Question about Grinders
Need a owners manual for a Buffalo Grinder model number# 07825
2 Suggested Answers
rowdy45176
  • 2176 Answers
SOURCE: I need a replacement switch for a craftsman 1/2 HP bench grinder
this switch is no longer available from Sears, so I suggest making a wiring drawing and taking the switch to a local electrical supply house and try matching it up with a replacement. It seems to be a simple on/off type switch and I would think that you should have no problem. Let me know if you do and give me the information on the switch and I will try some other sites I know.
Posted on Dec 28, 2009
Testimonial: "Great solution. Yhank you. - b"
On/off switch buffalo bench grinder
The switch is probably generic.. go to a Lighting store and see if they have equivalent
Nov 20, 2013 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I need a product owners manual
download on pdf files type in model number and make for tv and you can print it out the instruction should be there
May 28, 2012 | Televison & Video
I need instuction manual for a Milwaukee sander/grinder
go to milwaukeetool.com and you can download the owners manual, you will need the serial number to ensure that you get the right one. Let me know if you need more assistance
Sep 23, 2011 | Milwaukee 6140 6 4 1/2in. Sander/Grinder
I need an on/switch for a 6inch buffalo grinder model #b-6cb cycle 60 1/2 hp voltage 110 amb2 3450 rpm serial#8587745
Find a Single Pole Single Throw (spst) toggle switch at the local hardware store rated for the load of the grinder. Wire the switch in place and viola you are done! Machines are stupid;they can tell the difference between an oem part and a replacement.
Aug 30, 2011 | Grinders
I have a 7" angle
There are 3 versions of the 7" grinder model 4074. Sears Parts Direct has the manual for sale http://www.searspartsdirect.com/partsdirect/part-number/BLACK-DECKER-Parts/Grinder-Parts/741333-00/0009/900/Model-4074/1228/0721050?keySuffixId=NA&productTypeId=x&searchModelNumber=4074&subCompDesc=Unit%20parts&brandDesc=BLACK&DECKER&modelDesc=7 .
Black and Decker has pdf versions of the manuals for many of their products are here: http://www.blackanddecker.com/manuals.aspx . However, check the model number on the grinder. 4074 doesn't come up as a valid model. The usual model numbers start with alphabetic characters to indicate the type of tool. The site lists where to look for model numbers.
I hope this helps.
Apr 26, 2011 | Black & Decker Garden
I have an B-6CB(KS) 6" buffalo grinder, the switch
The neutral line should never be switched--only the hot wire (black). If there are only two wires that went to the switch, you should be able to tie them together and the motor will run when plugged in. The switch should be a common SPST type either toggle or rocker to fit. Hope this helps!
Dec 26, 2010 | BUFFALO 10" Bench Grinder
Need an on/off switch for a buffalo bench grinder model B-6CB 1/2 hp. 41/2 amp. serial #775713
I had the same problem with a Northern Tools bench grinder. These are made in China and parts are hard to come by. I had enough room after removing the old broken on/off switch to install a single pole 15 amp light switch like you use in your home. I simply installed it horizontally and then put the switch cover on. It works perfectly. If you do not have enough room then look for any 15 amp or larger switch that will fit in the housing. Any on/off switch will work. You could even mount the switch on the bench in a switch housing and run the wires from the grinder to the switch and back if need be. Just be safe and make sure there are no exposed wires. As a last resort you could remove the switch connect the wires, eliminating the switch and use a plug in wall switch such as this. 4147a14.png
Apr 23, 2010 | BUFFALO 10" Bench Grinder
Manufacturers instructions for a 5" bosch angle grinder
Since most manufacturers require a valid model number to obtain a owner's manual, I can't give you the direct link for your 5" grinder without that information.
However, here's a link to the Bosch web site and their manual section where you can enter in your model number and get a free download of the manual you can save on your computer or print out.
I suggest you set up a new folder on your PC titled "household items" and save a copy titled "Manuals" etc. so you will always have a copy for future use and reference.
http://www.boschtools.com/Service/ProductServices/Pages/ManualsandPartsDefault.aspx
I hope you find this Very Helpful and best regards!
Oct 09, 2009 | Bosch 5" Small Angle Grinder
Need manual for craftsman bench grinder model # 257.191300. misplaced other one. hope you can help. mike
Mike
Not sure what was happening when the previous reply was created, but the owners manual is part number 211260001 $7.99 at SearsPartsDirect.com
That said, I'm staring at my own copy of the the owners manual and I can't really see why you would want to pay for one. The only really useful information is the parts diagram which is online at SearsPartsDirect.com. The rest is generic grinder information (support workpiece, select proper wheel, etc.) and CYA (always wear gloves and eye protection, don't remopve safety guards, don't use damaged wheels, don't stick your finger in the light socket, don't cross the steet in the middle of the block, etc.)
Jun 07, 2009 | Craftsman 6" Bench Grinder with Lamp
Grinders Logo
108 people viewed this question
Top Grinders Experts
DrBogo
Level 1 Expert
Tom Chichester
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Grinder Expert? Answer questions, earn points and help others
