Question about Hayward TriStar Energy Solution Variable Speed Pump Control with Pro Logic Interface
Error code hf-04
What does error code hf-04 mean on the led readout behind the front cover of the Hayward tristar variable speed pump control?
3 Suggested Answers
  • 31 Answers
SOURCE: If my hayward pool vac (AquaBug) is always
Probably go for the 2 speed, manufacturers often embellish on the hp ratings of pumps, you will definitely see more energy savings from a 2 speed. Just stay away from hayward, easy to work on for service tech's for break alot. Go with Pentair or Jandy they are worth the money.
Posted on Nov 26, 2010
pctech1
  • 1940 Answers
SOURCE: OP error code. What is wrong with my Hayward pool
OP is the error code for a faulty Temperature Sensor. Try replacing the Temperature Sensor. I have seen many of these units have the wires chewed up by mice, etc., so you may want to check the wiring for any damage.
Posted on Jun 24, 2011
HF code on hayward 200fdn pool heater?replaced gas valve still have same code.What now?
HF
Flame present with gas valve "OFF" error
If flame is sensed with the gas valve off the control will go into lockout. The blower will run until error condition is corrected. When corrected, control will run blower for 5 s then automatically restart after 2 minutes.
the error might be caused by a faulty flame sensor. i have heard of this happening the other way (carbon blocks sensor causing no ignite)
Jul 06, 2014 | Hayward Pool & Spa
Error code
make sure water filter is CLEAN ! this will throw a code
Jun 22, 2013 | Hayward H-series Electronic Gas Pool...
Stops about half way thru cycle anf error code HF appears
F/H No water detected entering machine or Pressure switch trip not detected.
If after 30 seconds the control does not detect water entering machine and then valves will be turned off and the error code will be displayed.
Or
If the control has turned the water valves on and after 8 minutes the flow meter has detected 10.5 gallons of water passing through it, but has not detected the pressure switch trip, the valves will be turned off and the error code will flash.
Press PAUSE/CANCEL twice to clear the display.
If there is no water in the unit:
1. Make sure that both valves at the water source(s) are turned on all the way.
2. Check for plugged or kinked inlet hoses or plugged screens in the inlet valves
3. Verify inlet valve operation
If there is water in the unit:
1. Verify Drain pump operation
2. Pressure Switch Hose is in good condition and properly connected to Tub and Pressure switch
Verify there is not a siphon problem
Verify wire harness connections to:Inlet Valves, Pressure Switch, Drain Pump, Flow Meter, and Central Control Unit (CCU)
Check all hoses for possible leaks
Verify pressure switch operation
Verify flow meter operation
Verify CCU operation.
Nov 21, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Error code HF
Or
Oct 09, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Hayward TriStar Energy Solution Variable Speed Pump Control with Pro Logic Interface Logo
32 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
