Question about Jenn-Air Dishwashers
Items on top racak not getting clean
Seems like water not flowing properly to arms
catriver
  • 878 Answers
SOURCE: Water not getting to the upper level, dishes not cleaned.
Penrod, sounds like a circulation problem. Two things to check first. make sure the upper spray arm is not clogged with debris or split. Second is to twist and remove the filter and clear out any debris where the water enters the circulation pump impeller. If something has jammed the impeller, you would have to remove the dishwasher, remove the tank, remove the circulation motor and clean out the impeller...Catriver...post back.
Posted on Sep 03, 2006
catriver
  • 878 Answers
SOURCE: dishwasher does not clean properly
sewnice, you might have to dig a little deeper to correct the problem. As long as you can spin the spray arm with your hand and it's not split it should be ok. Your chopper screen might be plugged. You will have to remove the lower spray arm and filter cover. These are torq screws. The accumulator assy. turns to the right to unlock and will lift off. It will take some pressue to snap it off the rear fill tube. Now you will be looking down at the cover that protects the chopper and screen. There is one torq screw holding it down. Remove the screw and lift it off. See if the screen is clogged. If it is, it will prevent the pump from sending water to the upper spray arm in force. Catriver..post back
Posted on Feb 24, 2007
Noggin
  • 944 Answers
SOURCE: Upper rack dishes not coming clean.
You could try running it with the upper arm removed, just so you could be sure that the pressure is not getting to that point - unless you are absolutely sure the upper arm holes/channels are all clear then descale it overnight with some vinegar - just might clear something. if there is obviously only a little flow of water then perhaps you could try getting vinegar into the supply pipe using a basting bulb/syringe or similar - again leave overnight and you may get lucky. The next thing would be to take the machine apart so you could follow this hose through to the pump - undo it from the pump and blow through it or see if you can get a piece of wire in it from the pump end. try vinegar again. check the pump outlet for blockage. Hope this helps :)
Posted on Mar 14, 2007
  • 236 Answers
SOURCE: Bottom Dishwasher arm not turning
have you seen whether water is pouring out of the bottom supply tube with the lower arm removed? not 100% sure on this model but some units have a half load switch but that should turn off the top one. there may be a blockage in the lower water supply tubeways.
Posted on Jun 16, 2007
SOURCE: figidare dishwasher
I have a diswasher problem
type GSIP 6598 from Bauknecht
The reset button keeps blinking
what can I do?
Regards
Annick
Posted on Apr 07, 2008
Why are my top rack dishes not clean at all?
It is likely that sufficient water is not coming from the top arm. These dishwashers oscillate the water flow between top and bottoms sprays alternatively. This ensures water is pumped with adequate force. It is possible this mechanism is not working correctly. The device called check ball item 58 in this diagram actually does this function. The ball might be out of shape or not sitting properly causing incorrect wash water movement.
http://www.searspartsdirect.com/partsdirect/part-model/Frigidaire-Parts/Dishwasher-Parts/Model-FDB1050REC0/1428/0130000/R0505129/00004?blt=06&prst=&shdMod=
Apr 30, 2014 | Frigidaire 24 in. FDB1050REC Stainless...
Not cleaning dishes
Good Morning Lynn, thank you for your post!
I understand your dishwasher is not cleaning properly. Will the spray arm rotate freely or is it damaged? If so, you might have to remove and replace the spray arm assemblies. The top spray arm typically starts to function when the unit is in rinse or wash cycle. If for some reason the top rack is not getting clean, there is a possibility that it is not working properly. The top spray arm is either blocked by pots/pans or not enough water pressure is being pump meaning that the flow of water is not making it to the upper spray arm. If you tap the delivery tube that feeds this nozzle and the water pressure jumps immediately, then the problem may lie with a faulty pump or impeller. Should all basic troubleshooting measures fail contact a certified technician to narrow down the precise issue before investing in parts that may or may not be the root cause.
Dec 15, 2013 | Frigidaire 24 in. FDB1050REC Stainless...
