Question about Exercise & Fitness
I have he safety key for th precor 920 treadmill Buena where does it go
5 Suggested Answers
SOURCE: I have lost the safety key for my Weslo treadmill
Hi I folded up a piece of paper several times to make it into a small rectanguler shape and inserted into the slot for the key and it worked.
The replacement key doesn't need to be magnet just small enough to fit the shap of the slot is fine.Mine was a Weslo cadence 1000 (bought in 2002)
Posted on Jan 10, 2010
SOURCE: i have a pro form performance j4 treadmill. i
It is just plastic. You can wedge a piece into the slot
Posted on Feb 02, 2010
  • 95 Answers
SOURCE: I have a Sportsart treadmill
I would think that it can't hurt anything to try another magnet but if you end up needing to buy another one here is one website that sells them: Sportsart TR20F safety key
Posted on Apr 18, 2011
  • 95 Answers
SOURCE: Where can I find a Precor 9.21 treadmill motor cover?
Do you know which version of the Precor 9.21 you have? There are a few different versions you can view here. Click on your version to view the parts list and look for "Cover, Motor" or "Motor Cover".
For instance, if you have the 9.21 (AYYZ), the proper motor cover is this part #5019749
However, this part #5005569 is listed as the proper motor cover for the 9.21 (F5), 9.21i (2X), 9.21s (F6), 9.21si (2Y), and a couple others. Make sure you have matched up your exact model number with the motor cover you need so do you not order the wrong part.
Posted on Jan 13, 2012
My Precor 9.41 si treadmill won't let me click the switch to the "on" position. When I go to push it to the "on" position, it resist and spring back to "off".
is the safety key inserted as there may be a connection to not allow the unit to operate unless the key is in position
Dec 03, 2016 | Precor Exercise & Fitness
Grandchild lost my safety switch for Precor treadmill , manufacturer no longer carries this model. Any work around available?
Hi Emily, The safety switch... If that's the plastic part with the steel plate inside it that attaches to the console and when you remove it the treadmill won't operate then try cutting the top off a can and using that until you find the safety switch...Good Luck.....CHEERS..
Apr 13, 2016 | Precor Exercise & Fitness
Stuck Key message won't go away-how to get rid of
please find an overview of safety keys for treadmills here as well as a direct link to purchase some :
http://www.treadmillsrepair.co.uk/2014/08/treadmill-safety-key.html
Aug 23, 2014 | Precor C956 Commercial Treadmill -...
Belt won't move. It says to reset safety switch. Can't find the switch
There is a red magnet or insert that it used as a safety key. If you lost it, you will need to buy another.
Mar 04, 2014 | Precor 9.21 Treadmill
Precor 9.35 Error 5
please see the details and proceed according. God bless you
Dec 12, 2012 | Precor 9.35 Premium Series Treadmill
How to unlock safety code for precor 9.35 treadmill
Procedure 2.3 - Accessing the User Parameter Program
This procedure allows you to
change the following settings:
• Set Measurement Units
• Enable/Disable Password
• Set User Name
Procedure
1. Plug the power cord into the wall outlet, then turn on the treadmill with the circuit breaker.
2. Press keys STOP,5,6,7,1 sequentially.
3. The display will momentarily read SELECT UNITS
4. The currently selected measurement unit will then be displayed.
5. Use the UP, DOWN arrow keys to toggle between U.S. STANDARD and METRIC.
6. Press the ENTER key to select the currently displayed measurement unit.
7. The display will momentarily read, PASSWORD
8. Use the UP, DOWN arrow keys to select either PASSWORD ENABLED or PASSWORD DISABLED
9. Press the STOP or ENTER key to exit the program.
Sep 27, 2012 | Precor 9.35 Premium Series Treadmill
Where is the saftey switch on the precor 9.45i treadmill
You are refering to Reed switch or Sensor switch or Speed Sensor? please indicate.
Some equipment can have the safety switch when you remove the Hood as security measure, for to avoid the machine goes on or Start ON .
Please specify.
sincerely.
Nov 06, 2011 | Precor 9.21 Treadmill
We lost the safety key for precore 9.21i. will anything else work
You may be able to jerry rig something but it's much safer and always recommended to get a new safety key... saving $20 or less is not worth the risk. Here is one place to purchase a new safety key for the precor 9.21i. I like to recommend ordering two to have a spare and avoid paying for shipping again if you lose another one.
Aug 29, 2011 | Precor 9.21 Treadmill
I have lost the safety key to my Precor 9.20S. Is there a way to bypass and not use a key
I do not know if you can use it without a safety key... that is kinda the point of the key. I hope you can figure out a way but if it comes down to it there are many places online where you can find a replacement, here is one: http://www.fitnessrepairparts.com/cart/ViewItem/5000774
Sep 29, 2010 | Precor 9.21 Treadmill
Precor 9.1 won't turn on, outlet is good. (When unplugged, switch is OK & stays in on position. Once plugged in, switch flips off and won't stay on.) Site wouldn't allow me to choose correct model -...
I'm guessing the internal fuse is blown, which is part of the safety feature when you pull the magnetic key off. You need to put the little magnetic key onto the "stop" area after each use, and it will re-set. If you take the key off "start" and the machine stops, you can't start again until you put the key on "stop". Once you do that, the main switch should work again.
Aug 21, 2010 | Precor 9.21 Treadmill
Exercise & Fitness Logo
16 people viewed this question
Top Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
