Question about Konica Minolta Office Equipment & Supplies
Biz hub 750 code c6708 - Konica Minolta Office Equipment & Supplies
  • Konica Minolta Master
  • 6,696 Answers
Check the the bright light under the big glass come on, raise the doc feeder press the start button does it come on, second deals with the CCD which is the black device under the big glass to you left, need to have tech look at it.
Posted on Jan 22, 2016
  • 214 Answers
SOURCE: Konica Minolta biz hub c350 malfunction code c-0b4c
C0B4C Finishing option Exit Motor malfunction
Try reboot holding utility key down and do trouble reset, if it doesn't help then there is something wrong with exit motor, call for service
Posted on Dec 07, 2007
SOURCE: error code c-12cc for Konica Minolta biz hub c-350?
Error code C0520 on Konica Minolta biz hub c-350??
Posted on Apr 26, 2008
taminol
  • 62 Answers
SOURCE: Biz Hub C250 - code error C2551
Ahhh, you must be the same Macdaniel I emailed for clarification a short while ago.
C2551 relates to the Cyan imaging unit, the machine thinks the toner level inside the Cyan imaging unit is low.
Opening and shutting the main front door is the reset procedure. However if this doesn't work you should try the following
Remove the Cyan imaging unit, give it a bit of a shake and then refit.
Experience tells me that the above only works on occasion and you will probably require a new imaging unit. They are available for around £250.
Please be aware that the fault could also be down to a circuit board being defective, but this is less common.
Regards
Taminol
Posted on May 26, 2009
firecontrol7
  • 6696 Answers
SOURCE: biz hub 6500 has a code c3508 how do i clear it
If this code comes right back do not attemp to clear again, contact a certified service technician and have him or her look at this problem, it deals with fuser the hot part of the machine. Dangerious!!
To reset a fuser abnormality code, perform the following:
1. Power the machine OFF from the main switch leaving the sub switch ON.
2. Press the utility Key and power ON the machine from the main switch.
3. Enter Stop => 0 => 0 => Stop => 0 => 1.
4. Press [03 System Setting] on the touchscreen.
5.Press [01 Software SW setting] on the touchscreen.
6.Press the left up-arrow, which is displayed on the touchscreen, 2 times. The number displayed above the up-arrow will change to 03.
7. Select the bit number of switch 1, using the right up-arrow, 03-1 will be indicated.
8. Press the [Return] key, which is displayed on the touchscreen.
9. Exit Service mode to return to normal operation.
DipSW 3-1 is set to 0 without correcting the cause of the error, a fire may occur.
Posted on Aug 15, 2009
  • 158 Answers
SOURCE: konica minolta biz hub C250 need to reset admin code URGENT
you cannot overide the administrator password on the konicas the default password is 12345678 try that
Posted on Oct 31, 2009
How to fix problem biz 750 code c6708
Exposure lamp that is the bright light under the big glass that come on when scanning, the code also is associated with the CCD that is the device that see's the image you wand to copy or scan again under the big glass to your right, has a lens on it. One or bot are bad.
Jun 25, 2014 | Konica Minolta bizhub 750
Error code c6708
Please send me konica minolta bizhub 600 full service manual and help us this code c6708 still and my next machine bizhub 750 still warming up why problem this machine please help and send me your email address.
i want to talk to you continuous
May 18, 2013 | Konica Minolta Developer 02xk Dv710 for...
Error code c1144
I have 5 biz hub 654s. There is no "utility" hardware button. Instead, open the front cover (marked "biz hub 654") - switch off the main power - white switch in an orange rectangle. Wait 30 secs. Flip back on- then QUICKLY close the door while holding down the yellow RESET button. "Trouble reset" appears - tap it - OK appears below it. Use main power to power down. Wait 30 seconds. Power back up. Works every time.
Nov 01, 2012 | Konica Minolta Office Equipment & Supplies
Wanted suitable konica minolta black and white copier to be installed in a school
First for a school you will need to know the volume of copies you are going to use per month.Then go from there, there so many segments.For example 30k to 40k per month would put you in a segment 4 something like a konica Minolta Biz Hub 601 or Biz Hub 750
Sep 07, 2010 | Konica Minolta Bizhub 222 Black and White...
To enter service mode on biz hub c 500 what is the key order?
Lost my access to add employee name to scan docs Biz 500/420
Jan 22, 2009 | Konica Minolta bizhub C250 All-In-One...
24 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
