Question about Kenwood VR-605 Receiver
How to connect a kenwood surround sound receviver vr605 to t.v.
3 Suggested Answers
techman
  • 3130 Answers
SOURCE: Kenwood VR-605 display fading out
There is a cold solder connection on the display device, on the display driver board, or on or in the power supply that supplys the display voltage to the driver board. The only way you can repair it is if you have some soldering experience and or some electronic troubleshooting skills. If you go in and start poking around, and you poke at the wrong thing, It will smoke on you, as solid state electronics are very unforgiving when it comes to shorting out something, even if its for a blink of an eye!!! If you really like the unit, take it into a repair shop, as it should'nt cost to much to repair. If the units 3 to 6 years old, Maybe its time to think about upgrading to a newer unit??. Good Luck
Posted on Jul 30, 2006
dunnbiker
  • 8546 Answers
SOURCE: can connect kenwood equalizer ke-205 to a surround
Yes BUT...
The following is some boilerplate I made up that should explain some usage limitations.
Be advised that the engagement of any device in a Tape Monitor loop on a late-model Audio/Video Receiver will effectively tie the receiver down to stereo-only analog sound reproduction. I'll explain.
The connections themselves are fairly simple but it pays to understand what happens in the loop.
In general, any Line-Level external processor (EQ, dynamic range expander, etc) will go into a Tape Monitor loop on a receiver. A Tape Monitor, when engaged, sends the stereo analog signal Out to the Processor, massages it and returns it to the receiver via the Tape Monitor IN connectors to be passed on to the receiver's internal processes (volume, tone, whatever).
Old school analog stereo-only receivers consistently work this way. Newer digital and audio/video receivers introduce a couple of problems: 1) digital sound processing to simulate a variety of soundfields; 2) multiple output channels, either discrete or digitally-generated.
The latter requires that whatever signal is being processed experiences a maximum of one analog-digital-analog conversion.
EVERYTHING analog coming into the modern digital receiver is automatically converted to a digital signal for internal processing unless you choose a STEREO-only or STEREO-Direct setting. Consequently, no further external analog-digital conversions would be allowed if, say, a Tape Monitor circuit was activated, and a possible feedback loop could otherwise be created in a digital-sourced selection (output to its own input), so the unit is wired to treat the Tape Monitor as the first analog step in the process and defeats any pure digital sources.
In a multichannel unit, what would happen to the other channels if you sent ONLY the Front Left & Right out for processing? They would NOT be processed. That logical problem also plays into the decision to defeat digital sources if the Tape Monitor is activated. I don't totally agree with the engineers but that's the way it is. Nature of the digital beast.
Okay, back to the hook-up:
Receiver Tape Out (Rec) - to the External Processor (EQ, whatever) Preamp-, Rec, Line-In;
Receiver Tape In (Play) - from the External Processor (EQ, whatever) Preamp-, Play , Line-Out.
So, to sum up, you can only use the EQ or any outboard processor for analog stereo sources. If you actually want to use an analog recording deck you could place it within the typical Equalizer
Posted on Feb 05, 2011
Hooking up Kenwood VR505 to TCL Roku T.V. All I want is audio from the T.V. for Surround sound
Use an optical cable to connect them. Optical TV out to Kenwood optical in.
Oct 22, 2016 | Kenwood VR-505 Receiver
Avr kenwood kr v5090
Have you tried the "Simulated" surround setting?
If you don't get sound in "Simulated" mode then you have probably lost the surround channels.
If you do get sound then your "Media"
is not recorded with a surround "Track". or the surround "Processor" may have issues that need to go to the repair shop.
Mar 25, 2014 | Audio Players & Recorders
Optical hdmi
need to see the back of both units..
Jan 11, 2014 | Kenwood VR-716 6.1 Channels Receiver
Don't know how to hook up kenwood ka-994
Check the bellow link for the user manual of kenwood KA-994. In page number 4 of the user manual You can see how to make the connections to the receiver
Manual
Ajin
Mar 09, 2012 | Audio Players & Recorders
How do I connect my Kenwood VR-715 surround sound system, Dish Network receiver, and HD LCD TV together so the surround sound works? Can't figure out what goes in the input, the order of the connections or...
The best way to do this is to connect you dish network receiver is directly to the tv. Try to use the best video type possible. HDMI is the best, next is component and lastly is composite. This will take care of the video portion. Next, connect digital audio output to the Kenwood Receiver. I dont know what type of a digital audio output your dish box has, but your kenwood receiver has both optical and coaxial inputs so you should be fine there. Once you have both audio and video wired, change the inputs on both your tv and kenwood receiver to the inputs you are connected to. You might need to set up the kenwood to tell it that your running digital audio to it in the setup menus. Hopefully this helps, let me know if you need any clarification.
Good Luck
Jan 08, 2011 | Kenwood VR-715 Receiver
I have a kenwood vr-707 it gets surround sound on dvd/vcr but I can't get surround sound on just tv.
Well you have a built in decoder/surround processor that will detect a signal with the surround sound info(dvd/sat.receiver/cable converter etc.) and will then process it to the different speakers on your system. In the absence of that signal it will process it as standard stereo sound(two front speakers). You may want to look in your receiver functions/menu for simulated surround.
Hope this will help.
Nov 24, 2009 | Kenwood VR-707 Receiver
Kenwood VR-305 receiver surround speakers will not work
make sure that all input cables are in the correct positon also make sure that any inputs you are using don't have a macrovision in them that will also kill your sound due to copyright laws and stuff but main thing check all wires coming in to receiver and if you need more inputs go to walmart and get a rca splitter basicaly its a 1 in two out connection to add more cables in the input
Mar 16, 2009 | Kenwood VR-305
Kenwood VR6070 speaker/amp problems
unit needs repair. Look at the b speakers. Conect a speaker or two to the B position. If you have no sound than your surrond sound is ok and the unit is bad. Sound comes directly into the b speaker and not threw the surrond system. My 6070 has a cold start up problem. no sound. time to purchase a new one. to costly to repair.
Dec 30, 2008 | Kenwood VR-6070 Receiver
Operating Manual
Hi - You can download the manual from the link underlined in blue below:
KRF-V5060D
Please update the question & let us know if the information given was useful to you - Good Luck!
Jul 26, 2008 | Kenwood KRF-V5060D Receiver
Kenwood VR-605 Receiver Logo
35 people viewed this question
Top Kenwood Audio Players & Recorders Experts
 Grubhead
Grubhead
Don Hart
Are you a Kenwood Audio Player and Recorder Expert? Answer questions, earn points and help others
