Question about Cozy Heating & Cooling
Pilot light keeps going out jazz Rocco gas fire
    Top Expert:
  • Cozy Master
  • 52,099 Answers
Pilot orrifice might need cleaned
Posted on Jan 08, 2015
  • 10 Answers
SOURCE: pilot light
Pilot orifice may be clogged. Remove pilot tube and orifice. Blow out orifice with compressed air only and reassemble. Also, control valve may be bad.
Posted on Feb 05, 2009
Therinnaiguy
  • 1420 Answers
SOURCE: my gas furnace pilot light goes out after reaching
The room air blower should have no effect on the pilot unless there is a crack in the heat exchanger. Do you notice a change in the pattern of the main burner flame when the blower turns on? If so, you have major issues. If not, it could be a dirty pilot orifice or a weak thermocouple.
Posted on Jan 14, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Pilot light keeps going out on furnace. Ruud gas furnace, (20+)
When a pilot lite habitually goes out the thermocople has failed. The are pretty cheap. If you remove yours and go to a local applicane parts center they can provide you with one the same lenght as your current one for a much cheaper price than a plumbing and heating source. In the process of changing the thermocouple when you disconnect it from the gas control valve take a Q-tip and clean the mating area as best you can. You can try cleaning that mating area before changing the thermocouple first. You might just get lucky and not have to buy a new one.
This is not a hard task. It is a bit tedious to get to the area near the flame head but I am pretty sure you can do this. Just make sure the new thermocople is positioned like the one you removed.
There is a very very remote possibility that the gas control itself is failing but I doubt it. You still would have to change the thermocouple first in order to troubleshoot.
Thanks for using FixYa.
Kelly
Posted on Mar 27, 2010
  • 192 Answers
SOURCE: I have a Williams model # 2509612 wall heater. I
Remove your pilot assembly and remove the aluminum gas line going to it. Be careful when you take this off because there is an orifice inside of it that may or may not fall out. If it don`t fall out remove it. In the top of are a couple really small holes. Make sure they are clean. Also again clean the pilot hood of all debris. Reassemble everything and it should work fine. If not buy a replacement pilot assembly because I have had some that i couldn`t get clean enough not matter what I tried. Doesn`t happen often but does happen. New assembly always fixes it but a good cleaning usually does it.
Posted on Feb 03, 2011
emissionwiz
  • 80407 Answers
SOURCE: My gas fire keeps going out soon after turning it
This problem is caused by a defective gas supply valve.
Posted on Oct 28, 2011
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Relight combi pilot light?
These are designed not to light once the thermocouple fails.the thermocouple has a small wire that positions in to the pilot light which checks the pilot is on and keeps the gas governed.once the temperature drops it shuts off the gas to prevent a build up of gas in a room where a pilot light has gone out.this is why you need to hold the button in on reignition to allow the thermocouple to heat up so the gas keeps open.
Try to relight by turning on the gas ....pressing down and holding the button for at least 10 seconds whilst firing the piezo to ignite flame.do not release gas button for at least 10 seconds then slowly release.if the flame on the pilot will not stay alight....then it is likely the thermo has failed.try cleaning the metal wire that is above the pilot jet.still no joy then it needs replacing.hope my comment is of help...please vote.
