TV RCA RLDED 3258 A-B SHOWS no signal on all stations
Tv was working normaly then suddenly when first turning on all that shows on the screen is No Signal on all channels
jerryg50
  • 1667 Answers
SOURCE: No Signal through on my main TV input.
This may be the tuner or IF module that is failing. It may also be a voltage supply fault to these modules. It is impossible to accurately speculate without actualy troubleshooting the set.
Jerry G.
Posted on Apr 19, 2008
Benimur
  • 6966 Answers
SOURCE: Sony Tuner KV-20TS27 loses signal
Either that of your tuner block is acting up. Most Sonys of this production year uses a tuner block that requires 33VDC tuning supply. It has been known for this zener to fail or the capacitor parallel to it. At times, it could just be the tuner block itself.
Should you venture a DIY, it would be to your advantage to have access to a service manual or at the very least a schematic diagram with voltage readings.. It further requires familiarity with electronic components and circuitry, use of a DVM and a soldering iron. Should you be uncomfortable going this route, then perhaps your best bet would be to seek the services of a qualified professional
Hope this be of initial help/idea. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Thank you for using FixYa.
Posted on May 11, 2008
SOURCE: No picture, no sound, but TV is on
do a chanel set up through the menu as if it was the first time you plugged it in. there is no signal on a digital tv with out an initial set up.
Posted on Jan 11, 2009
ginko
  • 19396 Answers
SOURCE: Bush TV Model No 5693D
Try using the source button to switch through different inputs.
If that does not work try connecting a signal booster to the aerial, they cost about ten pounds at Argos.
Posted on Apr 29, 2009
  • 176 Answers
SOURCE: ilo tv shows no tv signal, I believe that the
Here is how to try and get them back if they are available.
On the original TV remote do the following-
1. Press the MENU button
2. Use the channel down button to select channel set
3. Select channel add/delete
4. Press volume up
5. Select channel you want to add by using the channel up/down buttons on remote.
6. When you get to the channel you want use the Volume up button and the color of the channel number should become either blue or green if it is added and it will be red if it is deleted.
7. Repeat until you have added all the channels you feel you are missing.
8. Press MENU button to exit.
If the channels are still available this should get them to return. If not contact you cable provider to see if they have moved some of their channels recently or check their web site for the current channel line up.
Good Luck and please rate this solution....
Posted on Jan 08, 2010
Why does screen show 'no signal' message?
generally that sign means that there is no signal from the transmitter of the tv company
if changing channels shows as programs then it is at the tv station
if you are moving the aux input selection and there is no wii or dvd,cd pc connected it will show as no signal
basically it is no input signal into the tv set
Sep 16, 2015 | Seiki Televison & Video
My rca tv will not work
try another input like video one or DVD or whatever you have plugged in it directly through HDMI or component, if it works it one of two things, your tuner inside the TV is damaged, or the signal from your cable is not there, bad wire or lost service.
Tony
Nov 25, 2014 | RCA Scenium HDLP61W151 61 in. HD-Ready...
The tv shows on the SCREEN NO SIGNAL model PV 16190 and when trying to use the dvd shows TRAY ERROR
The DVD mechanism to your TV is faulty. Just check whether it receive any external signal. Connect it to external areal and try to tune it to get on-air stations. If it receives any, just repair its CD tray mechanism. In most cases, the loading mechanism need replacement.
If the TV do not receive any on-air station too, the tuner to your TV is faulty. Do the needy. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Oct 14, 2014 | Televison & Video
Loss of Digital Shows??
U have cable's or dish's boxs?unplug,replug the box for the software to down load to upgrade.Unplug,replug the tv.Go to the menu set for Air or Cable then rescan all channels
Oct 26, 2009 | iLO V27DMBX Television
NO channels now, we had some before!!!!!
Here is how you should have it connected.
1- Antenna (rabbit ears or whatever)
2- Converter box
3- Television
When you turn on the TV and the converter box, go to channel 3 on the TV. You should see the converter box signal there. If you do not see it try channel 4. Bring up the convert box menu and go through the AUTO SEARCH, not manual search. Now your box will search all the frequencies and add any stations that are in your area. Make sure you change channels with the converter box, not the tv. An antenna on the roof will still provide somewhat better range, but even rabbit ears will likely pick up something. If you still get no channels you could be too far away, digital signals have a shorter range than analog signals. You can check your local TV stations website or call to see if they are broadcasting digital yet.
Apr 08, 2009 | RCA Analog (RCA) to Digital (VGA)...
Philips 3258
1. With the remote control, turn on the player. Keep the tray closed.
2. Press SETUP and use the buttons LEFT or RIGHT (arrows) to go to the Preferences Page.
3. Type 138931 and a screen will appear on TV.
4. Use the buttons UP/DOWN (arrows) to change the region code to 0 (zero), then press OK.
5. Turn off the player and turn on again.
OR
open lid; slowly press 9,9,9,9, then 0. will show region 0 on screen for maybe 2 seconds , shut lid & you are done!
One of these 2 should work. If one does post back which one please.
Sep 08, 2008 | Televison & Video
RCA TV
my tv shows a black screen with words saying...UNUSABLE SIGNAL
Sep 07, 2008 | Televison & Video
36" RCA TV
My RCA G36788LV 36" television won't turn on
Oct 30, 2007 | RCA G36788LV 36" TV
RCA F32665 Shows only gray screen, sound works.
You have a problem in the video circuit. Any video that comes into the set is not getting to the picture tube. The menus come from the system control microprocessor. This shows that the input at the picture tube itself is working. Also you system control is working. The signal would have to be traced through the set to find out where the loss is originating. Stargazer
Jun 14, 2007 | RCA F32665 32" TV
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
