Question about Sewing Machines
Hand wheel turns half way and won't go any further,nothing appears to be hitting anything
Serger is 30 years old, hadn't been used since 1991. needed oil so I did that. when I used it last and put it away in it's box, it was working. started to sew today and the wheel wouldn't go any further than half way around. wheel goes backward further than forward. seems like something is stopping the rotation but took bottom of machine off to see and can't see any obstruction. was full of lint though and needed oil. I cleaned and oiled but the same thing occurred
  • Sewing Machines Master
  • 12,537 Answers
Did you do a thorough oiing "inside" the machine--like take the bottom or back off, hand rotate the handwheel and apply a drop of "fresh, good quality serger oil" every place where metal rubs against metal?
Posted on Jun 12, 2017
snakehead
  • 1074 Answers
SOURCE: cooker won't stay on
Your rice cooker has a defect from the time you bought it, you should have taken it back while the warranty was still in effect,but if the warranty is still in effect take it back to the supplier.or have a tech look at it, the problem is in the power supply circuit.good luck.
Posted on Apr 24, 2007
  • 323 Answers
SOURCE: Pfaff serger stuck
your needle bar has been pushed up and is out of adjustment. You need to take off the side cover, there should be a screw on the back of your machine holding it on. Remove this screw, and remove the cover.You may have to remove the light assembly to reach the screw on the needle bar. Once you can see the needle bar, rotate the handwheel until you can see the screw on the needle bar. Loosen this screw SLIGHTLY until you can turn the needle bar. Hold and rotate the needle bar back and forth as you push down slightly. This will lower the bar.Lower it about 1/4 inch. Adjust the needles by turning the bar so that they are straight across. Tighten the needle bar screw so that the bar doesn't move. Turn the handwheel to see if the threads will be picked up. If not, adjust until they are. Tighten the needle bar screw tightly,reinstall the side cover ,and tighten the screw. Change your needles.Rethead and sew.
sewman7
Posted on Jun 17, 2008
MNfisherman
  • 11896 Answers
SOURCE: hand wheel won't turn and machine won't work
  • Sewing machine has been run at a low speed for an extended period of time.
  • To prevent overheating, motor power is automatically turned off.
Turn power off and wait about 20 minutes. Safety device will reset, and machine will be ready to operate, If this by chance doesn't work, Here is a diagram of a typical sewing machine. This fuse should be in the back next to the power box or motor564d4f7.gif
Posted on Jan 20, 2009
  • 323 Answers
SOURCE: can't tighten clutch on Kenmore zig zag sewing machine.
The clutch has fallen off the shaft. Remove the very small screw in the clutch release screw to remove the clutch release. Place the clutch(round thing with ears on it) back on the shaft with the center ears pointing towards the outside. Put the clutch release screw back on. Tighten it to make sure it works
properly. Put the small screw back in the clutch release screw and test it again. If it will not tighten or release properly, remove the clutch ,rotate it180 degrees and try it again.This should solve your problem.
sewman7
Posted on Feb 16, 2009
SOURCE: Oiling my Janome Gem Gold
Janome Gem are self lubricating. Silicon is embedded in the gears and releases as it runs. If the machine is put away and not run every so often it will lock up. The hand wheel may have thread caught up around it. The Gems aren't assembled to be dissembled except to change the light bulb.
Posted on Mar 04, 2009
Husqvarna Huskylock 936. Handwheel won't turn, machine hasn't been used in a long while.
A thorough clean and oil would probably do wonders for the machine. These old mechanical machines are dependable but they do need some regular TLC because the old oil dries out and glues things together. I recommend not trying to run the machine until the problem gets addressed because it could damage the motor trying to run parts that are stuck together.
Below is what I've done for old sewing machines that have been neglected. Also, about once a year I perform a thorough clean/oil on my mechanical serger (as well as all my sewing machines). On my serger, I can remove the bottom (because that's how mine opens) and get to the moving joints inside.
Wheel on right side that controls the needle up and down is very tight...
Nov 15, 2017 | Husqvarna Sewing Machines
Cannot turn hand wheel or sew.
Have you checked the bobbin compartment to make sure there isn't a thread-jam there? It can get so tightly snarled that even the handwheel won't turn.
Aug 08, 2017 | Sewing Machines
Sewing machine wheel won't turn, motor whirrs
So it sounds like the motor is working but nothing happens? And the hand wheel works ok by hand but nothing when the motor is engaged.
You've broken a belt. I'm not familiar with the 930, but if it has an internal motor... take it in to have it done. It's way too easy to knock these out of time. Spend the extra cash and have it cleaned lubed and adjusted too.
Sep 06, 2012 | Bernina Sewing Machines
Brother 1034d handwheel stuck
the best thing to do is take the machine in to have it checked.
sergers are nice & very useful, I have a babylock serger with the jet-air
looper threading systerm, and I use it alot when making clothes.
I even used my serger to serge the ends of fabric that I haven't used yet
so the ends won't fray.
Jun 11, 2012 | Brother 1034D Mechanical Sewing Machine
Motor is fine, but won't sew
since the machine has been setting for 20 years, it needs to be serviced
the old grease & oil have probably turned the gunk. the servicing can also tell if any parts are damaged
Mar 18, 2012 | White Sewing Sewing Machines
I have a White serger about 8 years old. I jammed up that it can not go forward or reverse. I can turn the wheel just so far. I rethreaded and cleaned everything. When the needles go down to the...
The moving parts on sergers have very precise settings and minute tolerances. When something prevents the machine from turning, one must be very careful. Try disengaging the knife. If that doesn't help, I would strongly recommend taking it to a knowledgeable repair person.
Nov 10, 2010 | White Sewing Sewing Machines
White w2500 serger - nothing happens when foot pedal pressed
Sounds like it could be wiring - probably a job for a mechanic
Aug 26, 2009 | Sewing Machines
Serger blade is dull
You blade definitely needs replacing. It is something that you could probably do yourself if you paid very close attention to the position of the current blade before removing it and get the new blade lined up exactly the same way. That is the best place to start. Then very carefully turn the hand wheel by hand while the machine is unthreaded. You could even place a piece of fabric under the foot and see if the knife is going to cut the fabric. If all is well and there is no grinding or hitting, you should be good to go.
Feb 10, 2009 | Singer Sewing Machines
White serger
You did not say it jammed from thread or just stopped working.
If it is thread, then you will need to carefully use embroidery scissors with a sharp point or a razor blade to cut at the lump of threads and carefully pull them out with your tweezers till you clear the mess. Use your vacuum to get all bits out of there, being careful and not hitting the loopers. You can knock them out of alignment with thread jams and such.
If it just stopped and you cannot turn the wheel, then it needs a trip to the repair shop, either your dealer or to a sew and vac repair where they know how to service sergers.
Aug 17, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Are you a Sewing Machine Expert? Answer questions, earn points and help others