Feb 19, 2015 | Water Heaters
Pilot light keeps going off jazz rocco gas fire
So we are talking about the same won't stay lit I will describe both ways. One is when you lift your fingers off the knob it goes out that instant which is probably the thermocouple needs replaced,look to make sure the tip of the thermocouple is in the flame of the pilot light first. The secound version of it is it goes out in a few minutes up to a few hours.The second version is most common.There is a part called a Thermocouple that is mounted next to the pilot light, it is around 3/16 of a inch diameter 1 to 2 inches long and should be mounted so the tip is in the flame of the pilot light. This is what tells the gas valve the pilot light is burning. If any dust ,cat hair ,dog fur what have you gets around the base of the hole the gas from this pilot light comes out of it will bend the gas, which move the flame so it does not hit the thermocouple like it should, this is below the flame so what ever is in there diverting the flame dose not burn up.A draft from a fan or door could do it also.I have used a procom ventless heater as my only heat for 7 years and have to blow it out twice a year. I bought a new thermocouple at the same time I bought the heater to have in the closet in case it went bad some night, it is still hanging there .Because it sucks air in from the bottom past the flame and out the top everything in the air gets burnt into a fine ash dust. So if you use compressed air to blow out your unit you might want to hold a wet towel up in front of it hoping a lot of that white powder dust will stick to it instead of flying around the room . My flame always looks so much better ,less orange and more blue after this .
Feb 08, 2014 | Procom ML060HPA Heater
Heater fires 3 times then quits, light on control board quits blinking then minutes later it tries again.
It sounds like a weak pilot generator. They wear out after a number of years. It is trying to fire which means the safety loop is all good. Sometimes the pilot generator is strong enough to keep the pilot valve open, but upon call for heat the main gas valve isn't getting enough voltage to open (and a good voltage output from the generator drops to nothing). It's not too hard of a diy
Sep 12, 2013 | Jandy Lite 2 Natural Gas Pilot Light...
The pilot light is out on my valor gas fire place. When I go to light it the flame comes on but if you let the button up to turn on the burners it goes out.
Keep the pilot gas control pressed down for 30 seconds to a minute after it lights to allow the thermopile in the pilot light to heat up. If you are already doing this the thermopile needs replacing
Dec 22, 2012 | Kitchen Ranges
Pilot light won't ignite
Wait 30 minutes; press reset button. Repeat if necessary. 4. Pilot light out. 4. Relight pilot. 5. No gas. 5. Make sure gas valve to furnace is fully open. Not enough ... home.howstuffworks.com/how-to-repair-gas-furnaces1.htm
Just checked this site. I am sure you will find it useful - Good luck
Feb 07, 2012 | Heating & Cooling
Pilot ignights, keeps sparking then goes to lockout
I have the exact same model with the exact same problem. Did you ever figure out what the problem was? I just picked up a new gas valve, but maybe i should check the flame sensor first. In my systems case the electronic ignition fires, which lights the pilot, but it keeps firing even though the pilot light is lit. So I think it could be the flame sensor, how do I remedy that or check it out. I would like to check this out first before dropping in the gas valve, cause they arent cheap and I can still return it before its installed.
Jul 11, 2010 | Raypak Free Hydraulic Lift Gate Delivery -...
My laars swimming pool pilot light keeps going out and it makes a clicking noise when it fires up and the pilot light goes out? it has been going on and off alot recently but can work for weeks on end then...
check power pile conections on gas control valve.it is the 2 wires that come from pilot asembly.if they are loose or have rust or oxidation this can affect pilot and cause intermittent outage. let me know
Jul 20, 2009 | Teledyne Laars Laars Lite 2 Pool Heater...
Bakers pride pizza oven
does it light then immediately go out? if yes, usually you have to hold in a button to allow gas to flow while you light the pilot, and hold this button until the therm0-couple is heated with the pilot flame. If the thermo-couple is not sufficiently heated and you let go of this button, the pilot light will go out as the safety circuit thinks there's no flame and unburned gas is entering the oven.
The other thing you could do is adjust the height of the pilot flame... there's usually an adjustment screw near the button described above which will allow you to adjust the height of the flame. Make the flame just big enough to guarantee that it keeps the thermo-couple hot AND that it can light the oven without being blown out.
Good luck.
Apr 21, 2008 | Ovens
Heating & Cooling Logo
46 people viewed this question
Top Cozy Heating & Cooling Experts
Paul Carew
vance jones
Mack Baxter
Are you a Cozy Heating and Cooling Expert? Answer questions, earn points and help others
