Question about Gear Head Mouse
Wireless mouse not scrolling
Light on wireless mouse, not scrolling
Tip
Tips to Choose a Wireless Mouse
A wireless mouse is better to use a mouse due to the lack of cables. With the use of it, mobility is doubled. This type of mouse is a relatively recent invention, however, many people already use. If you also want to have one, consider these tips before buying a wireless mouse:
The budget must be considered first. It 'important to look at what you can afford to avoid financial difficulties.
scroll wheel is between the two mouse buttons, left and right buttons. It is sometimes called the third button. It is used to scroll up and down.
Tilt wheel and scroll wheel can scroll up and down, the tilt wheel scrolls sideways.
Functions shortcut. Some wireless mice are very easy to use because the options they have shortened.
Serving Size-mouse Looking for a small, medium or large? What is easier to use and can be easily manipulated?
Design-The mouse that you should buy should match the design team to add beauty. In addition, proper design is pleasing to the eye.
Style Many wireless mice are sold with many different styles. Choose the one that will complement your tastes and fashions.
on Jan 16, 2011 | Computers & Internet
Logik wireless mouse
1. Make sure the mouse is fully charged. The underside should have a red flickering light if it is working properly. If not you need to change the batteries.
2. Plug the USB dongle into the computer. The blue light should light up and flash rapidly as you move the mouse around. If it still doesn't work you need to re-sync the mouse with the dongle.
Turn the mouse off and back on again. Hold it near the USB dongle.
Push the blue button on the dongle. It should flash steadily. Push the reset button on the bottom of the mouse. The blue light on the dongle should start flashing rapidly and your mouse should now work.
Jul 30, 2014 | Case Logic EW-609 3-Button Wireless...
HP 2530p EliteBook - touchpad stopped working. Scrolling works except touch scrolling on right side of pad) and right button, but that's all. Wireless mouse works fine.
To access Mouse Properties, select Start - Control Panel - Hardware and Sound -Mouse.
Use Mouse Properties in Windows to customize settings for pointing devices, such as button configuration, click speed, and pointer options.
Jan 18, 2013 | HP EliteBook 2530p Notebook
I have a dynex wireless optical mouse but my laptop will not recognise it
Have you installed the driver for the mouse? Did you install it before actually attaching the mouse's USB receiver? The driver should be installed first. You can download it here:
http://www.dynexproducts.com/productSearch.html?query=wireless+optical+mouse&mainSearchButton=
Scroll down to "Dynex Wireless Optical Mouse" and click on "English" next to "Driver:" in order to download it.
If you've already installed the driver and your computer still won't recognize the mouse, press the Connect button on the receiver, wait for the light to flash, and then press the Connect button on the mouse. The light should stop flashing and the mouse should be ready to use.
Nov 23, 2009 | Dynex Wireless Optical Mouse
Wireless Mouse
Have you changed the batteries recently?
Normal 0 Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
If it’s a wireless GE mouse turn it on by pushing the button on the bottom and hold till the red light comes on. Assuming the computer is running, press the Blue light on the Receiver and then, press the button on the bottom of the mouse and it should start tracking on the monitor.
Hope this helps. Bud
Aug 27, 2008 | GE Wireless Optical Mini Mouse 3087897985
Inverted vertical scrolling
did u download latest driver form website maker site dont use cd
Jan 28, 2008 | Microsoft Wireless Laser Desktop 4000...
Gear Head  Mouse Logo
102 people viewed this question
Top Gear Head Computers & Internet Experts
micky dee
Are you a Gear Head Computer and Internet Expert? Answer questions, earn points and help others
