Question about Singer Sewing Machines
Foot controller jf-1000
The sewing machine will sew for an inch and the stop when the foor control is pressed
    New Friend:
Foot controller (JF-1000) works some times, then not others, checked with multimeter, turned out that variable slide resistor inside of foot controller is bad. Could move resistor by hand (pulled up on slide bar of variable resistor inside of controller {after removing top cover} with fingers, which made contact inside of the resistor and machine sewed fine, then released slide bar and machine would no longer sew properly).
foot controller jf-1000 - foot-controller-jf-1000-jpvdpqnrjn0ehprarxw5z4s0-1-0.jpg
Posted on Jun 05, 2015
  • 6 Answers
SOURCE: Elna Super will not stop running
Bspring- I have found there is a suppressor inside the machine. If you email me at my business email I will forward the info to you so you can repair it your self.
ann@littlegemsales.com
It may take me a while to check for your email but I have Sue59 with the same machine and problem as well so I'm glad to help. Great machines. Ann
Posted on Feb 21, 2008
  • 69 Answers
SOURCE: Machine slows down,stops, starts again. Foot control problem?
Yes it does sound like a faulty foot control. The power cord is probably fine, you just need the controller. Ebay is a good source for parts.
Posted on Feb 09, 2009
  • 96 Answers
SOURCE: Husqvarna 2000 sewing machine foot pedal stuck on but not pressed
you may need to take foot pedal apart and clean it the contacts inside may be dirty and causing it to stick
Posted on Dec 13, 2009
SOURCE: wiring a foot control pedal for Singer
I have a singer advance 7422 and the outlet for the foot controller is kind of broken. A few days ago a little round black thing fell out of the outlet and now when i try to connect the foot controller it is very loose and the machine doesn't run. what should i do?
Posted on Jun 28, 2011
aeroseek
  • 55 Answers
SOURCE: foot pedal dead, machine keeps sewing!
Sounds like your foot control is faulty.
I can supply foot controls for 99% of sewing machines.
Mike
sewingmachines2004@yahoo.co.uk
http://www.sewingmachineswales.com
Posted on Oct 10, 2012
The brother sewing machine is a PS-1750 . What happened when you started sewing and the foot control is moving ,but the machine is not.
could be something wrong with the motor, or a wiring problem, make sure the foor pedal plug is making secure connection with the machine also
Jun 11, 2015 | Brother Sewing Machines
My Elna Pneumatic Air continues to sew even when the foot control is no longer pressed. What is going on?
theres a reostat in the machine thats sticking...try a new controller but its probably the internal reostat
Sep 19, 2014 | Sewing Machines
E 1 error message
Make sure you lower the presser foot before continuing the operation.
The foot controller was pressed (or the start/stop button
was pressed if the foot controller is not connected)
and the reverse/reinforcement stitch button
was pressed while the presser foot was raised.
Mar 01, 2014 | Brother CS6000i Computerized Sewing...
CS6000-i E5 showed on screen, now my backstitch doesnt work. Is this an adjustment I can make?
The start/stop button was pressed while the foot controller
was connected.
Disconnect the foot controller,
and then press the start/
stop button. Otherwise,
operate the machine by
using the foot controller.
Hope this helps.
Feb 13, 2014 | Brother CS6000i Computerized Sewing...
What does E5 means
On automatic sewing machines, the start/stop button was pressed while the foot controller was plugged in. Unplug the foot controller if you are using the automatic function.
Need more detailed information about Brother XL 2600i ?
Sep 30, 2012 | Singer 6180 Sewing Machine
When i turn on my sewing machine and press the foot control my machine beeps and e2 error appears
bar tack stitch was selected and the foot controller was pressed (or the start/stop button was pressed if the foot controller is not connected) while the buttonhole lever is lowered.
Raise the buttonhole lever before continuing the operation.
Jun 26, 2011 | Brother CS-6000
I can't start to sew on my 830. The foot control is recognized(the start/stop button light goes off when I press the foot control), but does not make the presser foot come down. It worked 15 minutes ago...
If you lower the pressure foot before you press the foot control does it sew then? If so, then some how in your setting menu you auto pressure foot setting has gotten turned off.
Apr 23, 2011 | Bernina Artista 180
I cant get the machine to sew a buttonhole.
I am not familiar with your machine, but some buttonhole attachments require a lever be lowered and inserted into a tab.
Review your manual to see if a step was overlooked.
Mar 07, 2010 | Janome Sewing Machines
I need to know how to thread a bobbin?
TRY THIS, itma not be your model, but should help Title:
ac093.jpg Pre-tension disk ac094.jpg Bobbin winder shaft ac095.jpg Bobbin
1. Pull up the spool pin as far as possible, and then put a spool of thread on this pin. windingbobbin_a0991.jpg
2. Pass the thread around the pre-tension disk. Make sure that the thread passes under the pre- tension disk.
windingbobbin_a0992.jpg ac098.jpg Pre-tension disk c_b4.jpg Pulling it in as far as possible
Caution If the spool of thread is not in the right place, the thread may tangle on the spool pin.
3. Pass the end of the thread through the hole on the bobbin from the inside of the bobbin. windingbobbin_a0993.jpg
4. Put the bobbin onto the bobbin winder shaft and slide the bobbin winder shaft to the right. windingbobbin_a0994.jpg
5. Turn the bobbin clockwise, by hand, until the spring on the shaft slides into the groove of the bobbin. windingbobbin_a0995.jpg ac099.jpg Spring on the shaft ac0991.jpg Groove of the bobbin
7. While holding the end of the thread, gently press the foot controller or press start/ stop button (for models equipped with the start/stop button) to wind the thread around the bobbin a few times. Then stop the machine. windingbobbin_a0997.jpg
Note
  • If the sewing machine is to be operated using the foot controller, connect the foot controller before turning on the machine.
  • When the foot controller is plugged in, the start/stop button cannot be used to start sewing (only for models equipped with the start/stop button).
Caution Make sure you follow the instructions carefully.
If you do not cut the thread completely, and the bobbin is wound, when the thread runs low it may tangle around the bobbin and cause the needle to break.
9. Slide the sewing speed controller to the right (to set the speed to fast).
(For models equipped with the sewing speed controller.) windingbobbin_a0999.jpg ac0992.jpg Sewing speed controller
10. Press the foot controller or press start/stop button (for models equipped with the start/stop button) to start. windingbobbin_a18.jpg
11. When the bobbin seems full and begins spinning slowly, take your foot off the foot controller or press start/stop button (for models equipped with the start/stop button). windingbobbin_a19.jpg
12. Cut the thread, slide the bobbin winder shaft to the left and remove the bobbin. windingbobbin_a191.jpg
13. Slide the sewing speed controller back to its original position (for models equipped with the sewing speed controller). windingbobbin_a192.jpg
Caution Not winding the bobbin properly may cause the thread tension to loosen, and may break the needle.
woundbobbin3.jpg ac0993.jpg Wound evenly ac0994.jpg Wound poorly
Note
  • When the sewing machine is started or the handwheel is turned after winding the thread around the bobbin, the machine will make a clicking sound; this is not a malfunction.
  • The needle bar does not move when you slide the bobbin winding shaft to the right.
Sep 02, 2009 | Brother LS-2125 Mechanical Sewing Machine
Sewing Machines Logo
470 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
