Question about Jenn-Air Ovens
Touch pad not working
Some buttons work A flash when it starts
5 Suggested Answers
localwonder
  • 6784 Answers
SOURCE: GE JKP27WP1 Built-In Double oven
Try gaining access to the touch pad and, try to free up the start button. if this is unsuccessful, replace the touch pad.
Posted on Jun 20, 2009
SOURCE: touch pad does not work and flashed FO
this happened to us when we had a power surge. The following instructions fixed our oven!! however, the next month we experienced another power outage and it did not work and the Sears repair man said we need to replace the Oven Control ($300) and the Sub Panel ($300) good luck! Joanne
FO CODE ON STOVE. HOW TO RESOLVE:
  1. Turn power off to the oven by flipping the circuit breakers off to oven for a few minutes then power back up.
  2. Press Bake and Broil keys simultaneously.
  3. Press Hour Down and Minute Down keys simultaneously for 5 seconds.
  4. Wait approximately 20 seconds after the time of day is displayed.
  5. Press the Temp Up and Minute Up keys simultaneously.
  6. The control will briefly go blank, briefly display all LED segments, briefly display LOC REF, then display all segments for 30 seconds, and finally display LOC REF.
  7. Press Hour Down and Minute Up keys simultaneously.
  8. The control will then display the time of day and operate.
http://www.managemyhome.com/mmh/answers/Answers.action#l4q126596
Posted on Aug 20, 2009
  • 523 Answers
SOURCE: Touch pad for the oven does not work
eith touch pad or control board un plug the touch pad if it returns the board is bad if it dont the touch pad is
Posted on May 27, 2010
  • 1416 Answers
SOURCE: oven beeps with f7 code , replaced display pcb .
hello,
(indication of problem)
This error code on a oven indicates a keypad short on the Electronic Range Control (ERC) board. This is the clock/timer on the operator console. The recommended fix is to replace the ERC. You can generally find replacement parts at these websites:
searspartsdirect.com pcappliancerepair.comappliancepartspros.com repairclinic.com
All these sites offer great service with competitive pricing, so shop and compare.
Replacing an ERC is not a difficult repair and can be accomplished by the average do-it-your self offer. If you decide to order the part and wish to repair this on your own, follow these steps:
1. UNPLUG the range. Dangerous voltage is still present inside even with the range turned off.
2. Pull the range away from the wall and turn the unit around so you can access the rear panel.
3. Remove the screws on the back of the operator console.
4. Carefully disconnect the connector plugs to the ERC. Take note of how they are connected, so that you can reinstall them correctly.
NOTE: The connectors are usually color coded with the colors printed on the circuit board. However, if the colors are not printed on the board, write them down. (A digital camera also comes in real handy for this).
5. With the connectors removed, remove the mounting screws to the ERC and the assembly will come out.
NOTE: Most replacement ERC boards do not come with the overlay. This is the plastic pre-printed number display. The overlay can easily be peeled off and re-used. Just make sure you properly orient the overlay so that you don't inadvertently place it on the new board upside down. If your existing overlay is damaged, you will need to order separately.
6. Install new ERC using the steps provided in reverse order. Minimize handling the new circuit board with your bare hands to avoid damaging the board.
I hope this information helps you.
thank you for using fixya.
Posted on Oct 03, 2010
The start button doesnt work, but all the rest do, What can it be?
Its a very common occurence for certain buttons to work on the touch pad yet others dont work.The only fix is to replace the touch pad.
Gene
Jul 30, 2011 | GE JKP30CMCC 27" Built-in Single Electric...
F-7 code has been flashing, along with constant beeping. This has happened about 5 times over the past 2 months. Eventually it stops but now we resort to flipping the fuse off to get rid of the noise. ...
