Question about Marvel 61WC Wine Cooler
Door handle loose - Marvel 61WC Wine Cooler
Bosch refrigerator door handle is loose
there is only one screw on the handles from what i found out from fixing my loose handle. the bottom of the door handle has one screw. once you loosen that one up then you lift it and it comes out at the top enough to slide the handle out and tighten it.
Aug 03, 2014 | Bosch Evolution 800 B20CS80SNS Stainless...
Inside door handle is loose. how to fix handle on my 2003 kia Sedona mini van?
you need to open the inside door and check for loosing screws or anything that looks loose or out of place
Oct 11, 2013 | Kia Sedona Cars & Trucks
Sub-Zero 601R door handle is loose
My Sub is a 650S. Not sure your handle assy. is the same or not. But each of the 2 attachment points have a small 3/32" set screw on the bottom of each short piece between the vertical handle and the door. These set screws grab onto posts that are screwed into the door. There can be 3 points where the handle can work loose.
1. The set screw(s) have backed out and not holding tightly onto the door studs. 2. The studs in the door are loose and need to be tightened with a screw driver. 3. After loosening the handle via the set screws, when you look back into the cavity vacated by the studs from the door, (pivot handle clockwise past edge of door) you will see a Philips-head screw that secures the spacer to the handle. If the spacer is loose, tighten it with screw driver. Then mount back into door stud and tighten set screw. Problem Solved. Have a beer!!!
Nov 26, 2010 | Sub-Zero 601R
The driver's side outside door handle is loose, toyota celica '95
I assume that the entire handle unit is loose in the body work of the door.
The interior door trim will need to be removed to access the inside of the door to fix the loose handle.
Do not attempt his yourself unless you have some experience in this area.
Take the vehicle to the nearest reputable auto body repair shop and they can easily fix it for you. There could be a breakage on the retaining system on the handle or the retainers may just need tightening.
Typically door handles which have not been subject to damage or abuse will not usually loosen like this. It's possible the door was damaged and the panel repaired and repainted at some stage. If so the door handle may have been removed and refitted in a sloppy manner.
Dec 03, 2009 | 1997 Toyota Camry
Loose handle on door
The door handles mount on hex bolts sticking out of the door, the door handles have key hole inserts that match with the bolts. The door handles are then slid in one direction to lock the handles in place. Removal is the reverse. To tighten the door handle screw the bolt out enough that you can still put the handle over the bolt heads and slide the handle to lock the handle in place.
Apr 12, 2009 | GE Profile Stainless Bottom-Freezer...
Loose door handle
I just FINALLY fixed mine...  Popped little cover pieces off top and bottom of handle with a plastic bread bag tag slid along space created by loose handle (did not scratch finish on door).  That exposed the screws which could be tightened with a phillips screw driver; the cover pieces then snap back on the ends of the handle.
Apr 06, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Door handle loose on 10656542400 kenmore
The solution on the Kenmore 56822 turned out to be very simple:
With the door closed, pull up on the door handle (requires some force). The door handle will slide up, and once it is up, it can be removed by carefully pulling it off of the door. Then the screws holding the mounting lug can be tightened. Place the handle back on the door, and slide it down, and voila, no more loose handle. I am going to put some LockTite on the screw on mine to ensure that it stays tight.
Nov 24, 2008 | Refrigerators
Door handles loose
i have a whirlpool conquest side by side and had loose handles,couldn't figure out.but then i grabbed handle and push in and up,handles slide off you can then tighten bolts then slide it back on.hope this helps.n
Oct 14, 2008 | Whirlpool Gold White-on-White 21.9 cu. ft....
LOOSE DOOR HANDLE whirlpool frige GC5SHEXNQ00
Pulled the handle up to release it from the clips on the door. The screw in the plastic door handle that attaches the handle to the door clip was striped. I used a small amount of J B Weld epoxy to repair and reattach the screw. Realign the handle with the clips and push handle down to reinstall.
Jul 29, 2008 | Refrigerators
Loose Door Handle
There is no adjustment for the door handles.  The brackets are metal pressed and if they become loose, it is recommended that they be replaced.
Mar 25, 2008 | LG LRFC22750ST French Door 22.4 Cu. Ft....
Marvel 61WC Wine Cooler Logo
Top Marvel Furniture Experts
Sal DeAngelo
Charles T Nevin
Charles T Nevin
Joseph Hoffmann
Are you a Marvel Furniture Expert? Answer questions, earn points and help others
