Dear Sirs, Whether EPSON LQ 570+ could print automatically more than one page if put together in the slot. I haven't found the answer in the Manual. Usually I print more pages one by one. If possible, pls explain how to do that. Kindest thanks, Karezic E-mai : [email protected]
SOURCE: EPSON LQ 1050+ printer; OS Windows XP, How to Print long pages of 24" length
My LQ1050 is cutting off text at the bottom what could be the problem please help?
SOURCE: Epson LQ-2180 continuous printing problem
An Emulation driver will fix everyones problem... Do this:
1. Click on "Start", then "Control Panel" and then "Printers and Faxes".
2. In the left hand column choose the option "Add Printer". The "Add Printer Wizard" comes up, click on "Next".
3. At the "Local or Network Printer" screen choose "Local" and remove the check from "Automatically Detect".
4. Click on "Next".
5. At the "Select Port" screen choose the appropriate port (usually LPT1: recommended printer port).
6. At the install printer software screen choose "Epson" under "Manufacturer" and LQ-1050 for the printer, then click "Next". If you wanted to install the Windows universal driver, choose "generic" under "Manufacturer" and choose "Text Only", then click "Next".
7. At the printer name screen choose "Next".
8. When asked if you would like the printer to be default make the appropriate selections and then click "Next".
9. Finally click on "Finish". You may need your Windows XP installation disk.
SOURCE: EPSON LQ - 2180 paper settings
I HAVE CUSTOME SIZE OF PAPER WHICH IS NOT AVILABLE IN THE PRINTER LIST .WHEN I DEEL WITH WINDOS XP
BUT WHEN DEEL WIHTH WINDOS 98 ITS OK
NO I DONT HAVE WINDOS 98 . MY QUESTION HOW I CAN ADJUST PAPER TO CUSTOM SIZE
SOURCE: printer Epson LQ 2090 ask to insert paper for every pages
Please take note of the paper used. Letter Size A4 or custom. This can be set on the PC (Mac or Window). If not you may just reset the hardware by holding the 1st and 3rd button and then power on. You may hear a beep sound after resetting. Good luck
