Question about Troy-Bilt 179cc 24" Snow Thrower Storm 2410 Electric Start
Engine lopes after it gets hot won't maintain full RPM
Started first pull and then half way through a 30 minute job the engine begins to lope and not maintain full RPM. Fuel was clean and good spark was maintained.
    Sergeant:
  • 416 Answers
Still something in that carb that needs to be cleaned out
Posted on Oct 29, 2014
Engine lopes 21.5HP OHV Inteck Briggs&Stratton How do I correct this LOPING problem? If I disconnect any one of the two spark plugs while the engine is running it smooths out. I had removed both the Choke...
It sounds like a dirty carburetor. The carb needs to be removed and cleaned. The loping problem you speak of is a tell tale sign that something is partially blocking a jet or passage in your carb. If you are not sure of how to do it, bring it to a repair shop. To set choke cable, you want choke valve wide open when lever is pushed in and valve closed when lever is pulled/ There should be a screw you can loosen to move cable forward or backwards to adjust. Throttle cable should be snug at low idle when lever in bottom position. There should be a set screw for low idle already set if it hasn't been adjusted yet. Same process to adjust this cable, watch that throttle valve opens completely when throttle lever is all the way up. Good luck, hope this helped.
Sep 08, 2013 | Craftsman Garden
1989 honda prelude check engine light on and won't hold charge
change the battery cables terminals you can get them at walmart for under 5 bucks last time I checked
Sep 29, 2012 | 1989 Honda Prelude
2001 ford taurus,lopes when first started,when cold.
intake manifoold leak check all vacuum lines replace all vacuum lines if look cracked ,spark plugs could be fouled out by leaking fuel injectors, clean fuel injectors,replace fuel filter,replace air filter,replace spark plugs and wires,do tune up see if it helps if not.could have leaking intake manifold gasket or leaking egr valve,use engine vacuum gauge check engine vacuum for intake manifold gasket leaks.
Sep 23, 2012 | Ford Cars & Trucks
Engine lopes at low acceleration
try pluging egr vacume hose fixed my problem also loped when going down road at steady speed. hope this helps
May 04, 2012 | 1995 GMC Sierra
Engine idles rough at red lights begins loping rpms drop to almost killing, then cycles back to normal, then repeats rough idle drop in rpms and loping, back and forth until I rev engine or take off
You could have a clogged fuel filter, if you haven't changed it in awhile. You could have a leak in the intake system somwhere also. When you slow down, you get less power to the engine. It may need spark plugs and wires as well, if in need for a tune up.
Mar 02, 2011 | 2001 Nissan Altima
Rough idle and engine will shut off after warm.
Check the exhaust manifold gasket. I have a 2003 SVT Focus I had a problem with it loping at low RPMs. I had a free flow exhaust system. When I bought a new exhaust manifold I replaced the gasket and the problem went away.
Apr 07, 2009 | 2001 Ford Focus
Engine Intermittent Stalling and Missing/Loping
***** is correct adn yoru issues are not a quick fix.. some sensor is acting up and /or computer is being told to do something .....get full scope done and dig towards cause that way
Nov 02, 2008 | 2006 Dodge Dakota
Troy-Bilt 179cc 24" Snow Thrower Storm 2410 Electric Start Logo
199 people viewed this question
Top Troy-Bilt Garden Experts
Jay Finke
Jay Finke
Roland W VanLue
Roland W VanLue
Tim Whalen
Are you a Troy-Bilt Garden Expert? Answer questions, earn points and help others
