Wt8951nd cant connect laptop to wireless router. comes up with error code wan 020
    Sergeant:
  • 260 Answers
Power cord
RJ-11 telephone cable coming from a splitter or the extn. line of your landline phone.
Ethernet cable coming from your Desktop/Laptop connecting RJ-45 port
Most standard ADSL modems have four/five lights in the front :
Power light to indicate electric power to the modem.
ADSL light indicates the status of ADSL sync. When the modem is synchronized with the ADSL line card at the other end of the circuit/loop, the DSL light will be steady green.
LAN light will glow steady green when the modem detects a successful link to a computer or router ethernet port.
ACT i.c. Activity light glows when the modem is sending and/or receiving data on the lan and wan. It will vary between very slow to fast flashing and steady green to indicate lan/wan traffic.
for more help visit CBR Tech Solutions
Posted on Nov 13, 2015
  • 101 Answers
SOURCE: WAN light off on router
Hi Bootstrap,
Try a new cable. I know it sound strange, but I have had some work in one port, and not others.
If you still don't get a WAN link light, try resetting your router. We don't know what Netgear you have, but usually there is just a small hole where you press in with a paperclip, or pencil, and hold it in for 30 sec. Lights should flash when you release it. Connect your PC to one of the LAN ports, with the router powered up, and power up your PC. On your PC, go to STARTt>RUN>type in CMD. Press Enter. In the black bix that opens, type ICONIFG.
Look for your IP Address. It should be 192.168.x.xxx. (X can be any number up to 254.) Subnet should be 255.255.255.0. Gateway IP should be 192.168.x.1.
If your IP address is 169.xxx.xxx.xxx, you are not connecting to your router, or your router is not issuing an IP, thru DHCP.
Make sure your router basic settings is setup for your Internet connection type, i.e. DSL or cable. If all that fails, can you return the router? Is it new? What model Netgear is it? The WAN port not working does make me think it may have been damaged by a power spike. Have you had any lightning storms lately, or power outages?
Let us know if any of that helps. Or give us more info and we can see what else we can find.
Posted on Jan 14, 2008
One Piece
  • 53 Answers
SOURCE: Connecting a netgear wireless router to a 2wire
before you connect the netgear router to your 2wire modem, you have to get the modem configured first. you did not include the firmware version of your modem (firmware version is found at the UI, go to gateway.2wire.net, click on the system icon.) for firmware version less than 3.7, go to homeportal/management, click on configure services, uncheck enable routing, then click on submit. for version 3.7 or higher, go to homeportal/management, click on configure under broadband link, put a dot in disable pvc search, set VPI to 0 & VCI to 35, the connection type box should be direct IP, then click on submit. then go to configure services, uncheck enable routing box, then click submit. you will notice the broadband link on the 2wire modem turn orange/amber, then you have successfully set the modem to bridged mode. that way you can now connect the router according to manufacturer's instructions (or just read the manual for the netgear router....)
Posted on Apr 03, 2008
RickOz
  • 145 Answers
SOURCE: Connecting Laptop wireless and Desktop wired to the router
Do you need to see the desktop or just share folders from each other? If the latter then you need to do the following:
Use Windows Explorer and select a folder you want to share. Right click and select sharing and security.
On the sharing tab click on Share this folder. Enter a share name ( I like to enter the PC name _folder name; Rick1_Downloads)
Click on Permissions. If your ok with everyone using the PC's and Laptops having access then highlight Everyone and click on Full Control.
Do this on each PC and Laptop.
That should be it or darned near close.
Posted on Apr 10, 2009
yboyandrei
  • 828 Answers
SOURCE: connection from billion 400g wireless adsl router to Fujitsu
please check your fujistu if there is wireless lan built-in...
Posted on Jun 16, 2009
mbase213
  • 728 Answers
SOURCE: my laptop can't connect via wireless to my att/dsl
Hi toasoulinh,
First off you need to go to your network connections, and right click on the wireless connection and view status. Then click on the support tab, and then the details tab. This will show you what the IP configuration is. You need to have a gateway (which is your wireless router IP) and a assigned IP address for the laptop, and also a dns IP to resolve who you are. I'm going to guess that one of them are missing, perhaps the DNS? If there is any missing click on the repair button, and see if it corrects the problem. If not, then you have a bigger problem then you bargined for. You will need to go to your network connection and click on wireless connection. Inside you will find a add wireless connection button. Click this button and windows will walk you through creating a new connection. If that doen't to the trick.
You can reconfigure your HomePortal without using the setup CD.
  • Open your Web browser.
  • Type http://homeportal/setup in the address or location line of your browser.
  • Follow the on-screen instructions to complete the setup process.
    • If you need a key code, you can find it at HERE
    • If you need to replace drivers for your 2Wire network adapters, you can download them directly from the 2Wire support Web site.
Good Luck,
And don't leave a rating
Thanks
Mark
Posted on Sep 21, 2009
How do i connect a wifi router to the dsl of my pc?
