Question about Air Intake Hose Holden Vectra 2 Gts Hump Bellow 3 25-3 5 Inch Od
Intermittent brake failure
Twice in the last month the brake pedal on my 2004 vy acclaim II has gone to the floor resulting in no brakes for approximately 15 min then has come good
    Novelist:
    Champion:
  • 239 Answers
Any leakage? If not, then I might be looking to a vacuum hose leaking, which will cause a low pedal effect. This is a serious issue and should be attended to by a qualified ASE mechanic right away.
Posted on Nov 24, 2014
I have a 2005 gmc envoy and the pedal brake was too hard en i did change the calipers , brake hose lines and power booster , and for few weeks still doing the same and now i have brakes but the some yimes...
Usually a hard brake pedal is the brake booster. Since you replaced that it is out f the picture (unless the replacement was bad). This issue of the pedal going to the floor is troublesome and potentially dangerous. If it is not doing it all the time, it probably soon will. What most likely occurred, and this happens quite often, is that after having had the hoses and calipers replaced, it was necessary to bleed the brake system of air in order to get proper brake operation. This requires depressing the brake pedal numerous times to the floor while purging air from the system. There is a potential problem in this and that problem is that the o-rings in the master cylinder can be damaged by the bleeding process, because the normal stroke of the master cylinder is much shorter than the one used during bleeding. This sometimes results in o-ring damage because the master cylinder bore may have worn a ridge in it where the normal stroke ends. The repeated passing of the o-rings over the ridge will damage them and can cause them to fail. When this happens the pedal will drop to the floor. You really can't blame the mechanic for this but it most likely happened as a result of the work done. Have the master cylinder replaced ASAP. I wouldn't recommend using the vehicle at all in the meantime.. it is a pedal-press away form total brake failure at any given moment.
Mar 19, 2015 | 2005 GMC Envoy
Sudden soft/spongy brakes 2001 ml430
once should have been enough to get it fixed
indicates a master cylinder failure
go to a brake specialist shop for a proper diagnosis and quote
the master is probably original and is well past a replacement maintenance period
Dec 02, 2017 | Mercedes-Benz Cars & Trucks
2000 silverado brake work good 90% of the time, but the odd time the pedal goes to the floor, and in the last second the abs kicks in. Then they work good again for a while. Could it be the booster, I...
may i suggest your problem is the brake master cylinder is faulty ie the line pressure is being lost due to fault on seal that is supposed to maintain brake pipes/line pressure when pedal is off resulting in brake pedal intermittantly going to floor but if you pump pedal it comes back ? the fact you mention you drained master cyl ? reservoir ?? and fluid was dirty ? assume you bled all brakes to flush b/system too ? the fluid being dirty is a clear indication that the seals on m/cyl pistons are deteriated and allowing fluid to pass seals and cause pedal to travel further SO best advice is to replace the master cyl as repair kits/seals are hard to come by these days then use new fluid and bleed all brakes/cyl's hope this helps ?
Apr 15, 2010 | 2000 Chevrolet Silverado
Brake pedal makes grinding noise and bleeds off
double check fluid.you have air or are losing hydrolic pressure somewhere. leak in master cylinder can do this. also vacume and air leak in the booster unit. double check bleading points on each wheel.
Mar 11, 2010 | 2004 Pontiac Grand Prix
Intermittent problem with brakes, sometimes the
your vacuum brake booster is gone... not cheap;... the big black thing under your hood and in front of the drivers side steering..
Feb 27, 2010 | 2004 Chevrolet Silverado
Brake pedal going to floor somtimes,could this be anything to do with rear brakes
I don't know about the rear brakes, but it is the brakes!!! You are out of fluid, might have a leak, get the reservoir filled up, and check all the wheels on the inside for brake fluid leaking. If the pedal has gone to the floor, you will need to bleed the system, Just get 2 people, one to loosen the bleeder on each wheel, and one to pump the pedal, Get a short hose and a can to catch the oil in. Loosen the bleeder screw, let the pedal go down, don't remove pressure till you tighten the screw back up, pump it up again, and do it till the pedal comes back to normal. Every wheel.
Feb 12, 2010 | 2004 Kia Sedona
Brakes are gone
check ur brake lines for posible leaks. also make sure to bleed your brakes after you put fluid into it or else the air won't come out of the brake lines causing ur pedal to still go to the floor
May 27, 2009 | 1998 GMC Blazer
Brake peddle goes to the floor intermitantly.
The problem may be that the master cylinder needs to be bench bled,there is most likely air trapped in the piston of the master cylinder.The problem comes from the piston not being fully actuated when connected to the pedal assembly.A vacuum bleeder will generally pull it out.
May 25, 2009 | 2004 Dodge Ram 2500
Anti lock brakes
Well this is very serious I hope you deal with it right away. You mentioned that sometimes the pedal was hard,do you mean that its all the way up and it doesnt feel like you have power brakes?? If so have you noticed any sounds like air escaping (swoosh sound when brakes applied)? Failure of the power booster causes pedal to become very hard and could possibly be your problem for hard pedal if I understood you correctly. check to make sure that vacuum to the booster is conected properly and hose not kinked..Now for the solution for the pedal fading to the floor... You either have air in your brake system, A bypassing master cylinder , or a hydraulic leak...Were your brakes serviced recently?? if so try bleeding your brake system first...That would be the first step if still the problem persist I would isolate exactly where the problem was coming from.. To do this you would start at the passenger rear wheel and line clamp the brake hose to make that part of your brake sytem inoperable...when clamped try your brakes and note if brakes improved or had know affect on system (when testing obviously im not suggesting you drive to determine results of test procedure)repeat test for each wheel you have isolated the problem when brakes feel normal with one wheel clamped,which ever it may be.. This isnt as hard as it might soun and if you are confused at all dont hesitate to ask questions... Remember the only dumb question is the one you fail to ask I would hate for you to get into an accident ... Good luck!!!
Dec 27, 2008 | 1994 Pontiac Grand Am
Air Intake Hose Holden Vectra 2 Gts Hump Bellow 3 25-3 5 Inch Od Logo
53 people viewed this question
Top Magnum Tuning Vehicle Parts & Accessories Experts
baire
jim
Level 1 Expert
mekanik84
Are you a Magnum Tuning Vehicle Part and Accessory Expert? Answer questions, earn points and help others
