Question about Shop Vac Vacuums
Instructions QSP shop vac pro wet dry 86771-32
Put filter back in canister
MakikiChris
  • 84 Answers
SOURCE: emptying the water from the Shop Vac 925-13 Canister Wet/Dry Vacuum
Stand in front of the vaccuum with the lable facing you, the 2 release levers are on the left and right sides, attached to the motor housing, which sits atop the tank/canister. Pull out and up on the levers, twist counter-clockwise, lift straight up and the motor housing will follow, leaving the tank/canister on the floor.
Posted on Aug 02, 2007
Buffalo12980
  • 625 Answers
SOURCE: my shop vac won't turn back on after emptying
I'm afraid you'll need to take it apart. the switch is mounted in a plastic holder in the top. While you got it apart and without it plugged in, check to see that both brushes are touching the commutator. there should be sufficient spring tension to hold the brushes against the spinning part [commutator] if even one brush isn't making contact it won't spin.
Posted on Sep 11, 2007
Agent Don
  • 310 Answers
SOURCE: Shop Vac 12 wet dry canister
http://geeksquad.fixya.com/ThreadView.aspx?prdid=19255&thid=245090
Posted by Fa Fa on Nov 05, 2007
I'm not certain I have all the parts to my Shop Vac. I have no instructions so I need help describing how it works and a picture of the main parts.
Thanks for any help. Julia Harris
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. I am supplying you with the contact for the Shop Vac Factory Service for owner’s manuals listed below: for the website and the customer service line, but make sure you include the Shop Vac Model # and the Serial # as well. So if you need further assistance, please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://shopvac.com/contact.asp Customer Service 570-326-0502 Phone #
Shop-Vac Corporation Customer Service 570-326-7185 Fax #
2323 Reach Road
P.O. Box 3307
Williamsport, PA 17701
Hours are: Monday thru Friday 8:00 am to 5:00 pm (EST)
Posted on Jun 09, 2008
  • 302 Answers
SOURCE: how do you change the ridgid 9 gallon wet/dry shop
all you have to do is open it up and take the paper filter off and then it's a wet vac. If it has a foam over filter you leave that on
Posted on Oct 14, 2009
  • 447 Answers
SOURCE: Change shop Vac Model LM500 from dry to wet pick
To change from dry to wet, remove the paper filter and install ball float if not already attatched
Posted on May 16, 2010
Where is the circuit breaker on a wet/dry shop vac
There is a thermo fuse in the field winding under the tape. When it overheated the fuse went bad.
Apr 07, 2013 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Is the shopvac qsp 10 for water
yes it is wet and dry cac go to link below for deiails
http://www.shopvac.com/pdf/Shop-Vac-QSP.pdf
Nov 08, 2012 | Vacuums
May 16, 2010 | Shop Vac 925-13 Canister Wet/Dry Vacuum
Can't find manual
ask your local vac shop,they should be abel to get you one. they can help with any questions.
Oct 23, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
How do you change the ridgid 9 gallon wet/dry shop vac from a dry to wet vac? Is it simply changing the hose to the back fitting?
Oct 13, 2009 | Ridgid 9 Gallon Wet/Dry Shop Vac 96882...
Vac doesn't work well after cleaning
check your filter
it the round thing hanging from the middle
you may need to clean or replace your filter
you should never leave the filter in while using it as a wet vac that will ruin it immedatly
Oct 09, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Blowing stuff out the back
It sure sounds like your filter broke. Replace the filters.
May 29, 2009 | Shop Vac 925-09-62 QSP Plus Wet/Dry Vacuum
Bought house. Inherited shop/vac. A bit old, but
If you are going to use the wet vac to remove water, be sure to remove the bag inside the canister first. Also, some wet vacs have an internal float that has to be installed, but that may not be the case with yours.
May 16, 2009 | Shop Vac 584-06-00 Canister Wet/Dry Vacuum
Vacuums Logo
126 people viewed this question
Top Shop Vac Vacuums Experts
Mike
jdthefixer
Are you a Shop Vac Vacuum Expert? Answer questions, earn points and help others
