Question about Saeco Vienna De Luxe Espresso Machine
Where to set the dial to make the coffee coarser on a Vienna machine
SOURCE: Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Posted on Jul 22, 2007
SOURCE: Problem getting a Full Cup of Coffee
besides descaling you need to lube the brew group, especially the bit that accepts the group nozzle. You might have a leaking boiler too, 6 years is pretty good for a vienna.
Remove the brew group and look for the two red o-rings on teh brass bit, smear some lube on it, they might need replacing by now, but luckily they aren't too expensive and readily available albeit a bit tricky to install, a good light and some patience is very important.
Posted on Dec 16, 2007
SOURCE: saeco vienna "machine ready" light
seaco vienna , same problem like above, but cold water coming out. My guess is heating element. Am I right ?
Posted on Nov 06, 2008
espressonist
  • 1711 Answers
SOURCE: how do I clean my Saeco Vienna SuperAutomatica
In order to proceed with decaling of the espresso machine you need to have the solution appropriate for decaling an espresso machine.
Different brands of espresso machines, like Krups, Saeco, Gaggia e.t.a. have their own brands of decaling solutions. You should know that all of these are similar products so you can use them in all different bands if you don't have the one of you specific brand without any problem. So if you have Krups machine and you can only find Saeco decaling solution you can use it with the same results.
One thing you should have in mind Never use any Vinegar as a decaling solution since this will destroy some parts of the machines not instantly but in long term since vinegar is corrosive to this parts.
So the first thing is to remove any water fitters or small softeners that are included in you water tank. Fill the water tank with water up to maximum, dissolve your solution in the water you do need only two to three spoonfuls of solution.
Switch on the machine and wait to warm up. When the machine is ready you can turn the water knob and start getting some water in a pot. Leave it for a couple of minutes and then again the same. Do these until you draw off all the water with dissolve solution. After that leave the machine for more than 20 minutes. Remove then the remaining water with solution from the water tank, rinse it and fill it with fresh water. Now draw again continuously hot water from the machine in order to rinse it completely.
The last portion of hot water taste it to be sure that is pure clean and if not refill the water tank again and perform another rinsing.
Now the machine is ready to be used again.
Try to do decaling every 20 to 30 days.
If you plan to leave the machine unused for along time perform a decaling in order to avoid the possibilities of having the machine stuck when you will try using it again after a long time.
A machine which is used frequently every day is more secure to work fine even without any decaling but machines which are used rarely is more possible to have problems of stacking out in water outlet or coffee outlet.
Posted on Jul 01, 2010
espressonist
  • 1711 Answers
SOURCE: Vienna deluxe automatic coffee Machine
Despite that this due to a relay on the control pcb board you need to replace the whole board to solve it.
Posted on Nov 01, 2010
What would cause the machine to grind the beans but not produce any coffee despite the water tank being full?
Your grinder setting might be too fine. Only adjust while the grinder is grinding -- set to a coarser grind. Have you tried the preground coffee dispenser? Again, use coarser ground coffee in case the sieve is getting clogged.
Mar 27, 2015 | Coffee Makers & Espresso Machines
Coffee drips very slowly and descaling not helping
I had the same problem. Check and make sure your dose is not turned up too highor your grind is not set too fine? Turning the dose knob clockwise decreasesit. I have ended up with my grind set on 13 which is more coarse than averagefor the beans I'm currently using. Adjust the grind while the grinder isworking by one number and then brew 3 or 4 coffees before changing it again. Ittakes that long for the grind to be seen in the coffee. The higher the number,the coarser the grind will be. Any time you use different beans it is possiblethat you'll have to reset the grind.
Oct 31, 2010 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna Superautomatica will not make a full cup of coffee
I'm wondering if you had any luck solving this? After 3 years of great coffee, my machine is only making a 1/4 cup or so. All parts are clean. I'm guessing something on the circuit board that the dial is attached to....thanks!
Feb 27, 2010 | Saeco Vienna SuperAutomatica Coffee...
Grinder settings for Vienna Deluxe
Hi
To start off with, you should not change the big knob unless the grinder is operating at the time.
Set the small knob to the middle position. You can move this any time. Move towards the + mark to strengthen the coffee, but never all the way to the full +.
Set the big knob to the #8 to start off with. Move it 1 # smaller to make the coffee stronger but be careful not to get it to fine as you will clog the grinder and you will have to take it apart to clean. If you ever get an out of beans light, but there are beans in the hopper, open the knob to #16 for 1 cycle, then turn it back down to a # 1 larger than you had before and leave it unless you get the message again. Shiny beans call for a coarser grind than a dull bean because of the oils in the coffee bean. Oils will cause the grinds to stick together and cause clogs faster than beans that have less oil.
Jul 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Change the grind in Saeco Vienna Deluxe coffee maker
Hello kgspco.
You will need to work the 'dial knob' untill it free's it-self.
The higher the number the Coarse(r) the grind.
If you want rich - dark - strong coffee, set number between 4 - 8.
(if you can free it up - keep trying
Jul 06, 2009 | Saeco Vienna De Luxe Espresso Machine
Think Pump or boiler broken as water doesn't flow through
If you cannot get hot water from machine(brew unit or steam valve), then there is something wrong with boiler elements.
If water won't flow thru coffee(pump is not vibrating) and you've tried adjusting the grind to a coarser setting, then you will have to replace the pump($50).
However, since no water is going thru machine and it does not heat up then the problem might be the board or the inline fuse on the machine.
May 16, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe grinds but plugs up at door
Try this: clean out the chamber, then set the grinds coarser to see if it makes a difference. If it does not then the micro switch or solenoid that controls the door is broken. Check resistance on solenoid it may need to be replaced.
May 10, 2009 | Saeco Vienna De Luxe Espresso Machine
Our Saeco Vienna deluxe had a couple of problems: the grinder wouldn't stop grinding..coffee all over the place...stopped it cleaned it and it's ok. The other problem is that it takes forever for a small...
What does the coffee produced taste like, is it bitter and watery, is there any creama on the espresso shot. Try adjusting the grind and the coffee level, maybe a little coarser.
Mar 26, 2009 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna De Luxe Espresso Machine Logo
18 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
