Creda 79163 Hi, I have a creda 79163 convector storage heater. I t does not charge up overnight but the convector part works. An electrician has tested it and said there is power getting to the dials. Any ideas what's wrong?
4 Suggested Answers
SOURCE: dimplex dual night storage heater/convector heater
runs for 30 seconds then shuts off
Posted on Jan 23, 2008
  • 38 Answers
SOURCE: i have a creda storage heater 79153, i turned it
Check the fuse board it should be marked up (but often is not especially if POLISH electricians concerned) it should be a 32 amp fuse.
The heater has a thermal fuse installed internally £12 replacement, these tend to be the only things that go wrong with storage heaters! get a qualified electrician who you trust to have a look otherwise who-ever looks at it will say its F****d and will take you to the cleaners
Posted on Nov 04, 2009
SOURCE: operating instructions for creda storage heaters
how do you regulate the heat from creda storage heaters model No 79163 /79151 /79141 they have 2 dials on each heater,I was told the dial on the right turn up to 6 its highest point & the left dial to its lowest number 1 .But i got up this morning & its like a sauna
Posted on Feb 16, 2010
Creda 79141c
Turn it off and have it checked by a registered electritan. Please DO NOT use it until you have!
Jan 28, 2014 | Heating & Cooling
Creda storage heater manual
I'm not a heating expert, but according to the information I could find, Economy 7 utilizes cheap electricty at night, during off-peak hours (7 hours) between midnight and 7AM. Economy 7 costs about 4p per unit compared to peak electricity, which is about 10 to 15p per unit. If you do not have Economy 7, you can request it FREE of charge from your electricity provider. You will either have one meter with two readings or two separate meters. A two tariff electric meter will record the electricity used during off peak times, so it can be billed, separately, at a lower rate. If you have two meters, one meter controls on peak daytime electricity and the other controls your night time economy 7 electricity.
I would need to know what model Creda heater you have installed in order to determine how energy efficient it may be. I also will need the model so I can determine operating instructions. If you need further assistance, please post back and let me know. I hope this helps.
Nov 15, 2011 | Heating & Cooling
How to operate an economy 7 heater
storage is when it stores up heat at night and convector is when you use it in the day , best I can tell you .
Oct 21, 2011 | Heating & Cooling
I have a creda storage heater 79153, i turned it on on sunday night monday morning it was still cold , i changed the fuse at the wall still nothing, the only part that works is the convector heater at the...
Oct 21, 2009 | Heating & Cooling
What size breaker do i use?
at 10kw, that should be about 34130 btu's. With 240 volts, you should be using approximately 41-42 amps. Check the manufacturers name plate for breaker sizing. probably a 45-50 amp double pole breaker will work, also check with a licensed electrician to make sure that the wire is sized correctly for that unit. Hope this helps.
May 01, 2009 | Fahrenheat Electric Convector Baseboard...
Operating instructions for creda storage heaters
Jan 03, 2008 | Heating & Cooling
Low heat output
first of all, have the thermostacts been checked,if not they will need to be checked,mainly dust can get into them.
if they have heating elements,ckeck to see if they are all in tact and have no dust on them.if this does not work then you will need new heating elements,which you might not get any more,if this is the case then im sorry to say that new heaters will be needed. i hope this helps and good luck.
Nov 21, 2007 | Fahrenheat Electric Convector Baseboard...
Heating & Cooling Logo
15 people viewed this question
Top Heating & Cooling Experts
paulcarew
Dan Webster
Dan Webster
Donni Steen
