Question about Sewing Machines
Bernina 830 record not picking up bobbin thread
Trifect7
  • 57 Answers
SOURCE: Bobbin thread not being picked up
This unfortunately sounds dismally like a timing problem. When a sewing machine makes a sudden mechanical stop as when a needle is bent slightly and hits the needle plate, sometimes the other machine bits revolve along further causing the needle to be introduced into the hook either to early or to late to catch the thread.
To test this, remove the thread, the needle plate and and the bobbin case. Replace the needle with a brand new one. Yes, again. Revolve the machine by hand via the balance wheel and watch closely as the needle goes into the hook region allow it to it move down and then just start to move up. If the tip of the hook is not pretty close to right behind the needle than it is more than likely a timing problem.
If the tip of the hook is behind the needle in the scarf (the slight hollow on the back of the needle) than it is not timing. Thread the machine normally like it is and watch what happens as you manually turn the machine via the balance wheel. The thread should catch and be pulled around the hook and let go.
Try this and then either you figured it out the problem or contact me again. Either way please vote. Thanks
Posted on Mar 02, 2008
SOURCE: Bernina 801 Sport
Did you clean out the lint under the plate?
Posted on May 18, 2008
  • 4 Answers
SOURCE: singer quantum sewing machine won't pick up bobbin thread
Try changing your needle
Posted on Dec 13, 2008
  • 136 Answers
SOURCE: will not pick up bobbin thread
Unusual for this machine. Check to be sure the needle is inserted with the flat side to the back of the machine. If it is, remove the needle plate, bobbin and bobbin case. Turn the hand wheel slowly toward you and see if the point of the hook is above or below the eye of the needle when the hook point is aligned behind the needle. If the eye is above the point of the hook the machine is out of time and best taken to qualified technician.
Posted on Jul 04, 2009
Sewtech1
  • 69 Answers
SOURCE: The thread from the needle that goes down to pick up bobbin doesn
make sure your needle's flat bit shows to the back and it is in deep anough. else your timing is out.
Posted on Jan 22, 2010
Needle threaded is stuck in up position will not return 830 bernina
Bernina 830 Record??? Or newer Bernina 830 computerized?
If it's a Record, could very well need a good cleaning and oiling. Older mechanical machines need periodic lube to keep them running smoothly and quietly.
Wheel on right side that controls the needle up and down is very tight...
Feb 11, 2017 | Bernina Sewing Machines
I have a Bernina 830. Using #03 foot....bobbin thread through the hole in the arm of the bobbin. Why does it not go in reverse to finish the buttonhole?
If it is the older Bernina 830 Record, could be some of the parts have seized due to lack of oil. Frequently, seldom used functions (levers, dials, feed dog control) are the first signs.
Be sure to move the dials/levers and apply oil there as well.
Dec 07, 2016 | Bernina Sewing Machines
Bernina 830 Bobbin case does not swing out
Bernina 830 / 880 Bobbin Error and Bobbin Sensor ...
? 2:53
https://www.youtube.com/watch?v=RzpprWzYEJY
Dec 17, 2014 - Uploaded by Bernina Boys
What to do when your Bernina 830 or 880 bobbin shows a question mark. It also shows you how to ...
[PDF]Dear BERNINA 830 customer, Congratulation
Jan 01, 2016 | Bernina Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
I have Bernina 830 embroidery machine. I'm still a novice with this machine. An upper thread broke and could only be removed from the right side. I know that this is a NO NO but I had no choice. I r
Do you have a manual?
http://www.ebay.com/sch/i.html?_from=R40&_sacat=0&_nkw=Bernina+830+manual&_sop=15
You may need some cleaning, oiling or maintenance?
Tips for cleaning and maintenance:
Oil the hook after having used the content of 3 to 4 bobbins. The machine
screen will display a reminder
Increasing noise of the motor and/or irregular
stitch formation can also be an indication that oiling is necessary
Remove any lint from the hook and the bobbin area, then remove the stitch plate
See instruction manual chapter Maintenance/Cleaning
YouTube videos:
https://www.youtube.com/watch?v=mlBNy33bd3U
https://www.youtube.com/watch?v=mV4z3EAyMz4 Bernina 830 or 880 Thread Nesting Troubleshooting
Feb 08, 2015 | Bernina Sewing Machines
Needle will not pick up bobbin thread (Bernina 830) despite tightening handwheel therefore no stitching. Have cleaned bobbin mechanism and have checked and rechecked bobbin threading. Have tightened
Make sure needle is inserted with the scarf(small indentation above needle eye) to the back and fully inserted. Otherwise it could be out of time which would require a technician.
Jul 10, 2012 | Bernina Sewing Machines
I have a Bernina 530 Record and i'm trying to but
You would be best to download an instruction manual for your machine as it explains clearly, with diagrams how to thread and insert the bobbin. You probably wont find the 530 manual however download a copy for Bernina 530-2 or 532-2 as they are almost identical to the 530.
Sep 25, 2009 | Bernina Sewing Machines
Old bernina 830 stitching problem: tight
Sounds like you need to adjust the tension. Probably a good idea to oil this older machine before you adjust. Also look for and clean out any lint or debris in bobbin case and around foot area.
Aug 29, 2009 | Bernina Sewing Machines
The needle thread will not pick up the bobbin thread
It looks right but its not. Try looking on the internet for threading instructions. The bobbin winds in two directions, I have never saw a Bernina but I have 2 new machines and the thread goes in and then threads back to the left. Its hard to describe. But if the bobbin isn't right it will not pick up the thread. Write to Bernina for instructions. There are websites that have the directions for free.
Nov 18, 2008 | Bernina Virtuosa 160
Sewing Machines Logo
90 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
