar 28, 2014 | Audio Players & Recorders
    I HAVE A PIONEER PL-30 TURNTABLE AND I NEED TO REMOVE THE 'PLATTER' IN ORDER TO REPLACE THE BELT. THERE IS NO CLIP TO REMOVE. HOW DO I GET THE 'PLATTER' OFF. AGAIN THERE IS NO CLIP FOR REMOVAL.
    Pull up on the platter with one hand after you remove the rubber mat. Then hit the center post with a rubber mallet while pulling up on the platter with on hand just hard enough to release the platter from the post. The platter should come off.
    Aug 06, 2013 | Pioneer Audio Players & Recorders
    Where do I attach a ground wire on an Onkyo CP1100A turntable? I'm getting a hum. Thanks. GK
    Some amps have Earth connections for them. But any kind of metal might do it.
    Aug 04, 2013 | Audio Players & Recorders
    Onkyo Diagram
    To replace a turntable drive belt.
    Before starting ensure you disconnect the power supply.
    1, Remove the rubber platter mat to expose the platter.
    2. Put your thumb and forefinger through the two round holes and lift the platter off. You may need to give the center spindle a light tap (whilst applying upward pressure) with a screwdriver handle or some similar tool that will not leave any marks or damage.
    3. Remove the old belt and wipe the platter pulley and motor pulley with an alcohol swab to remove any old belt residue.
    4. Place the new belt around the platter pulley making sure t is sitting flat without any twists.
    5. Flip platter over the right way up. There are1or 2 larger rectangle shaped cut outs in the platter.
    6. Through the cut out pinch up the belt and slip a finger or belt hook between the platter pulley and the belt gripping the belt ready to fit over the motor pulley.
    7. Align the center hole of the platter with the spindle and place platter back into position keeping a grip on the belt.
    8. Slip belt over motor pulley and give the platter a light clockwise rotation to ensure the belt is riding correctly.
    9. Replace the rubber mat and then run the turntable to ensure correct operation.
    Remember, when changing between 33 & 45 rpm the platter must be rotating to ensure correct belt repositioning on motor pulley.
    Job done.
    Copyright, Styluscity.com
    Apr 27, 2013 | Audio Players & Recorders
    Turntable wont spin
    Jun 28, 2009 | Technics SL-BD20D Turntable
    Removing the platter to oil the motor shaft
    hi .... get any object ( like hammer, or handle or wood) tap slight on the middle spindle of your turntable until become loose,...
    May 28, 2009 | Technics SL-1200MK2 Turntable
    Onkyo Dvd
    It is likely that the little platter that supports the centre of the dvd has been pushed down on the spindle motor shaft. Setting this to the correct height should allow disks to rotate without being scratched.
    Mar 16, 2008 | Televison & Video
    Onkyo DR-C500 won't recognize discs
    Onkyo units as well as several other manufacturers have a common problem where the spindle motor gets intermittant or wont come up to speed.Its not hard to replace this motor, but could be a trick to adjust the platter height. Also the unit probably needs a servo alighnment as well. This unit could also have a simple problem as a dirty laser lens. You can try to use a disc lens cleaner to see if that helps. Good Luck
    Jun 24, 2006 | Onkyo DR-C500 Multi-disc DVD Player
    50 people viewed this question
    Top Onkyo Audio Players & Recorders Experts
     Grubhead
    Grubhead
    Are you an Onkyo Audio Player and Recorder Expert? Answer questions, earn points and help others
