Question about GE Advantium 120 Convection/Microwave Oven
Oven works, microwave does not work
Oven works
After I entred the desired minutes, when I press START it does not work. And if I press the ADD MINUTES, it is not working. Please can you tell me any solution. Can this problem be due to not cleaning the...
HELLO.
The steps to the solution are as follows.
Off the microwave oven and it.
Then plug the microwave oven and power on the microwave.
Allow the microwave oven to load itself.
Then reset the timing program.
Test the microwave for normal operation.
NOTE:if the problem persist,cleaning the microwave is the next solution.Below is the solution to cleaning the microwave oven.
  • Remove oven racks and soak them in soapy water.
  • Turn on your automatic oven cleaner; this usually entails locking the door and turning the function switch to "clean."
  • Let the oven do its work; it will heat for several hours, charring off baked-on foods.
Thanks.
Sep 20, 2011 | Kenmore 63652 Microwave Oven
Microwave not working. all lights and timers working but oven not heating(not hearing the hum you hear when it is working properly). all buttons functioning properly.
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Basic Microwave Oven TroubleshootingTips
heatman101';][][
May 04, 2010 | GE JVM1320 Microwave Oven
Sharp microwave grill and oven working ok, microwave option not
the magnatron is burnt out they are very expensive to replqace thus i would suggest bying a new microwave
Apr 21, 2010 | Microwave Ovens
Sharp R-1871 microwave/convection oven. Microwave will not work
This may be due to the microwave section not working. Check the high voltage diode if it is ok, replace the Magneton.
May 29, 2009 | Sharp R-1871 Convection Microwave Oven
My GE Profile Convection Microwave Oven - Convection not working
Microwave Oven Basic Troubleshooting Tips
heatman101
uijjf
Dec 02, 2008 | GE JVM1790SK Convection/Microwave Oven
Microwave oven does not heat anything
heatman101
l;hkhtguii
Oct 13, 2008 | Magic Chef MCP13E1ST 1000 Watts Microwave...
GE Advantium 120 Convection/Microwave Oven Logo
12 people viewed this question
Top GE Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
D. E. Hev
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
