Question about Kenmore Elite 78722 78729 Bottom Freezer French Door Refrigerator
Kenmore 70312 ice maker stopped making ice - Kenmore Elite 78722 78729 Bottom Freezer French Door Refrigerator
the dr
  • 447 Answers
SOURCE: Ice maker not making ice.
These Icemakers have plastic gears on the modules that are breaking, also some have thermostats that are malfunctioning. I recommend haveing an experianced tech look at the unit to see if you need the new upgraded indoor ice maker.
Posted on Jan 15, 2008
  • 172 Answers
SOURCE: Kenmore Coldspot w/Ice Maker Not Making Ice
hi LOP7,
In most cases you can easily solve this problem.
step one would be to make sure your freezer is getting cold enough. If you have icecream in your freezer is it frozen solid or is it soft. Most icemakers cycle around 0 degrees and if your freezer is not getting to 0 then it will not cycle and it will not make ice.
Step two would be to make sure you icemake is cycling. To do this simply lift the little shut off arm on your icemaker and wait about an hour then go back to the icemaker and drop the arm down. The icemaker should start going through a cycle. You should notice the arm slowly begin to raise and the ice dispencer fingers will begin to turn. Then you will hear it call for water. You may hear a humm.
If the freezer is cold enough and the icemaker is cycling that only leaves the inlet valve. replace the valve and enjoy the ice.
If the freezer is cold enought and the icemaker does not cycle, then you have a bad icemaker. Simply replace the icemaker and viola.
Third if the freezer is not cold enought 0 defrees. Then you may have a defrost problem. In this case post more info and I will be happy to help. Good luck mca0824@aol.com
Posted on Apr 30, 2008
huuum
  • 750 Answers
SOURCE: kenmore elite, will not make ice, but it does dispeanse
Dear tnsmarchini
You said, Kenmore elite, ice maker in door...........................???What????????
And we need more detail than Ice maker in door.
What does your ice maker do?
Posted on Sep 27, 2008
TheMobilian
  • 8220 Answers
SOURCE: Ice maker not working Kenmore model 106.55226400
Look for an ice cube lodged in the fingers IM. Get a hair dryer and melt that dude. No ice cube? Add some water to the IM mold. If it kicks out some ice but makes no more then you is gonna need a water valve. If it don't kick out no ice then you is gonna need a ice mold thermostat. Either one is very easy and cheap to fix. let me know Kimosabe.
Posted on Mar 06, 2009
  • 351 Answers
SOURCE: Kenmore Ice Maker Not Working
Probably need a new ice maker, whirlpoolpartssurplus.com
Posted on Jun 23, 2009
My kenmore refigerator ice maker stopped making ice.
Could be that the solenoid that feeds water to the ice maker is not working properly.
Also make sure that the freezer temp is at least 10 degrees or less - if not the ice making cycle will not commence.
Mar 12, 2017 | Kenmore Refrigerators
Kenmore WR30X0318 Ice Maker Stopped Making Ice
The ice maker uses a internal thermostat that starts the cycle of dropping the ice and refilling with tap water. If your water control valve works filling the ice maker then the problem is the ice maker itself that will need replaced. Unfortuantly the ice maker you have has no rebuildable parts and will need to be replace with a=> WR30X10093 Ice Maker Assembly
Or here=> WR30X10093 Ice Maker Let me know if you have questions, Thanks Sea Breeze
Nov 14, 2012 | Kenmore Refrigerators
I have a Kenmore Model 106-55602400 Coldspot and the icemaker stopped working. What do I do?
The control module has failed on the ice maker. You can replace the control module alone, but I would replace the ice maker completely.
Here is a link for the control module.
Here is a link for the new ice maker.
Oct 15, 2012 | Kenmore Refrigerators
Ice maker stopped making ice
Here is a tip that I wrote about the reasons why ice makers do not work.
Ice Maker Problems and Ice Maker Troubleshooting
heatman101
Dec 26, 2010 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
I have a side by side Kenmore fridge, model# 106.53532300. The ice maker has stopped making ice all of a sudden. Everything else works fine.
Ice makers do go bad and it is inevitable. Check the ice maker connection and make sure that all is in order. If all seems okay and the ice maker does not work, replace it.
Dec 19, 2010 | Kenmore Refrigerators
Ice maker stopped working...water works, ice tray has water, ice maker is turned on. curious if I should just replace the motor or if it could be something else
If your ice maker is not making ice and you poured water into the ice maker, that would indicate the ice maker is not cycling. If you have any make or model except a whirlpool, kitchenaid or sears kenmore, if you replace the ice maker, you will be making ice in no time. If you have one of the aforementioned brands, AND the ice BUCKET is mounted on the door, you will have to replace the electric eye boards on either side wall as well, as these often short, damaging the icemaker electronics in the process.
Nov 09, 2010 | Kenmore Refrigerators
Ice maker stopped making ice. Now water continuously drips.
Replace the water valve behind refrig , where the wall water line connects to on refrig .
Aug 31, 2009 | Kenmore Elite 22.4 cu. ft. Bottom Freezer...
Jan 14, 2008 | Kenmore 21.7 cu. ft. Top Freezer...
Kenmore Elite 78722 78729 Bottom Freezer French Door Refrigerator Logo
37 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
