Question about Bosch Pmf 180 E Multifunctional All Rounder- Deluxe Set With 24 Accessories
Bosch pmf 190e just stopped working.fuse ok lead ok
My Miele Hepa 5281 stopped working for no apparent reason. No burning smell etc. I've replaced the fuse on the plug but it's still not working. Any suggestions on what could be wrong a
Could be a break in the mains lead. Usually where it enters the machine and gets stressed. Some motors have a thermal cut out or thermal fuse fitted to them. If the motor overheats it breaks the circuit. Some of them reset when they cool down, some are a one shot device, when it blows it has to be replaced. Could also be faulty brushes on the motor not making proper contact because the are sticking or worn.
Dec 18, 2014 | Miele Vacuums
Stopped working
the next step would be continiuty to test lead. Measure live, neutral and earth if all ok the motor brushes need to be inspected. Set multimeter to buzzer and test from plug to hoover one at a time.
Nov 05, 2013 | Vacuums
I know this is an OLD post - but just in case anyone else comes across this question/problem - the fix is here - worked for so many people . . . http://jb-service.blogspot.co.uk/2013/04/bosch-pmf-180e-multi-tool-240vac.html
Aug 21, 2013 | Bosch Pmf 180 E Multifunctional All...
Panasonic vacuum cleaner MC-5030 stopped and don't work
Unplug, check if brush has cord wrapped. Check for fuse, if applicable.
Check power lead in another supply socket. Check for reset button, if applicable. Contact Panasonic technical support for suggestions before heading to service centre.
Jun 17, 2012 | Vacuums
Nutone cv353 unable to stop
You may have a stuck relay or one of your access port switches may be bad. According to the owners manual: "A complete check of all Wall Inlet and Power Unit low voltage control lead connections (external yellow leads). Turn system off by removing fuse or tripping circuit breaker at
house fuse box."
Dec 27, 2011 | Broan-NuTone CV353 Central Vacuum
Vacuum cleaner....will not switch on.....when I press the on / off switch...it appears as if it is stuck...there is no click of the on off switch to indicate switching on/off. power source OK.
The on/off switch is first to be examined. Let an accredited technician examine it. The carbon might be too thin. The fuse might also busted. Thank you for asking.
Jun 14, 2011 | Bosch Vacuums
No motor action when the power is ON
I have the same problem with mine -- precisely the same model BSG 81335UC. It feels like the power button switch isn't working properly.
Dec 31, 2008 | Bosch BSG81360UC Premium Health Guard...
Vacuum will not power on...
your repairman missed the thermal fuse in the motor compartment
Aug 10, 2008 | Bosch BSA2200UC Bagged Canister Vacuum
Dyson
Hi .
Could be the on off switch faulty. Or a internal break in the mains lead this usually occurs where lead enters machine.
Try wiggling the mains lead & see if it starts & stops.
http://dysonmanuals.llc.nu/
Chris.
Dec 25, 2007 | Dyson DC14 Full Access Bagless Upright...
Bosch Pmf 180 E Multifunctional All Rounder- Deluxe Set With 24 Accessories Logo
51 people viewed this question
Top Bosch Vacuums Experts
Cleverer2
Billy Detlefsen
ray gallant
Are you a Bosch Vacuum Expert? Answer questions, earn points and help others
