Question about Stanley Air Tools & Compressors
Air compressor will not shut off after pressure
  • 1383 Answers
SOURCE: how do make air compressor shut off at your desired air pressure
You compressor has a pilot valve that controls the tank pressure and the speed of the engine. Locate the brass pilot valve, (It has a flip lever that unloads the compressor) you will notice that it has two locking nuts that allow for adjustment when loosened. Loosen the small lock nut and turn the upper-most part of the pilot valve out to reduce pressure, in to increase pressure. Hope this helps, enjoy.
Posted on Dec 11, 2008
gaeb7
  • 25 Answers
SOURCE: 25 gallon air compressor wont shut off,changed air regulator
You have a valve plate problem . It could be a slipped "o" ring to a bad reed valve. There are rebuild kits for that purpose. The kits include a valve plate assembly. It covers all the bases. When you look at this area pay attention to the partitions of the head gasket/"o"ring. You may avoid the cost of the kit.
Posted on Feb 25, 2009
roniecon
  • 6826 Answers
SOURCE: Sanborn 34A50 air compressor will not shut off.
look in the box where the wires go in and see if ther is an ajustment screw if n ot replace that box it is the pressure switch
Posted on Jul 01, 2009
Testimonial: "Following roniecon's suggestion I eventually found that the problem was caused by a stuck pressure control switch. Thanks for your help."
dmftrucker
  • 1922 Answers
SOURCE: Bostitch Air Compressor cap60p-of will not shut off
you can open the pressure switch if it has a removable cover and try,but i'd replace the pressure switch anyway
Posted on Aug 29, 2009
  • 18 Answers
SOURCE: my husky air compressor is suppose to shut off at at 125psi
Pressure switch may be stuck. May need to adjust pressure switch.
Posted on Jul 10, 2010
Compressor has air coming out the air in take, and has air pressure in the crankcase. When shut off. I shut it off at 150psi.
home compressors should cut out at 100- 110 psi so check / replace the controller
air out of the inlet is air under pressure holding the valves open
pressure in the sump is a blocked breather for the sump possibly from excessive air pressure
remember it is not pressure that drives tools but volume flow so if you have a 10 cubic ft /min compressor but are running a tool that requires 12 cubic ft /min air then 150 psi is not the answer
a bigger capacity compressor is
Nov 06, 2016 | Air Tools & Compressors
Why my air compressor want shut off after building up pressure
If it is building up to the full rated pressure and there are no air leaks in the hoses then it is most likely the pressure switch. It is item 111 in this parts diagram.
Porter Cable C2002 diagram
Aug 25, 2012 | Porter Cable C2002 150 Psi 6 Gal...
Leaking air
When the Pressure switch shuts off, the little air valve in the pressure switch vents the copper line from the compressor, to blead the pressure from the compressor so it's easier to start the next time. If it continues to leak, the check valve between compressor and tank must not be holding.
Jul 16, 2010 | Ingersoll Rand - Rand - Ir 2545K10FP Type...
My husky air compressor is suppose to shut off at at 125psi
May 27, 2010 | Air Tools & Compressors
My air compressor wont shut off when its full like it use to.
Hello
Could be a bad pressure control switch.
Depending on the size of the compressor it should shut down on high pressure via a pressure switch.Some will shut down at 150psi.
Also there should be a relief valve,make sure this is also working.
Apr 06, 2010 | Craftsman Air Tools & Compressors
hi mate you can try and adjust it but if this problem has just started then you need a pressure switch replacement
Aug 29, 2009 | Air Tools & Compressors
Compessor trips circuit
IT SOUNDS LIKE YOUR COMPRESSOR IS NOT UNLOADING WHEN IT SHUTS DOWN. YOU SHOULD HEAR AN AIR RELIEF SOUND TYPICALLY ON THE SIDE OF THE PRESSURE SWITCH WHEN IT SHUTS DOWN. ITS A SMALL VALVE WITH A TIRE VALVE THAT THE LEVER HITS AND RELIEVES THE PRESSURE FROM THE DISCHARGE LINE AND THE TOP OF THE PISTON.
YOUR CHECK VALVE COULD BE BAD LETTING PRESSURE BACK UP BUT IT WOULD BE BLOWING AIR OUT ALL THE TIME WHEN SHUT DOWN.
IF YOU THINK THE VALVE OR SWITCH IS WORKING AND WANT TO CHECK IT, LET THE COMPRESSOR BUILD UP AND SHUT DOWN, LISTEN FOR THE AIR RELIEF,IF IT DOESNT THEN CRACK THE DISCHARGE LINE AND SEE IF THERES ANY PRESSURE, MANUALLY RELIEVE THE PRESSURE THEN USE SOME AIR AND SEE WHAT HAPPENS. REPAIR VALVE ON THE SIDE OR CHANGE PRESSURE SWITCH $30-40.00. HOPE THIS HELPS. PLEASE REPLY. JODY
Apr 04, 2009 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
Air compressor - pressure problem
'When the machine is shut off, disconnect the discharge line out of the head of the compressor. If air releases, replace discharge check valve in tank.
Mar 30, 2009 | Air Tools & Compressors
Cycling compressor
The pressure switch will shut off when the set pressure is obtained. Usually about 100 to 120 lbs. If the compressor stops at lower pressure than mentioned you may try to adjust the pressure by looking under the switch cover for adjustment screw/nut.(no more than a few turns) Increase pressure by increasing spring tension. Quick cycling is usually caused by air leaking from tubing, drain valve or check valve. After compressor shuts off unplug it from the outlet and spray soapy water on all fittings and drain valve. Repair leaks and test for quick cycling, however the compressor should reach 100-120 before shutting off. Some small compressors have a thermal reset but that usually takes a few minutes to reset. Pressure switch is defective if it shuts off before setting mentioned. Enjoy
Dec 11, 2008 | Craftsman 3 gal. Air Compressor, 1.5 hp,...
How do make air compressor shut off at your desired air pressure
Dec 11, 2008 | Honda Quincy 17 - Gallon Air Compressor...
Air Tools & Compressors Logo
Top Stanley Air Tools & Compressors Experts
John Trevino
yoopertech
Joe Garcia
Joe Garcia
Are you a Stanley Air Tool and Compressor Expert? Answer questions, earn points and help others
