Question about Drills
Replacement diode for mb on battery pack
Connected wrong charger line and blew diode, need to replace. need part number for diode
4 Suggested Answers
puertobori
  • 7733 Answers
SOURCE: Charging Stand for Singer Cordless
Look at eReplacementParts.com and the parts diagrams or ToolPartsDirect.com - Your Tool Repair Supply Store.
If you need more help come back.Post / thumbs / testimonial are welcome!
Posted on Nov 12, 2010
c1apton15
  • 3400 Answers
SOURCE: The charger inidcated to replace
If you have a Batteries Plus store near you they can test your charger. (had one done recently)
Posted on Mar 12, 2011
wade7223
SOURCE: I need a recharger for a DESA Remington brand 18v
Yea go to Remingtontools.com and search for your part there. Their model #'s are different so search by finding a new saw and using it's # to locate parts from it.
Posted on Sep 30, 2012
Need replacement diode for battery 1311145
if you are in australia you can try Jay Car
Feb 08, 2014 | 1311145 7.2 Volt Battery Pack
Dyson dc31 won't charge
Sounds like the charger is bad. It is 24vdc output, so you can check with a voltmeter. It probably blew the fuse inside since it isn't lighting the green charge light. There are replacement chargers for this for under $20.
Dec 04, 2013 | Vacuums
Schematic dewalt de0246
depending on the location of the diode in your charger just try replacing it with a ginaric type diode of the same size, but be forewarned that the diode blew up for a reason and you must first find the cause before you replace it for it will blow again and possibly cause more destruction, is it worth it to you to repair or just bye a new one ?
best regards Falco
Oct 31, 2013 | Drills
Battery for Remington MB-70 Beard Trimmer
Remove the batteries and look at the number on them, then go on ebay and you can find a replacement to make up the needed battery cell pack.
Jan 15, 2012 | Remington MB-70 Beard Trimmer
DeWalt charger #DW9107 binks eraticly, even when battery is not installed, DC output is 35 volts, which is too high, the reading across all of the diodes on the circut bd in the converter circut is 5.8...
There could be a number of things wrong inside the charger, and could cause more problems trying to replace components on the board. Your best bet is to look on ebay or some other place to see if you can get a replacement charger.
Mar 29, 2011 | Dewalt DW056 18 Volt Cordless Impact...
Charger adapter and battery get warm but charger light won't come on. Batteries don't charge any more. Are there supposed to be 2 or 3 charger contacts in the charger? Mine only has 2 but the batteries...
This could be an indication of a bad cell in the pack. As nicad batteries get older they will sometimes short internally do to oxide buildup. If one or more cells are bad the pack as a whole will pull more current from the charger which in turn could cause it to heat up. Most newer chargers have 3 contacts. The 3rd contact is normally conected to a diode inside the pack. The chargers circuitry monitors the batteries temp by measuring the voltage drop on the diode.
Hopefully this may give some insite.
Nov 12, 2009 | Drills
Car Battery Charger - Repair
thats what i did on mine they blew when i hooked the cables up backwards (gotta watch that)
but i used 130 amp alt diodes from an old tractor alt i had
Jul 03, 2009 | Kitchen Appliances - Others
I need to replace the diode on a 4.8 volt NiCad 400m rechargeable
If you de-solder the diode, there should be a number on it i.e. 1N4000. You may need a magnifying glass depending on how tiny you can read. Once you know the number, you can go to DigiKey or another online electronic parts supplier and order it.
Mar 19, 2009 | Uniden HH9485 - Drop in Charger Fits the...
Drills Logo
Top Drills Experts
Are you a Drill Expert? Answer questions, earn points and help others
