Question about Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top Load Washer with Precision
Whirlpool washer wtw5500xw cabiro will not drain
Whirlpool washer fault codes
Whether under Warranty or Not this is a Controller Problem and a Tech will have to be called as you won't be able to DIY access a new part from an Appliance Parts Shop or Whirlpool.
Controller or sensor are not repairable but must be replaced as a Unit to restore full function
Sep 08, 2014 | Whirlpool WTW8200YW 4.6 cu. ft. Cabrio...
Why does my washer wtw6200sw2 display an Ld code?
The Ld code is Long Drain. You might have a clogged hose. I had this problem once with mine. We had to empty the washer by hand and turn it on its front. Make sure you unplug it first! There is an elbow that I think was attached to the pump. We popped it off and it was clogged with dog fur (from washing dog bedding). Cleaned it out and put it back on and that took care of it. I found the diagram of the system online and suggest you look for it too - my memory isn't what it used to be - it'll tell you what to look for and where everything is. It could be the pump, too, but hopefully just a clogged hose.
Jun 07, 2014 | Whirlpool WTW5600XW 3.6 cu. ft. Cabrio Top...
Wtw5500xw2 will add some water, senses for a very long time. Sometimes it makes it to the "wash" cycle but nothing happens. When you come back later the machine is off and the lid is unlocked as if it...
Un plug it for a few minutes or even overnight and plug back in, that will reboot the electronic control, if that doesn't fix it and you do not have a good honest local repair shop call Sears. Good Luck
Oct 12, 2013 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
I have a cabrio top fill Washer model #WTW5500Xw1 that will not fill with water
Both hot and cold water or just one type. Check the hose in line filters, they could be clogged.
Oct 03, 2013 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Can the water level be raised?
1st thing to check, would be water level sensor, usually a pressure switch, one end will be connected to the outlet pipe the other to a approx 75mm dia unit towards the top with two wires on it. clear that pipe
Mar 03, 2013 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Whirlpool Cabrio Washer fills but will not do anything else
1. Remove the drain hose from the drain and try to drain the water from the washer. To do this plug the washer back in and attempt another drain cycle. If water does not come out of the drain hose then you now know that the plumbing is in good working order. 2. Place the drain hose back into the drain and remove the washers cabinet.
3. You will now be able to see the pump and it should have two hoses attached to it.
4. Disconnect the hose coming from the basket. If water comes out you will know that nothing is clogging the basket.
5. If both of these tests come out good you now know that the problem is the pump.
6. Make sure you write down all relevant information such as the washing machine model and serial number.
7. Head to your local hardware store and buy a pump (they typically run about $15.00).
8. Remove the old pump and install the new one (make sure the washing machine is turned off and unplugged).
9. Test it. Let it run through a cycle to make sure everything is installed and working properly.
10. If it is still broken call a repairman or ask a handy friend to check it out for you.
Sep 20, 2012 | Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top...
Whirlpool WTW5500XW 3.6 cu. ft. Cabrio Top Load Washer with Precision Logo
24 people viewed this question
Top Whirlpool Water Heaters Experts
Donni Steen
80stech
jdthefixer
Are you a Whirlpool Water Heater Expert? Answer questions, earn points and help others
