Question about Panasonic Flip Number Alarm Clock Am Radio Rc-1280 Japan
Flip clock radio runs slow
This clock radio has worked very well since new until about two to three months ago when the clock started running slow. I am considering opening it up and looking for some key spots to maybe apply some wd-40 to see if that will help. Any suggestions?
2 Suggested Answers
ripleymojica
  • 643 Answers
SOURCE: I bought a Panasonic clock-radio
Yes contact panasonic. They may have a flat rate repair if sent to them.
Posted on May 09, 2011
How do I adjust the clock when it's running slow?
If your cuckoo runs too fast or slow, the best way to correct this problem is to set your cuckoo to an accurate watch or clock. After 24 hours, record how many minutes your cuckoo is running too fast or slow. Then adjust the bob up or down the pendulum stick to change the pendulms effective length. You'll need to take an educated guess as to the distance. Reset the cuckoo minute hand time to your watch or clock again. Repeat this process every 24 hours, recording the results, and readjusting the bob until you are within 3 minutes of the correct time. Then, switch from recording every day to recording every week. Use the same process described, recording the time difference, adjusting the bob up or down every week, until the cuckoo is accurate within approximately 3 minutes per week. Remember, mechanical cuckoo clocks are not as accurate as quartz or electric clocks! A three minute error per week is not bad. Maybe you can do better. What you are attempting to do is to obtain is the best timekeeping possible from your cuckoo clock. Afterwards, you will still need to sychronize the cuckoo (coo coo) clock minute hand to an accurate clock or watch, each week or as desired.
Feb 14, 2016 | Audio Players & Recorders
Every time i start the car it resets the clock
The clock and radio memory use a different power source than the radio - - that source is not controlled by the key switch. I would check the fuses first to see if you blew one that is hot all the time.
Jul 15, 2012 | 2007 Mitsubishi Outlander XLS
P105-56014> clock runs slow.> This is a daily problem> when I start up it will be on yesterday's date.> I reset the time and date and the clock runs slow. I set it 3 hours ago and it is 90...
No
the clock is not running slow. Double click your clock.You will see three tabs: Date&time, Time Zone, Internet Time.
click internet time and you will see tick mark on internet. remove it by clicking on it
If grayed out , reset your time and date
Aug 05, 2010 | Toshiba Computers & Internet
My Emerson CKA1000 clock radio worked great for years, but now it eats the battery back up, battery will go dead in a month or so and if I set the alarm for radio it will show the 20 ne message when the...
Sounds like the main power supply may have gone bad and you are strictly running off the battery. This is why it works fine for a while when you install a new battery, that is until that battery drains and gets too low. The radio won't play because it is preserving battery life. I bet you could unplug it from the wall and would get the same results. You essentially have a battery powered clock right now. To test this theory simply remove the battery, plug the clock up and see if it comes on. My guess is it will only work with the battery installed.
Jul 23, 2010 | Emerson CKA1000 Clock Radio
No water goes into dishwasher. Dishwasher has only been used 2times. Came new with house 3.6 years ago. Pulled front panel off...everything appears to be connected motor fan runs.
I've experienced the same thing. Try very slowly rotating timer dial, click by click, until the water starts. Sometimes 3 or 4 clicks will start water. (You're advancing the clock.) Usually water starts in before the dial points to, "Short Wash." If this doesn't work, advance the dial to, "Off," unlock and open the door, reset, close, the soap dispenser, close and lock the door, and slowly advance the dial until the unit starts. I think this problem is a clock to pump issue and what I've described does a reset of the system. This happens to me once or twice per month. Poor engineering but still better than buying a new machine...at least 'till now.
Jan 04, 2010 | GE Nautilus 24" Built-in Dishwasher
RCA RP5435B SN.1A006J255A0594-Clock running slow
Most of the Radio clocks by RCA are meant to be used with 60Hz AC line. This problem will not go away unles you can get a custom built 60 Hz AC power supply, may prove to be too expensive for the clock.
Sep 20, 2008 | RCA RP5430 Clock Radio
I have a starmate2 replay and what has happened is i turn it on and it stay on the title screen thats it.None of the buttons will work on it only the power button to shut it off.Please help
Three months ago I had the same problem. My wife paid over $300 for the radio, the portable boom-box and subscription less than 2 years ago.
Sirius offered no help or discount on a new radio. Guess they follow the Microsoft doctrine because they suggested I upgrade to a new radio.
Anyhow, feeling frustrated, I took the receiver apart, thinking that a stray voltage on an IC ping maybe causing the problem. It was only a guess. I don't even have a wiring diagram At any rate, once I had it apart, I used a small flathead screw driver and drug it (lightly) across all IC pins, possibly in an effort to drain the voltage. Please do this in a low static area.
When I put everything back together, the receiver worked. It's been working good the up until about 2 weeks ago, when the same problem began again. I just finished the same process and the receiver is working again.
I don't advocate this for anyone who doesn't know how to handle electronics.
I'm just very disappointed in Sirius for not admitting the problem and providing no discount for a newer model. I have a $10 clock radio that's 9 years old. Guess what, I don't have to take it apart every three months to keep it working.
Ken in PA
Jul 20, 2008 | Sirius Starmate ST2 Satellite Radio...
Daylight savings time adjustment
Go to:
http://www.emersonelectronics.ca/emerson/en/product/details/VLJT600
or
http://www.emersonelectronics.ca/emerson/en/category/list/694
The solution appears to be common for all recent Emerson SmartSet(tm) radios (BTW it's not the clock fault, it's the law).
Remarkably Emerson foresaw this, so here we go.
Short version (may require three hands :-) )
DST start:
Press and hold MONTH/DATE and ALARM 1 buttons for at least 3 seconds until the display changes to something like "4 F" (Fourth month, First week) alternating with something like "4. 1" (April 1st, for 2007) or "4. 6" (April 6th, for 2008). While holding down the MONTH/DATE and ALARM 1 buttons, now press the DOWN or "-" Set button (3 times) until "3F2" shows (Third month, second week) alternating with something like "3.11) (March 11th, for 2007) or "3. 9" (March 9th, for 2008). Let go of all buttons and we are now half done.
DST end:
Press and hold MONTH/DATE and ALARM 2 buttons for at least 3 seconds until the display changes to something like "10 L" (Tenth month, Last week) alternating with something like "10.28" (October 28th, for 2007) or "10.26" (October 26th, for 2008). While holding down the MONTH/DATE and ALARM 2 buttons, now press the UP or "+" Set button (1 time) until "11 F" shows (Eleventh month, first week) alternating with something like "11. 4" (November 4th, for 2007) or "11. 2" (November 2nd, for 2008). Let go of all buttons and we are now done.
This should remain until either the lithium battery fails or Congress undoes its work.
BTW the Emerson addendum has a history error. The time change in the first Sunday in April and the last Sunday in October did not start in 1966, but in 1987. Before that starting in 1966 the standard was set at the last Sunday in April and the last Sunday in October. Except for 1974, when it was January 6th, 1974 (DST start) and October 27th, 1974 (DST end) and in 1975 when it was February 23rd, 1975 (DST start) and October 26th, 1975 (DST end). Before 1966, state and local governments had many different rules. Source: http://webexhibits.org/daylightsaving/e.html
Oct 28, 2007 | Emerson CKS3029 Clock Radio
Panasonic Flip Number Alarm Clock Am Radio Rc-1280 Japan Logo
43 people viewed this question
Top Panasonic Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
