Question about Audio Technica Audio-Technica PRO 4L Professional Microphone
Pro 4l switch
Switch broken
4L light
the motor has three bolts and a plug. They are pretty simple to do.
Jul 26, 2012 | 2007 Ford Explorer Eddie Bauer
Hp 4L printer won't pickup paper from tray. Sequence- green led light- motor running but with grinding- no movement from pickup roller or foot- finally a misfeed led light.
That is a very common problem with the Laserjet 4L and 4P printers. The sound you hear is caused by a broken motor drive gear. This is a small plastic gear on the drive motor shaft. They can develop a small crack which prevents the motor from turning the gears for paper pickup and toner movement. When the motor tries to turn the broken gear can not turn the other gears and makes the popping or grinding sound when the gear teeth slip. You will need to replace the motor gear, it is available here:
http://www.ccl-la.com/catalog/product_info.php?cPath=24_41_49&products_id=61
I hope this helps,
BuddyMc
Jul 16, 2012 | HP Office Equipment & Supplies
Transfer case shifter is locked up in 2H on 4x4 montero sport 2002
Mine did the same thing so I removed the center console and then the boot around transfer case shifter and the shifter it self.
This is when I discovered a broken linkage that had wedged itself between the 4L & 4H shafts in the transfer case. I removed the broken parts and reassembled and it will shift between 2H & 4H but not 4L until the broken plastic linkage is replaced. Found your post while lookin for the replacement part so I thought I would try to help. Good Luck
Feb 08, 2011 | 2000 Mitsubishi Montero Sport
4L light has appeared on the dash. the trans is in AWD and has never been switch to 4L or any other drive !
it may be a shorted switch or stuck try rocking the t.case shifter through the ranges see if it go out 4l 4h awd several times they had a habit of sticking if not used regularly if that doesnt help it could be the module ?
Mar 24, 2010 | 2002 Mitsubishi Montero Sport
4L light flashes in 05 rodeo 4x4 3.0 deisel
water is getting inside the switch boot on the transmission
when it dries , light goes out
Jun 03, 2009 | 2004 Isuzu Rodeo
Fit my Canon NB-4L Battery
Canon nb-4l battery pack canon 100 percent compatible with you canon nb-4l camera battery. I bought two canon nb-4l battery from http://www.camera-battery.co.uk/canon/nb-4l.htm two weeks ago, I felt very surprised, because it fits nearly as good as the original battery.
Feb 06, 2009 | Canon Cameras
HP Laser Jet 4L fuses
The fuses are located on the DC Controller (main bottom board). Getting to the DC Controller Board on a 4L printer is a very significant disassembly. Best left for a pro but if you really want to do it, I have attached below a link to a scanned copy of the service manual. Please keep in mind that the scanned copy is not a nice fresh PDF as most manuals as the 4L was made in 1994 and HP has physically scanned the printed manual for distribution. Just look up the removal and replacement of the DC Controller Board. Once removed, the fuses are glass buss style, readily available at any Radio Shack.
Gotta love that old technology.
Hope this helps you. :)
http://www.feedroller.com/Store/Service%20Manual/LASERJET%204L,%204ML,%204P,%204MP%20Service%20Manual.pdf
Aug 27, 2008 | HP LaserJet 4L Printer
On & off switch
I don't think there is one.
Jan 17, 2008 | HP LaserJet 4L Printer
Audio Technica Audio-Technica PRO 4L Professional Microphone Logo
Top Audio Technica Audio Players & Recorders Experts
 Grubhead
Grubhead
Greg Cann
Greg Cann
Clif Roberts
Are you an Audio Technica Audio Player and Recorder Expert? Answer questions, earn points and help others
