Question about Zebra S4M Thermal Label Printer
Zebra S4M Thermal Lable Printer Not Printing Correctly.
Hi, ok so when I print the labels somehow the labels (size 4"W x 2"L) start shifting to the right, therefore, causing the barcodes to be cut off. It is really important that we have the full barcode for scanning...can someone please help me figure out this issue?
  • Anonymous Nov 15, 2007
  • rolo34 Nov 21, 2007
    Are you have s4m epl or zpl? What it has firmware version?
This solution for you . label printers
Posted on Jun 11, 2012
    Renaissance:
    An user who is expert in 3 categories / brands.
  • Zebra Master
  • 1,362 Answers
Is the Media guide st corectly?
This link is for a datamax but all label printers are stuctured the same way.
check
http://www.posguys.com/download/88230401_a.pdf
Posted on Oct 26, 2007
  • CheckitRight
    CheckitRight Oct 26, 2007
    check out page 28
Hi I have Zeba printer S4M It is printing from half side
mohd shah521: Adjust the page label size in driver parameters to match the real label.
Roberto Martinez
padrino99@prodigy.net.mx
Aug 22, 2011 | Zebra S4M Thermal Label Printer
Printing Half side of the label,,that mean on Left Side
mohd shah521: Adjust the page label size in driver parameters to match the real label. If this adjust is ok, then the printhead has damage or dirt.
Roberto Martinez
Aug 20, 2011 | Zebra S4M Thermal Label Printer
My printer s4m is printing one side of the label the alignment is far right on the label
Check the size of the label that you are using if you are using label design software. If you are using another software, check your left margin setting. Hope this helps!
Aug 18, 2011 | Zebra S4M Thermal Label Printer
Can't get the Zebra S4m printer to align? How should I trouble shoot this? Sonya
I am assuming you mean misalignment of lable top or start of print moving on label.
check sensor for lable debris.
if OK then perform media calibration:
Enter menu and scroll to ADVANCED
press enter and use password 9999
scroll to MEDIA and RIBBON CALIBRATE
Remove a few labels and remove ribbon
Press right arrow to continue display CALIBRATING PLEASE WAIT.
When complete reload ribbon and labels press right arrow printer will feed approx 39"
printer should now print OK.
Aug 08, 2011 | Zebra S4M Thermal Label Printer
Hi I am unable to print from Zebra S4M.. while printing the configuration it prints but does not print the test page or the label.
There a number of things that can cause that: 1) wrong printer driver was installed 2) cable to printer is faulty 3) wrong port was selected when the printer driver was installed
Check these and let me know!
Jan 20, 2011 | Zebra S4M Thermal Label Printer
I am using a S4m printer to print on non zebra labels, by direct printing ( not thermal paper) I cant get what i'm printing to print in the middle of the page. I have tried every possible setting but I...
You need to make sure the printer is calibrated correctly. If you press the feed key, does one label come out and stop at the gap? Do the labels have a black mark on the back of the liner? This would tell us if the printer is set correctly. (Mark or gap). We need to make sure the labels are loaded correctly and the printer is set correctly. Then we move to driver and software settings. I have 10 years experience working for Zebra, so I will get you the resolution once we determine the current setup.
Oct 16, 2009 | Zebra S4M Thermal Label Printer
Zebra S4M Lable Printer Not Scanning
You might want to check the barcode ratio, bar width, printer speed and printer darkness. I am assuming that you are creating the barcode in some sort of label design package, correct? You either need wider bars, or make sure you have enough quiet zone on both sides of the barcode, so shrinking it might be the solution as well.
Apr 12, 2009 | Zebra S4M Thermal Label Printer
S4m is not printing
zebra s4m barcode printer ,suppose if i print 10 Labels only 2 Label come out balance 8 in memory .then printer comes pause, disply showing paper out /ribbon in/please help me....
Dec 30, 2008 | Zebra S4M Thermal Label Printer
Printing every third labels ---> not evry
You need to take the labels out.
If you are using the labels that have perforations is where you can tear them off.
What you need to do is to
1) Switch off printer
2) ensure that the ribbon is loaded correctly
3) take some labels, feed them through the mechanism till you can see them coming out from the other end.
4) Make sure that the labels are lined up with the alignment mark or sometimes with label printers there is a light.
5)switch on printer and do a test print
May 08, 2008 | Zebra S4M Thermal Label Printer
Printing Round Labels
the issue sounds inpart to be related the set lable length, the printer thinks that the data will not fit on the label and gives the error. also note that the gap sensor is not in the center so the printer will not and can not autodetect the media correctly. you need to tweak the label setup. you could trick the printer by centering the labels over the gap sensor or if you do a autocalibating use the lable size it give you which would be much smaller then 17mm
Nov 12, 2007 | Zebra TLP 3842 Thermal Label Printer
Zebra S4M Thermal Label Printer Logo
809 people viewed this question
Top Zebra Office Equipment & Supplies Experts
Dave Busselle
Level 1 Expert
Are you a Zebra Office Equipment and Supply Expert? Answer questions, earn points and help others
