Question about Dream Maker Spas EZS-UHH-GG-F
Pump light stays on and pump not running - Dream Maker Spas EZS-UHH-GG-F
My 2001 GMC sierra 2500 starts up but will not stay running and its throwing a light in the message center. What's my problem and how can I quick fix it to get it home??
What light is on? Possible fuel pump failure causing it to not stay running. Sometimes banging on the bottom of the fuel tank will excite the fuel pump into working. If banging on the tank makes the vehicle stay running, suspect a fuel pump problem and it will have to be replaced
Feb 03, 2016 | GMC Cars & Trucks
THE CAR WILL NOT STAY RUNNING
The car will not stay running ?How long ? dies right away ,runs for a bit , till warm ? Any lights on the instrument cluster lit or flashing ? Security ?
Sep 24, 2015 | 2000 Plymouth Prowler
1998 nissan quest service engine light will flash three times and then just stay on while im driving
run the fault codes to find the sensor that is putting the light on and replace/repair the faulty unit. It is simply very false economy to run tanks empty as the fuel pumps need fuel to lubricate the gears and if that is intermittent of not there that plastic gears fail and pumps are not cheap.
Aug 03, 2014 | 1998 Nissan Quest
Starts but will not keep running,changed fuel pump,,
If the security light is flashing, are you using a duplicate key? Some duplicate keys do not have the correct "chip".
Nov 25, 2013 | Chevrolet Cars & Trucks
Oil pressure light went on on my 2000 audi a4 1,8t. What should i do?
could be sender or pump. do not run the engine until you're sure you have a good pump. Does it blink on and off--coming on mainly at idle? This would be normal for an old engine. If it stays on and the pump is bad, you will ruin your engine. You can try replacing the sending uniot, as that is cheap compared to the pump, but don't run it long to check new sender. If new sender stays red, shut down and replace pump.
Sep 03, 2010 | 2000 Audi A4
Red bucket full light stays on.
If the bucket is full then the pump should be running, if the pump is not running it is a faulty pump motor, a faulty control board, a faulty level switch for the pump motor or the water level alarm float switch.
Jun 07, 2010 | Frigidaire FAP094P1Z Portable Air...
Wont stay running
if it will start with either it has to be a fuel issue. if the pump is good you need to check the power supply to the pump.
Jun 11, 2009 | 2004 Hyundai Santa Fe
84 toyota supra 5 speed man.
sounds like ecm. car starts but when it switches over to run setting from cranking setting the cumputer ecu doent activate the run curcuits which may control your fuel injectors. check to see if engine has spark. remove one plug wire from spark plug put it close to the valve cover if you see an arc then you know that you have spark. then also go to fuel pump in tank and check voltage on the power wire if you have good voltage and the pump doesnt make any noise while ur cranking then it may be a fuel pump if the pump is making way to much noise then check the fuel pressure by hooking up a fuel pressure gauge. all test are to be done while someone cranks the engine. noid light for the injectors, disconnect on injector electical connetor connect the noid light to the wire that u just unplugged from the injector. the light will flash while u crank , once it goes to the run circut the light will either stay on which will shut off ur car or the light will stay off which will do the same. if the noid light did what I said when it went to the run circut then it is what controls your injectors...ecm good luck....daniel
Oct 11, 2008 | 1984 Toyota Celica Supra
Dream Maker Spas EZS-UHH-GG-F Logo
Top Dream Maker Spas Clothing Accessories Experts
Da Doc
ray gallant
Are you a Dream Maker Spas Clothing Accessory Expert? Answer questions, earn points and help others
