Question about Refrigerators
GE bottom freezer PF22missaww i came home from vacation and it was at 60 degrees , unplugged it for 10 minutes and plugged it back in , ran fine for a month , came home from work and the unit is warm again . power is on and no power failures in the home. lights are on inside when i opened the door and digital disp[lay was reading the same temp as the room temp . unplugged it again for 2 minutes , re plugged it in and its blowing cold air .
  • 6 Answers
GE Profile bottom freezer erratic.
GE Profile Bottom-Freezer Refrigerator with Electronic controls with digital temperature readout (Should include Models PDS20MFS, PDS20SFS, PDS22MFS, PDS22SFS, PDS22MFS) May also apply to other models.
Diagnosis: Search of Internet yielded no definitive fix. It appeared to me that the some minor frost buildup might be symptomatic of unseen frost elsewhere. The electronic controls could possibly be messed up.
Fix: Not knowing whether it was frost or the electronic controls (or both), did the following:
1. Turned off the refrigerator. (It is not clear how to do that. Download the owner's manual for your model from the Internet. If it is like mine, the freezer and refrigerator APPEAR to have separate controls. In fact they are linked. To turn both freezer and refrigerator off, press the WARMER button on EITHER the refrigerator OR freezer until the display shows OFF for both the freezer and refrigerator.)
2. Unplugged the unit. Let it set for 18 hours with both doors open.
3. Plugged it in (which may have reset the electronic controls.)
4. Turned it on. To do so, I followed the instructions that said to press the COLDER button on either the refrigerator or freezer. Press the same COLDER button a second time and it should go to the factory presets of 0 degrees for the freezer and 37 degrees for the refrigerator.
5. Allowed the temperatures to stabilize for a week, after which temperature adjustments can be made.
Posted on Jun 25, 2017
2 Suggested Answers
Sea Breeze
  • 4655 Answers
SOURCE: blows warm air, unpluged it for 2 days plugged back in blew very
Either the start relay and start capacitor or the Adaptive Defrost control is burned out. If you have a voltage meter we can test a few things like the compressor and the capasitor. The part number for the Adaptive defrost is 241508001 and found inside the fresh food compartment behind the control panel. I can help you locate the problem if you like. Let me know, Thanks, Sea Breeze
Posted on Jul 18, 2009
Why is the refrigerator section not cooling?
Sounds like a defrost problem,either bad defrost heater or bad defrost thermostat
Jul 07, 2015 | Electrolux EI28BS56IS (278 cu ft) Bottom...
GE profile bottom freezer model # PGSS5NFXA SS. Got up this morning and freezer thawing. Pulled back panel cleaned the condenser fins with compressed air andchecked the connections. runs fine but can'
I had this happen with my fridge when the door was open for awhile when I was cleaning the inside. I did what you did, clean everything behind it. Pay particular attention to the circuit boards, there may be reset buttons in that area. Then unplug the freezer for 10 minutes (make sure it's for a FULL 10 minutes) then plug it back in and try it.
Feb 03, 2015 | GE Refrigerators
Refrigerator stopped cooling
the problem is in your freezer !
open the back wall of your freezer and check if the fan working then if you see a big build up of ice. then its your heater unit or your heater thermostat. to check that it is the problem unplug the unit defrost the freezer coil with hair drier gently and when it done plug it again and see if your fridg get cool (1h or 2) then you know its the heater unit or the thermostat :(
911servicetoday .com
Jan 01, 2010 | Whirlpool ES5FHAXS Side by Side...
GE Profile PFSF5NJW French door Bottom freezer. Freezer is fine. Refrigerator at 60 degrees. Unplugged for two days to thaw any possible freeze up. Refrige still at 60 degrees.
If that is what happened after plugging back in still no change in temperature I recommend you call someone you can trust. Trust is about asking too much these days. You refrigerator does not need to run at all until I or someone can find the problem. If someone there would like the challenge and knows how to use a multi-meter let me know. Thanks, Sea Breeze
Nov 21, 2009 | GE Profile PFSF5NFW Bottom Freezer French...
Frigidaire FRS26R4CW1, buzzes. When I noticed that the freezer was warm the unit was unplugged. The refrigerator was left unplugged for about 20 hours. When it was plugged back in it was ran, was quiet and...
Yes, what you are asking is possible. It is also possible that the compressor motor has a flat spot or is even siezing up when hot. If you are comfortable changing the cap. then I would do that first a see what happens. Changing the compressor will be much more costly and maybe more than you want to put into you refrigerator.
Nov 17, 2009 | Refrigerators
The freezer and fridge temperature has been raising 1 degree per hour all day. The unit is 2 1/2 years old. any thoughts on this?
i've never heard of this, um, try unplugging it for a couple of minutes then plug it back in. not sure if it will do anything but it wont hurt to try it.
Nov 15, 2009 | GE Profile PFS22MBS Bottom Freezer French...
Back wall freezes up on freezer side while fridge side is too warm. fridge temperature stays between 60 to 70 degrees
Is the freezer fan working ? If not , control board probably bad . Pull refrig out from wall and remove power . Remove the 8" X 10" panel and you will see the main control board . Remove the blue plug with 3 larger wires . The sequence is : wire1 , wire2 , space , wire3 . Using a short piece of wire with both ends stripped about 1/4 " , insert the wire into wire2 and wire3 . Plug refrig back in . Look in the freezer at the bottom rear for a red glow ( may take a minute or so ) . If you see a red glow , the main control board is bad ( the board you unplugged the wires from ) . If no red glow , then disconnect power to fridge , remove the jumper , and reinstall the blue plug and the panel .
Remove the food from the freezer section and remove the rear freezer panel inside the freezer . There you will see a round 1 " disk , clipped on top of the coils .Pt # WR60X10068 Defrost thermostat . At the bottom of the coils , you will see a heater . Pt # WR51X10042 Defrost heater . Replace both of these as the heater gets hot , and cuts off by the bimetal . he heater only has a screw on each side attaching it to the coils , and the bimetal just clips on . Easily repairable .
Aug 29, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Internal temp of fridge and freezer are different from bottom top
Hi, Is the evaporator fan motor running in the freezer? Was the fridge setting any length of time unplugged before you got it?
May 10, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer temperature is not consistent
No recall that I have on my listing for that model. Keep in mind that the refrigerator goes into a defrost mode that lasts up to 30 minutes. It happens anywhere from 10 hours to 60 hours of operational time. When this happens, it's not uncommon to see 20 ° temperature. If you check it again an hour later, it should be back under 10 °. Also, double check to be sure the condenser coils are really clean. That alone can also cause this sort of symptom.
Oct 24, 2017 | GE Refrigerators
Freezer works refrigerator doesn't
Try finding the defrost timer and slowly click by click turn it just until the compressor stops. let it finish the defrost cycle. Let it run for about 3 hours then do it again. Sometimes if the frost builds up too much the defrost system can't handle it. If you can't find the timer, take out the food, unplug it and leave the doors open for at least 24 hours. Then plug it back in. It can take up to 10 hours to cool down completely. Use a thermometer. you should be around 38 degrees in the fridge and between 0 and 10 degrees in the freezer.
Jul 04, 2008 | GE GBS22HCR Bottom Freezer Refrigerator
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