Hello Marylou,
The F7 code means the same thing on all domestic (USA) brand ovens.What is means is that a button on the touch pad is shorted (welded together) out. Since you did not include brand or model#
i will give you the following advice, if your touch pad is a seperate part that plugs in clock (also called the oven control,or eoc..electronic oven control) then just the touch pad can be replaced,on certain brands or even some models within a brand the touch pad is integrated into the clock/oven control or eoc in that case the complete touch pad/control asm. is what needs to be replaced
Hope this helps and if it does please give me a 4 thumbs up rating
Gene
Jul 29, 2011 | Ovens
Worked fine all of a sudden it is flashing and beeping F-7 ??? wont heat up
F7 Function key shorted or stuck button Clean and un-stick button or replace Touch Pad or Clock. So first try checking the touch pad buttons.If any of the button got internally stuck then its the cause of error.Release the button and see if that helps.But if all button looks ok then its faulty touch pad causing this error.It has to be replaced. ----------------- You can get required part from www.repairclinic.com ------------- Thanks.Helpmech.
Jan 07, 2011 | Magic Chef Ovens
May 27, 2010 | GE Profile JTP56 Electric Double Oven
I HAVE A MAYTAG BUILT IN OVEN THAT WAS WORKING FINE LAST NIGHT AND GET UP THIS MORNING TO BAKE AND I AM GETTING, ITS FLASHING A F2 AND F7 ERROR CODE AND THE ALARM OR BEEPING IS GOING OFF
Hi You have a bad touch pad , there maybe a be a button stuck in , try running your fingers over all the touch buttons but i think the touch pad will need to be replaced as always remove the power before taking it a part
Dec 21, 2009 | Maytag CWE4800A Electric Single Oven
Exactly the same problem. My oven is 11 yrs old instead of 10
All F3-E Codes - Oven Temperature Sensor (RTD) or Warming Drawer Defect - Replace oven temperature sensor (RTD).
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 28, 2009 | Kenmore 40494 / 40495 / 40499 Electric...
F1 error/touch panel not working on GE Monogram Dual Oven
Usually, the F1 means that either the touch pad or the oven control (also called clock or ERC) is defective and needs to be replaced. If this fault code cannot be canceled, replace the oven control (also called clock or ERC), touch pad, or both.
I recommend a service call for this repair.
Jun 02, 2009 | GE Monogram ZET3058SHSS Stainless Steel...
GE JKP27WP1 Built-In Double oven - the start button on the touch pad doesn't work. Everything else works fine. Haven't received an error code.
Dec 16, 2008 | GE JKP27 Electric Double Oven
Touch Pad issues JT952-30
Hi richard..
the ribbon connector that connects the touch pad to the control may not be correctly connected. you may try to remove and reconnect it... be sure to have the power to it turned off..if the is not the solution the replace the touch pad...
Aug 16, 2008 | GE Profile JT952 Electric Double Oven
Jenn-Air WW30430W double oven flashing F7 and beeping
It seems you have a stuck button. Here is a list of fault codes:
JENN AIR
Range/Stove/Oven Fault Codes
Failure
Code
Condition Check/Repair F1 Defective touch pad or membrane Replace touch pad or membrane (this problem is usually the touch pad) F1 Watchdog on board Replace touch pad or clock assembly (also called the ERC) F2 Oven too hot Replace relay board (if present) or oven temperature sensor F3 or F4 Open or shorted oven temperature sensor Replace oven temperature sensor F5 Hardware and watchdog circuits disagree Replace clock assembly (also called the ERC) F6 Missing AC signal Check for proper voltage F7 Function key shorted or stuck button Replace touch pad or clock assembly (also called the ERC) or attempt to un-stick button F8 Analog/Digital supervisory Replace clock assembly (also called the ERC) F9 Door latch supervisory Check door lock circuit or replace clock assembly (also called the ERC) F0 Function key stuck Replace touch pad or clock assembly (also called the ERC)
Dec 09, 2007 | Jenn-Air JJW8530C Expressions Collection...
Ovens Logo
12 people viewed this question
Top Jenn-Air Ovens Experts
 Fix Your Board
Fix Your Board
Dan Webster
Dan Webster
Are you a Jenn-Air Oven Expert? Answer questions, earn points and help others
