Question about DeLonghi Magnifica 3300 Espresso Machine
Delonghi magnifica- water light on even though reservoir is full
Even though the reservoir is full, the red water indicator light is on, and the machine won't work. Sometines the light goes off and then on again in the middle of a cycle and then the function stops. Tried turning it on and off, and unplugging, but the problem recurs.
SOURCE: no water light on new delonghi magnifica
I had the same problem.
As the machine is brand new, try washing the infuser under the hot water tap and then dry it. I then made a 2 cup long coffee and the red no water light stayed off.
Posted on Apr 11, 2009
  • 421 Answers
SOURCE: Coffee machine Delonghi Magnifica grinding function not working
There are two reasons for this usually. Either the grinder is jammed or the grinding wheel or wheels have broken. Your machine needs to go to a repair shop to be looked at.
Posted on Jan 13, 2010
SOURCE: delonghi magnifica coffee machine...infuser jammed
Remove base plate and turn pulley clockwise (probably for several minutes) until infuser arm returns to vertical position and the infuser itself drops to the low position. You should here a click when it reaches this point. The infuser can then be removed as normal.
Posted on May 03, 2010
Dane1234
  • 25 Answers
SOURCE: I'm getting the
Not good; from page 21 of the owner's manual: If the message is still displayed after cleaning, contact the service center.
The good news is that when I had to send in my ESAM3500 for warranty repair, I called DeLonghi (1-866-528-8323) and got through to their repair center without difficulty. They sent a new shipping box and wrapping material, and a prepaid shipping label to a repair center about 100 miles away. I got my repair ESAM back in just a week. I hope that your experience goes as well. If it's out of warranty, though, it could be expensive.
Posted on Jun 29, 2010
SOURCE: descaling a delonghi magnifica ESAm04
I had this problem too. The instruction manual says to turn the steam knob only half way counter-clockwise after pressing the button for 5 seconds, but you need to turn it ALL the way to have the procedure start (at least, that was the solution with my machine). Good luck!
Posted on Jul 08, 2010
Internal water pipes leaking on my Delonghi magnifica. Where can I buy the pipes? Will I be able to replace the pipes myself?
DeLonghi Magnifica water leak problem - YouTube
? 2:37
https://www.youtube.com/watch?v=_mNGPs79ajY
Feb 5, 2011 - Uploaded by shellway2005
My DeLonghi Magnifica ESAM3300 is not making shots. Wateris instead coming out of the front bottom via a ...Missing: pipes
DeLonghi Magnifica leaking water pipe Questions ... - Fixya
www.fixya.com > ... > Coffee Makers & Espresso... > DeLonghi
DeLonghi Magnifica coffee makers & espresso machines leaking water pipe related questions and answers. ... Delonghi Magnifica My steam arm drips when I make coffee. ... Not sure if water is leaking from water tank or internal water line.
DeLonghi Magnifica leaking water Questions & Answers ...
Order DeLonghi Parts‎
www.ereplacementparts.com/DeLonghiadvertiser rating
Buy DeLonghi Parts.
Fastest Shipping - Low Prices.
Jan 07, 2016 | DeLonghi Coffee Makers & Espresso Machines
Water indicator light keeps coming on, even though tank is full. Unit stops brewing mid cycle and indicator light comes on.
Do you mean the "Fill Tank" message? If so, I found the problem to be the magnetic switch triggered by the float in the water tank. Please confirm the message you see and I can provide more details.
Ok, it sounds like your unit might have the same problem mine did. I posted some of my findings in this thread:
http://www.fixya.com/support/t1898311-water_container_full_but_low_indication
Adding a magnet to the float helped for several months but then the problem came back. I found the root-cause to be the 'reed switch' (see picture in the other thread) and when I replaced it, it worked fine. Replacement parts like these are often available through web-sites (e.g. http://www.ereplacementparts.com)
Apr 06, 2015 | DeLonghi Magnifica 3300 Espresso Machine
My Delonghi Magnifica's three red light indicators are solid red. I have unplugged and plugged back in to no avail. Any suggestions?
Which three indicator lights? The ones to the right of the power button? If they are flashing, then your steam knob is open. Turn it clockwise and try again.
Jun 05, 2014 | DeLonghi Esclusivo Magnifica ESAM3300...
This is difficult to describe but my delonghi magnifica has developed a small problem, after turning the machine on via the front panel On button, the pump activates (slightly) even though no other buttons...
It might be a normal cleaning cycle or flushing itself out. You don't mention whether it's not working anymore, so is it just that the sounds and lights seem concerning, or has it actually stopped working?
Oct 28, 2013 | DeLonghi Magnifica 3300 Espresso Machine
Delonghi Magnifica Light B12 in manual states that
I had a problem where the machine would not operate and the water and grounds lights were on steady (red). After contacting customer support, they directed me to do a reset. This is done by disconnecting the power and holding down the ground coffee and decalcification buttons while reconnecting power. Then release the buttons and power on the unit. This revived my Magnifica from the dead, maybe it will work for you...
Nov 25, 2011 | DeLonghi Esclusivo Magnifica ESAM3300...
Full water indicator lit continuously even though
Problem was a stuck float in the small water reservoir to the rear left of the unit.. Remove top and left hand side panel. Small reservoir can be seen at the bottom left. Remove small screw and slide off the cable assembly above. You should then see into the reservoir and the float. Clean float and reservoir and reassemble.
Feb 08, 2010 | Zanussi TC7114W Electric Dryer
Low water light on even when water tank is full
Before disassembling anything, use the steamer feature to see if there's an airlock in the system.
Feb 02, 2010 | DeLonghi Esclusivo Magnifica ESAM3300...
No water light on new delonghi magnifica
Mar 24, 2009 | DeLonghi Esclusivo Magnifica ESAM3300...
DeLonghi Magnifica 3300 Espresso Machine Logo
54 people viewed this question
Top DeLonghi Coffee Makers & Espresso Machines Experts
Henry  Thomas
Henry Thomas
Shehu Pro
Shehu Pro
Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
