Question about Saeco Vienna De Luxe Espresso Machine
Water under vienna coffee machine
Much water gathers under the machine when in use, I cannot see where it comes from ??
SOURCE: Vienna De Luxe Espresso Machine
You can download a manual at www.cerinicoffee.com
Posted on Jul 22, 2007
SOURCE: saeco vienna deluxe espresso machine
adjust the water flow look for a knob that turn right to left minus less water plus more water
Posted on Dec 30, 2007
SOURCE: Saeco Vienna: water does not go through to the main unit
I had the same problem and got on the Saeco US website and talked to an online support person. She downloaded me a couple of pages of "fixes", I tried them and they worked! You have to take the two screws out of the brew group, remove the spring and a little clear plastic ball. Then clean out the hole thoroughly. I stuck a toothpick up into it from underneath to clean out the coffee that was stuck in the hole. I then put it back together and now it works perfectly.
Posted on Aug 02, 2008
SOURCE: Saeco Vienna Coffee Machine water leak
I have had the same problem with my Saeco Digital & Saeco Superautomica machines. After much work and somewhat expense I have finally found a simple fix. All you need to do is replace the gasket which is located just under the water reservoir.
(1) Take the water reservoir off
(2) Pop the round plastic piece located in the middle off (don't worry you won't break it as is it pretty tough)
(3) Take the black rubber gasket out and either:
(a) cover the present gasket with the brew group lube or
(b) replace the gasket with a new one.
which will give it a air tight fit and prevent any further water leakage from the reservoir.
You can get a new gasket for $5!!! :) I got mine at: http://cerinicoffee.com/item.asp?cID=0&PID=90
I also put some Brew Group lube ( http://cerinicoffee.com/Lube_brew_group_saeco.asp ) around the gasket as a temp fix until I completely replaced to gasket. Apparently, what happens is that the original gasket gets old, dry rots or whatever allowing the water to leak out of the reservoir. And then all over your work surface. The Saeco machines are quite intricate but are
Hope this helps.
-Dave
Posted on Nov 29, 2008
espressonist
  • 1711 Answers
SOURCE: saeco vienna leaks CLEAR water from under the machine.
The leaking is from the water pipe coming from the boiler thought the solenoid valve to coffee group. Their are many points that this leak can be so the only way to find it is to run the machine completly open without the plastic sides. The most posible postion is the plastic hose conected on the coffee group and some times you will have to place it back in position very easy.
Good luck.
Remeber to vote for this answer.
Posted on Feb 25, 2010
Hi our CB18M/1c/FAN keeps gathering water under the salad trays please advice thankyou
You say it runs down the channels.
Is their a drain hole at the bottom?
If the drain hole is blocked then you will need to unblock it using compressed air or a thin piece of medium flexible wire.
It should drain to a pan near the compressor and evaporaste from
there. Sometimes a loose particle of food can block the drain, usually at the back lower position of the fridge.
Jul 25, 2015 | Refrigerators
What does EFO mean
Its an anti flood warning. generally it means something has leaked into the cabinet and water has triggered the safety float on the floor of the cabinet. You will probably find a small leak somewhere which has allowed water to gather under the machine. IE/ Hose, front gasket, pump etc.. If you tip the machine backwards to drain all the water out of the base, it will probably work until the safety switch triggers again. Locate and fix the leak before it gets worse and causes some damage.
Mar 08, 2015 | AEG Washing Machines
Water is gathering in the refrigerator of my whirlpool ET20GK. I can not determine where it is coming from.
Can you be more specific on whether it's gathering? If you have a top mount(freezer on top) fridge and water is gathering on the top shelf in the middle, you have a clogged drain and need to flush it.
Aug 04, 2013 | Refrigerators
Thread is gathering under cloth
Check that the thread is tight around the bobbin. Make sure that the bobbin is in the right way around - the bobbin thread should double back on itself coming out of the bobbin holder. The bobbin tension adjustment is the small screw in the plate on the bobbin case that the thread passes under as it comes off the bobbin and goes out.
May 05, 2011 | Olde Thompson PWZ500
My machine gathers thread in the bobbin and then the thread breaks off.
check the needle to see if it's damaged
some sewing machines gather thread in the bobbin area when the thread come off the thread take up lever
check the bobbin & bobbin area for burrs
Sep 23, 2010 | Singer Sewing Machines
No espresso coming out.
The problem with the XP4050 is the two safety valves that the water goes trough on its way to the coffee head. They are plastic and some of the parts will just become brittle because of the hot water and the contamination they gather. With my XP4050 they just broke and parts of it were in the rubber tubes that go to the waste tank.They are also very cheaply constructed compared to the more robust parts of this machine. The water to the hot water/steam head does not have these valves and has a completely different routing. I am currently trying to fix the machine with just one valve and parts of the two valves that are still good. Fingers crossed....
Apr 20, 2010 | Krups XP 4050 Espresso Machine
Water leaks from my Aquasmart 8 kg washing
On most units, the water pump was a "weep" hole on it which tells you pump needs to be changed soon. It tells you the internal seals are starting to fail.
Dec 28, 2009 | Washing Machines
Freezer door pops open when refrigerator door is closed and water is gathering under vegetable drawers.
Well the water gathering is probably the drain hole plugged,(under bottom drawer),its a round plug that sticks up a little,it turns out like a bolt,--now about the freezer door,how is the door seal?bad as in warped,torn,bent?incase you didnt know there is a magnet inside the seal.also check if the door needs to be re-adjusted
Apr 21, 2009 | Refrigerators
Hotpoint HDA3230Z02WW Dishwasher leak
Hello ajs10172003
Welcome
You said, you have a leak under my dishwasher every time you run a load but can not tell where it is coming from. When you looked under the dishwasher it appeared to be leaking under a white cylinder shaped part. This is where the water was gathering at. Not sure what this is. Maybe someone can shed some light on this.
It is probably the SOLENOID that is leaking.
This opens and closes to control the water coming in and going out!
And it looks like cylinder as you described.
Time to replace that part if this is the case. An easy repair only a $40 part.
call service!
Let me know how it goes!
Huuum,
Please remember to leave a rating!
Oct 20, 2008 | Dishwashers
Gathering thread under the clothes
check needle to see if it's in backwards
check needle to see if it's bent-lay the needle on a flat surface & roll the needle over, if the needle doesn't roll good replace
check to make sure machine is threaded right
check for lint or loose thread fragment in bobbin area
Jun 02, 2008 | Singer 3116 Simple
Saeco Vienna De Luxe Espresso Machine Logo
22 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
83bj60
Level 1 Expert
Shehu Pro
Shehu Pro
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
