Question about Maytag Performa PAV2200
Water out of washing machine.
My drain hose always seems to let water leak at the wall connection.  I have tried stuffing cloth and paper towels in there to block the water from coming out all over the floor.
  • 64 Answers
Sounds like the machine is not at fault. The problem is probably the pipework that takes the water out of the building, it could be made up with lime & wash powder residue. Try running some water into the wall outlet pipe, & see if it overflows, if it does you need to dismantle & clean it
Posted on Oct 26, 2007
SOURCE:
WASHING MACHINE WHEN TURN ON WATER IT STARTS TO LEAK
Check your drain pump, pour 3-4 cups of water in tilt the machine backand secured. Look to see if the pump is wet. The pump is located on top of the motor . Check the tiny hose on the side of the tub. You can use paper towel to touch which checking the towel for wetness. Check all the drain hoses.
Mar 19, 2013 | Kenmore 24032\24036 Top Load Washer
Water leaking from my Maytag Neptune model FAV6800AWW Serial number 15646382GA Leaks during wash cycle imediately and during complete cycle. Enough water to saturate 2-3 towels and clothes come out...
Could be a Tub Seal leak my 1st choice. Could also be a leak caused by a cracked outer tub, issues from the hoses from the drain line connections to the drain pump, drain pump and or drain line.
Are you going to try to DIY the fix?
Sep 07, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Water is not draining. I did pull out the washer drain hose and cleared but still not draining. Appears stuck in cycle. Water is sitting in the washer
Hi Friend, welcome to fixya.... This happens sometimes, usually when you stuff too many towels or clothes in the machine. Next time it happens, open the machine, and rearrange the clothes/towels with your hands.
Then turn the machine back on and start it where it left off, not simply popping the button back on, but turning it all around through a cycle and setting the button where you left it on 'rinse'. If it doesn't work simply by rearranging the clothes, pull out one or two wet towels and try again.
If it is due to over stuffing, the rinse cycle should drain and go into spin normally. If this doesn't work then call a maintenance person. It would be awful to have spent money only to find out from the maintenance man that it was an over stuffed machine the whole time;)
if you think that i helped you please rate it\\\\\\\\ thank u...
Apr 03, 2010 | Frigidaire GLTF2940ES Front Load Washer
I have never liked my lg and now it seems that
You might check the water inlet valve on the back of the machine where the water hooks up. There should be a blue plastic water valve. remove the water hose on both sides hot and cold. At the blue water inlet valve inside the connector there are small filtering screens (similar to an areator valve on your sink faucet) They may be clogged by sediment and this would cause your low water issue and possibly the smell. Simply pull out the screens with a pair of needle nosed pliers and replace. Hope this helped
Dave
Nov 05, 2009 | LG WM2016C
We think we overloaded the machine with bath mats and since then the water did not drain and the machine does not work any more. All buttons are flashing.
your pump is totaly clogged with the math matt sand
you should be able to access the pump from the rear wall,
bring towels you will loose water
remove both hoses from the pump and ensure they are clear, wash the drain hose completly run water through it
make sure you pump is clean and free
to spin
reassemble and and plug back in
errors should clear
Oct 23, 2009 | Washing Machines
Intermittent water on floor
Check the inlet valve hoses, even if inlet is at the back, the water may drip down and flow on the front part on the machine. There you also have the PUMP, a faulty pump may leak intermittently.
Here you get all diagrams and parts for your appliance.
Sep 25, 2009 | GE WJSR2070B Top Load Washer
Washer does not remove water in final spin
If washer hums when it should spin, and the washer will not drain, you may have 2 issues.
First check that the drain pump, drain hose, and wall drain are free of debris.
The washer may not spin properly if the drain system is not operable.
Once you are sure the washer drain pump, drain lines, wall drain, and drain hose is okay, run a test wash.
If the washer hums but now drains, you fixed one issue.
If the washer still hums, you may have a bad belt, motor coupler, motor itself, etc...
Check parts for wear and replace as necessary.I pulled the drain impeller and found a sock from my little guy stuck in there. Fixed!
check all water outlets to make sure there is nothing blocking the pipes.
you could also go to this link it might help you out..... Washer does not remove water in final spin Google Search
Oct 24, 2017 | Maytag MAH6700AWW Neptune Front-Load...
Clothes washer leaking
First of all, check to make sure the drain hose is inserted properly in the drain pipe in your wall. Second, if that's not the problem, check to make sure the drain hoses inside the machine are tightly connected and not cracked. Tighten or replace as necessary.
Sep 25, 2007 | GE WCXR1070A
Washing Machines Logo
51 people viewed this question
Top Maytag Washing Machines Experts
jimorris77
Sheldon Dedek
Bill Long
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
