Question about Pyle Pro PCMX265W 8" Portable PA System with MP3 and DJ Efffects[...]
Pyle pro pcmx265w power but no sound
Powers up but no sound
Pyle troubleshooting
probably something wrong with speaker
Sep 08, 2014 | Pyle Pro PPHP106A Powered Two-Way PA...
How do i set p the pyle pdwm96?
Is it connected correctly? Try connecting something else to where it's connected and see if you get sound then.
Jan 31, 2014 | Pyle Pro PDWM96 Lavalier Wireless...
Speaker output not working on my Pyle Pro p3001at amplifier
The question of home repair vs professional depends upon your degree of confidence in your skill level.
Nov 27, 2013 | Pyle Pro P3001at Hybrid Amplifier & AM/FM...
My Pyle amp cut off and will not turn on
  • Ensure the device's power switch is on
  • Make sure the device has power connected.
  • Contact Pyle -->
    1-888-318-PYLE / 718-535-1800
Oct 20, 2013 | Pyle Pro PTA1000 1000 Watt DJ Amplifier
Amp on but no sound
Double check all of your fuses and make sure they are the corrects AMP. Other than that it sounds like the speaker wires came loose somewhere along the line. check on the subs and behind the deck. hope this helps
Apr 22, 2013 | Pyle PLA2678 POWER SERIES BRIDGED MOSFET...
Pyle dryver amp light protection stays on not green light stays red i have tried to disconnect everything and plug it back up but light stays red
check your subs disconnect them the try to power the amp up if it powers up the the subs have died and it could be a problem with that amp i suggest you get a better amp
Jul 09, 2009 | Pyle Dryver PLAD213 Car Audio Amplifier
No power when i plug it up !
HI, check to make sure the wall socket is live by, plugging another device into the socket. if the socket is live, this will confirm a internal issue that concerns the power sector of the unit.
Contact pyle for this repair.
***In some model, there will be an In-Line fuse located inside the unit on the power board or transformer. replacing this fuse(if installed), may fix this issue.(uncommon)
Jun 22, 2009 | Pyle Audio Players & Recorders
NO SOUND
Check to make sure you have a signal going into the amp.
Make sure Your speakers are still good.
Apr 09, 2009 | Pyle PLA3000D Car Audio Amplifier
Pyle Pro PCMX265W 8" Portable PA System with MP3 and DJ Efffects[...] Logo
90 people viewed this question
Top Pyle Audio Players & Recorders Experts
 Grubhead
Grubhead
Gerhardus Stroebel
Are you a Pyle Audio Player and Recorder Expert? Answer questions, earn points and help others