Your internet provider should have provided you with a modem (dsl modem) that will have a ethernet port which can be connected to a computer directly or a router to make internet available to multiple computers. Router usually comes with five ports one of them is WAN port (Wide Area Network) and other four are LAN ports (Local Area Network) The dsl modem should be connected to WAN port of your router and the LAN ports are use to connect to any computer with an ethernet cable. If the router has wireless capability you can use your laptop or smartphone to access internet wirelessly!
Sep 23, 2011 | Computers & Internet
I have to internet subscription.I connected it to the router but when i tried to connect the router to my laptop, i cant browse to any site (internet connection is very ok).
The router that you have is a Dual-Wan router, specifically designed for hooking up 2 cable modems at the same time to the same router. If you do not have such a set-up I would recommend purchasing a Netgear Wireless-N router for $40 at Walmart, or any store really. The Dual Wan routers can be finicky at times, and is overkill for any normal use of internet bandwidth.
May 17, 2011 | D-Link DI-LB604 Router (DILB604)
Wireless connection error code 32007
Wireless Router:
  • Try adjusting the "Channel" your wireless router broadcasts on. We highly recommend setting your wireless router to either channel 1 or 11. Be sure to try both channels if the first one you try does not work. This can potentially increase the download speed. For information on accessing your router's settings, click here to select the brand name and model number of your router (if available). (The "Channel" setting is typically found in the "Wireless" section of your router's setup utility.)
  • If adjusting the "Channel" did not work, please review our "Slow Download Times or Errors Received While Connecting" troubleshooting tips by clicking here.
  • Are you using a Netgear brand wireless router? Our expeirence shows disabling the "SPI Firewall" of the router may help the connection. The "SPI Firewall" option is typically found under the "WAN Setup" tab of the router's settings. For information on accessing your router's settings, please click here and select the model of the Netgear router you own (if available).
  • If you are still receiving this error code, please click here for assistance.
    Feb 08, 2010 | Nintendo Wii Console
    No internet access with wireless
    First of all check the DSL cable must be in WAN port of the linksys router. if it is done then do the following.
    Actually DSL modem and Linksys router are conflicting with their IP class. Means DSL and Linksys routers are using the same IP class of 192.168.1.1 or 192.168.0.1.
    You must change one's IP class because both are routers and if they having same class they cant communicate. Unplug the WAN cable of the linksys. open browser and put ip 192.168.1.1 or 192.168.0.1 any one which works for u in the address bar. Username and password hopefully be admin admin or just admin and password blank field.
    when you access the linksys router configuration page then come to LAN configuration. If there IP is 192.168.1.1 then change it to 192.168.0.1 and if it is 192.168.0.1 then change it to 192.168.1.1 Save configuration and reboot your laptop and plug dsl cable to linksys WAN port.
    Hope now this will work.
    Regards;
    Hasan
    Dec 30, 2009 | HP Pavilion dv6000z Notebook
    Router errors
    well if you can login to the router, do so and on the first page you come to you will be able to choose your WAN connection... Here's what it should look like..
    ad520ba.jpg Secondly, you want to make sure your wireless settings are enabled and correct. This next picture should closely resemble what you see but I cant be sure because I dont know if you have version 1 or 2...
    And finally you must make sure your wireless card is set to the correct encryption level to match that of the router... Hope this helps!!
    --Joshua79
    Apr 05, 2009 | Linksys Wireless-G Broadband Router
    Error code 109 D-Link Router DIR 109
    can you connect to the router interface? what does it say the wan status is?
    Mar 09, 2009 | D-Link DIR-625 (790069292637) Wireless...
    Cant get my router to work
    Connect the computer to LAN port one of the router using an Ethernet cable, access the configuration page (ie 192.168.1.254), configure the router as Dynamic IP, Configure the wireless network as (WEP or WPA), Check the IP address of the WAN section.
    Note: If you have an IP address to the WAN section the Internet connection is working, Connect through the wireless network by finding the wireless network name was been created to the router.
    Mar 09, 2009 | Belkin Wireless G Plus MIMO (F5D9230-4)...
    G wireless router
    You should disable the WAN miniport pppoe. SSID is the wireless network name or the signal's name coming from your wireless router.
    After disabling the wan miniport, Right-click on Wireless Network Connection > View Available Wireless Network. If you see several networks listed, highlight your wireless network and click Connect. That should do it.
    Sep 28, 2008 | Linksys Wireless-G WRT54G Router
    Wireless router setup
    is the problem that "nothing coming from the modem to the router"
    if the router has more than one Lan port try the cable from the modem to the router, in the first lan port or the last port.
    if its a wireless problem,ensure wireless is enabled on the laptop and the router,if you set up a security key ensure that it is put into the laptop wireless setting
    sometimes you need to turn on the modem first then turn the router on after a little while to sort the ip address out before trying to connect the laptop, in the first instance.
    hope this is of some help but more info would be good
    good luck
    Terry
    Mar 27, 2008 | Computers & Internet
    Laptop
    the internet cable should be connected to the "Internet" or "WAN" port on the router. Your PC should be connected to one of the regular ports on the back of the router and your laptop can be connected just like the pc, or it can connect wirelessly.
    Then you should be able to see the internet from your laptop.
    Jan 20, 2008 | Belkin (F5D7231-4) Wireless Router
    Computers & Internet Logo
    93 people viewed this question
    David Payne
    David Payne