LG LDF6810ST dishwasher won't clean and spin arms properly
Check for a worn bushing washer on the lower arm. Also, make sure the arms are clean inside - they are propelled by reaction from the water jets spraying out, and clogs will prevent proper water flow through the jet orifices. Sometimes food debris will get through the pump and cause this problem. The diverter valve may also have trash inside clogging it and keeping from seating properly - this could account for both low pressure at the spray arm and water coming out of the lower rack when it should not.
Dec 02, 2013 | LG Dishwashers
The unit goes through its cycles but the top rack is not getting clean. The bottom spray wheel works, the middle and top spray arms are getting water but it seems not enough to make them rotate. The pump...
The problem is likely to be that the jets in the rotor arm are blocked.
To check this, remove the arm (it is easy to do, as it is intended for the user to do this) and clean out all the holes. Try running water from you tap through the holes (backward flow) to remove anything that is too large to pass through the jets.
Sep 26, 2010 | Dishwashers
Why does the diswasher not clean top rack of dirty dishes? It does not seem to be getting any water.
Check if the top sprinkler arm sprinkles any water. If it got some years the screw on which holds the arm might be worn out and that could, depending on the model, result in water only flowing straight down to the second arm. Or the sprinkler arm could be clogged, I would check it out anyhow.
Mar 06, 2010 | Dishwashers
Bottom rack cleans fine, top rack doesn't clean at all - can I take apart the top spray arm?
yes, the spray arm can be removed and cleaned out.
Also, clean the 3rd (very top spray area) located attached to the top of the dishwasher. You want to make sure this small (1 inch size) piece can spin freely, so water can rinse the upper rack items.
Feb 01, 2010 | KitchenAid 24 in. KUDS25SH Built-in...
Frigidaire dishwasher - upper spray arm trouble?
I do not have a problem w/the upper arm not spinning. Rather, the upper arm keeps falling off of my frigidair dishwasher. The owner's manual suggests the upper arm is a single unit. However, the upper arm component is comprised of 3 parts. The parts are an arm that distributes the water, the base that screws to the top of the dishwasher, and a small plastic type washer that rides in the base and literally holds the arm to the base. The plastic washer has two small clips that tend to wear or contrast with age; thus letting the arm fall off on a very frequent basis.
Potentially, the small plastic washer piece may have broken in the base assembly and is not allowing the arm to turn. As water flows into the arm from a hole in the base; suggesting the plastic washer may be jammed with a foreign item seems less likely. The base unit screws to the top of the dishwasher and can be removed by hand (the base is a little tight). There are no mechanical pieces to my third (upper) arm; movement of the arm is accomplished with water flow.
You may wish to remove the arm assembly and check for a broken washer or a foreign item in the assembly. As a side note, I found that I can unscrew the base and remove the assembly without removing the top dish tray. The fit is a little tight but the tedium of pulling and reinstalling the top tray can be eliminated by unscrewing the assembly w/the tray slid forward for assembly access.
Hope all you have is a foreign item that is locking the washer.
Nov 03, 2009 | Frigidaire Dishwashers
The top drawer does not get my dishes clean. When the come out, it seems as though water is on the inside but they are not clean
Clean the sprayer arm. You can try running dishwasher cleaner through the machine or remove the arm and make sure the holes are clean and free from obstruction. If this is clear then you will need to check the pump to make sure it is pushing water at a sufficient flow to clean the dishes on the top rack.
Oct 08, 2009 | Dishwashers
MY KITCHENAID DISH WASHER TOP SHELF IS NOT CLEANING AT ALL .
There may be something plugging up the arm that sprays over the dishes. And of course, I'm sure you know not to place items like bowls, pots, etc that will block the flow of water from the bottom sprays.
Although the bottom jets do most of the working cleaning the top items, the spray from above is vital. Take the stem pipe leadin from the top to the bottom off and separate the spray arms carefully. If you can, look throgh each end to make sure no deposits are in there.
Another way is to blow compressed air from the center stem down in the water supply unit. If food particles are there you'll see them.
May 14, 2009 | Jenn-Air JDB6510 Built-in Dishwasher
Mar 14, 2007 | Frigidaire 24 in. FDB435RFR Built-in...
Dishwashers Logo
13 people viewed this question
Top Jenn-Air Dishwashers Experts
John Tripp
John Tripp
Mike
Are you a Jenn-Air Dishwasher Expert? Answer questions, earn points and help others
