Question about Toro Power Max 726 OE Snowblower - 37771
Vibration when auger is engaged in Toro 726 oe
    Sergeant:
  • 416 Answers
Be sure to check pulleys for a rock or anything else lodged in there
then check rear bearing for alot of play up and down
Posted on Oct 29, 2014
How do I adjust the belt ona Toro 726 snowblower
There should be a tension pulley between the main pulleys. Usually it is mounted on the side wall and can be adjusted with a nut and bolt.
Mar 16, 2016 | Toro Power Max 726 OE Snowblower - 37771
Put new belt on for 2nd stage still does not work augers work
Sounds like roll pin has broken that is on it. Look for a hole where pin slides through shaft. Use a hammer and punch to push out broken piece out. Make sure outer hole matches up with inner hole.
Mar 02, 2015 | Toro Power Max 726 OE Snowblower - 37771
Pull starter won't pull
ALL-- Power Equipment-- needs to be inside & warm,
NOT in an outside shed
Have to warm it up inside-neighbors garage!
Feb 28, 2014 | Toro Power Max 726 OE Snowblower - 37771
Left auger does not engage/spins freely
The shear pin is sheared off. Somewhere along the auger, you'll find a hole drilled all the way through it. The shaft inside also has a hole drilled all the way through it. Compare the two augers - the holes are USUALLY in a straight line with each other (when one is up/down, the other is also up/down).
Get a replacement shear pin (DO NOT use a hardened bolt!) and put it through the holes when the auger holes are lined up with the axle holes.
Feb 19, 2014 | Toro Power Max 724 OE 24 inch 205cc Two...
Problems shifting toro power max 726 oe snowblower
adjust the cable easy to do , get the manual or just look good at it ,
Feb 04, 2014 | Toro Power Max 726 OE Snowblower - 37771
No spark at all
Clean the magneto . check the wires and ground .
Dec 08, 2013 | Toro Power Max 726 OE Snowblower - 37771
Toro Power Max 726 OE Snowblower - 37771 Logo
217 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
Mike Squire
Are you a Toro Garden Expert? Answer questions, earn points and help others
