Lcd tv ghost images
Ghosts and pixaly on block colours
  • 395 Answers
SOURCE: Samsung lcd tv le40r8
if the unit is under warranty call samsung for the nearest authorized repair place. the problem is a bad main board.
Posted on Feb 24, 2008
  • 58 Answers
SOURCE: Blue ghost image in middle of the tv
You have a defective light engine and you do not have to be under warranty for Hitachi to replace this part. We just went through this and here's what you need to do. Call Hitachi's customer relations department at 800-654-7013 and tell them that you have a defective light engine. They will act like they've never heard of this problem but they have. They will give you the names of some certified dealers in your area to call. Once a tech comes out and confirms that it's the light engine, call Hitachi back and they will send a brand new light engine to the dealer and Hitachi will cover the cost of the part (cost $1500).
Here is the deal, if you're under warranty, Hitachi will cover the part and the install. If you're not under warranty, all you pay is the install. Our install cost $400. Others on this site have paid $200. Do not let anyone tell you that you have to pay for the light engine part...you do not. Hitachi has not recalled this part but they are replacing it for free. Also, deal only with Hitachi customer realations number that I listed. Good Luck!
Posted on Mar 07, 2008
mfspencer
  • 58 Answers
SOURCE: LCD picture distortion.
This is caused by a failure of the main board. The failure causes the refresh rate of the unit to be off creating a trailing or ghost effect. This will require a technician to replace that board though. Hope this help.
Posted on Apr 02, 2008
  • 93 Answers
SOURCE: Ghost Images - Pastel colored images
There are 3-4 issues in here,one of them might be a bad convertion part in there. It is not worth your time and money to guess the issue,if it is under warranty,you should take it back.If not,repair tech. would be the way to go!
solutiondoct
Posted on Nov 11, 2008
  • 3 Answers
SOURCE: Ghosting on LCD
He may just be giving up too soon. Again, does this happen on every channel no matter what is plugged into it?
If replacing the cables doesnt help, try giving sony tech support a call and see what they suggest. It wouldnt hurt to get a professional opinion. Plus if your warrenty has expired and they offer to repair it at a cost, im sure it will cost less than a new 40" TV
Not sure what country you're in so go to the website below and choose your country then look for their contact email or phone number. I'm sure they will be helpful, thats what theyre there for.
http://www.sony.com/
Have your TV model number (usually on the back of the set) and details of the fault handy. They may also ask where you purchased it from.
Posted on Feb 10, 2009
Sony bravia 52 kdl xbr ghosting
Michael, does the ghosting go away of you tap the set? Or if you turn off the set and let it cool off and turn it back on, is the ghosting still here? One of the most common causes of ghosting or double image problem is due to a defective LCD panel tab. Sony's are known for this problem. I would recommend getting a diagnoses done on the set to be sure. If it turns out to be a LCD tab problem, the only true fix is to replace the panel.
Nov 24, 2012 | Sony BRAVIA Televison & Video
Hey, i have a samsung ln32b360, just 2 months old. worked beautifully when i got it, but recently it started ghosting a little in very specific situations. then it started ghosting a lot, but only in dark...
First,If there are double images or "ghost" images on the TV's picture, check the cable connections and make sure they are secure.Because the loose cable connection would be a chance for the ghost picture
But if the cable is perfect and if you still get ghost picture then here is the solution:
The LCD Panel is defective. The problem is the T-con board that is used to decode the signal from the main board to the LCD Panel. The only way to fix it is to replace the whole LCD Panel or T-con board if possible. The T-con will cost about 1/10 of the price as the LCD panel but except for a few new models, the T-con is not available. The LCD Panel is very expensive (usually from $600-700 for a 32" Sony).
The reason is that Sony makes the T-cons for each individual TV with different specs to match that of the LCD panel because of the low threshold for error between the LCD Panel and the T-con.
Its best to avil warranty and change the panel...
Please leave me comment, if you need furher assitance
Rnj VINODKUMAR
Oct 27, 2009 | Sony Bravia KDL-32ML130 32 in. LCD TV
"ghosts on sony projection tv
Hi friend
its colour wheel problem you should change it,,,first check if any burnt parts resistors,,,,,common problem is colourwheel,
check it...........thank u,,,,,,
May 03, 2009 | Televison & Video
Ghosting on LCD TV
get a big heavy brick and throw it at the screen this fixed mine
in no time and got a sony instead
Apr 08, 2008 | Televison & Video
Ghost image on sony lcd 5 years old
This problem is a defect in the optics block. There is however an adjusment procedure to correct this problem. Please send me and email to misssiontracetv@msn.com and I will send you back the detailed alignment process on Monday.
Feb 23, 2008 | Televison & Video
Tri coloured ghosting
maybe...it might need service mode aligning be a tech
Jan 02, 2008 | Televison & Video
Ghosts or shadows around images
I always start my Hitachi research at their website.........
www.HitachiServiceUSA.com...................T.
Nov 28, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
2004 Phillis 47 " flat panel ghost image
Yes, it called ghost image. You can try to go in the service menu, and scroll to ghost image. Turn tv off, wait till red light stops blinking, and then on the remote press the input button. at the same time press the power button on the tv. this should put you in the service mode. If nervous about this call tech assist at Hittachi.
Nov 25, 2007 | Hitachi 50V500 50 in. HD-Ready LCD...
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
