Question about Nike Triax Watches
Reset after battery replacement - Triax Nike Watches
How to place the back on
It is highly recommended that you take it to a jeweller's to replace the battery. If the battery is replaced you need to reset the watch by push/short internal reset switch after replacing battery.
Oct 14, 2015 | Timex Mens T2N723 Intelligent Quartz...
My g shock ga 100 keeps resetting itself back to 12:00 and the analog doesn't stay synced to the digital i have had a new battery fitted and it still doesn't work any suggestions ??
Did you take your Casio to a pro or it was just a normal battery replacement service?.
I am asking because if a pro did it seems he forgot to reset your Casio watch when battery was replaced.
This is a must when you change battery on a Casio digital watch.
Take it again and ask for a complete reset, if they know what they are doing they will do as you ask without questioning.
Casio Watches
Jul 02, 2014 | Watches
The second hand was delayed by 2-5 seconds and then it quit altogether. I read that this meant that the battery was dead, so i got a new battery and replaced it. After replacing the battery the watch still...
You do not give a model number for your Wittnauer Montserrat. It does sound like it needs a reset - generally this is making an electrical connection for a few seconds between the positive terminal of the battery and a reset contact point on the watch movement - a pair of fine point tweezers is ideal for this.
HOWEVER - without knowledge of the movement used in this watch, this is just speculation.
Oct 14, 2017 | Wittnauer 10D02 Montserrat Watch for Men
Hello ,,, I changed the battery in my Timex Indiglo and now just the light is working but not the minute hand or time hands. How do I fix this I have tried two batteries already?
Inside the battery compartment, you will see the battery is held down by a clip. Carefully remove the clip and eject the battery. Insert the new battery and replace the clip. If the battery clamp indicates you should do so, quickly press the reset button twice. Then reattach the back of the watch. If the watch display remains off after replacing the battery, press all buttons at the same time to reset the display.
Jul 23, 2010 | Timex 27191 Wristwatch
How do I reset my Casio PRG-40 following battery replacement?
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all CASIO watch manuals. Rate me, please .
Apr 08, 2010 | Casio Protrek Triple Sensor Tough Solar...
Won't reset to zero (60 sec.) after battery was replaced
You need to "Reset" the watch's computer, this is done by removing the case cap, (Same as battery replacement) Look for a imbosed "RESET" and using a paperclip, Push gently in the reset hole for five seconds, Remove the paperclip, You should then have all funtions restored to "Factory Settings"
May 20, 2009 | Casio Watches
How to replace battery for Timex expedition
Remove the four screws that hold the battery cover on the back of the watch. Remove the 3 very small screws that hold the battery in place. Remove the battery from the battery holder. The piece that the 3 small screws were removed from seperates from the 3 volt 2016 energizer battery. Replace the battery with a new one. Re-install the battery holder to the watch. There is a small tab on the lower left part of the battery holder that needs to be depressed to activate the watch. Depress it and look at the face of the watch to make sure it is activated. The watch will need to have the time, date etc reset but you should now be able to see that the battery is working. Replace the battery cover and reset the time and date as needed.
May 12, 2009 | Timex Expedition 84601 Wristwatch
Timex rush new battery reset
good morning ! you need to use the pointed twisser to short the two reset pad ! thanks !god bless !...
Sep 02, 2008 | Timex Rush Sports Watch
Battery change and then reset
If you open already the watch,and you want to take the old battery,there is a clip that's lock the battery twist that lock.then the battery comes out and replaced with a new one. If you have already put the battery and no display you must reset it by shorting battery connection,in the plate there is arrow guide to the hole where you put your tweezers to short the connection.then the display appears 8888,that is already resetted take the tweezers..
click below for video guide;
G-ShockBattery Change Tutorial
hope this may help
DON'T FORGET TO RATE
Regards,
VOTIT
Jul 29, 2008 | Adidas Watches
Resetting Watch
Here's the inside of my Timex Expedition Dive watch. To reset the watch after replacing the battery, press down with a small screw driver on the metal tab that the red arrow is pointing to.
Nov 20, 2007 | Timex Expedition 84601 Wristwatch
Watches Logo
65 people viewed this question
Top Nike Watches Experts
Ansel Alberto
Ansel Alberto
TIME TRACK SERVICES
TIME TRACK SERVICES
Are you a Nike Watch Expert? Answer questions, earn points and help others
