Question about Electrical Supplies
Honda eb 6500 generator starts then stalls - Electrical Supplies
5 Suggested Answers
EduTech
  • 54 Answers
SOURCE: Honda 6500 generator overheating and shuting down.
My hunch would be Bad thermostat stuck in closed position
Is load greater than spec?
Does it emit blue smoke = oil burner, needs overhaul
Does oil pump work to full capacity? (is there a pressure gauge?) Does it use a lot of oil?
1ak+f4pj7cbm32cuniyi2gaaaaaelftksuqmcc
Posted on Jun 26, 2009
jan mczeal
  • 632 Answers
SOURCE: generator starts but does not generate power
  1. Check for any blown fuse and replace. It can be traced directly from the output lines.
  2. Check field excitation. The field excitation is supplied by the battery to the excitation coil through a pair of carbon brushes. If the brushes are worn out, no excitation field is supplied and no output is generated. Replace carbon brush if found worn-out.
  3. Use an analog multitester to check the continuity of the carbon brush and the field coil.
Posted on Sep 25, 2009
  • 342 Answers
SOURCE: how do you separate the generator from the engine
unbolt from the engine then it will just pull of leaving the armature still in place on the crank shaft you may need to use a puller to get it moving
Posted on Apr 04, 2010
Mr BrokRench
  • 1623 Answers
SOURCE: Our Honda EB 3500 generator
It's either not getting enough fuel, or the govenor is not working. When the engine is running, watch the throttle linkage between the carburetor and engine, looks like a bent wire. When you throw a load on it, it should move to give the engine more power, if it dont, try moving it by hand.
If that appears to be working ok, check the fuel line from the tank to the carb for good gas flow.
You can also remove the float bowl on the bottom of the carb, it's a round bowl on the bottom of the carb with a bolt in the middle of it...clean it out and check the float. The float looks like a little catamaran, make sure it is moving freely up and down. That is about all you can do without removing and cleaning the jets in the carb.
Good luck, & i hope this helps.
Posted on Aug 27, 2011
Start the engine
I assume you refer to a 6500 watt Honda, if it's electric start/and manual(pull cord) First supply a 12 volt battery /if you haven't put fresh gas in it do the best you can to remove all the old gas from the tank and you should find drain screws and small hoses on the lower part of the carburetor. After completing this step add about 1 gallon or so of fresh gas, remove the air filter system from the face of the carburetor ,with a small squirt bottle put a tea spoon or so of gas into the of the carb, close the choke and turn the key, if it fires let it run with the choke closed for only a few seconds then slowly open the choke fully, if the engine stalls close the choke and start the engine again do not leave the choke closed for extended periods as this will cause engine flooding and spark plug failure. Also be sure you have inspected the existing spark plug to be sure it's clean if there is any question about the plug change it.
BR
Oct 20, 2014 | Honda 3000 Watt Portable Generator
I've just got a wireless remote for my Honda 6500 ,after pressing the arm button and then the start button I hear a click but no start
I have the same remote start but I could never get it to work so I just gave up . I hope you find the solution I would like to use mine .
Dec 03, 2013 | Honda Generator Wireless Remote Start Kit
I have a Honda EB 7000I generator. It runs for 7-10 seconds then stalls. When it stalls the red LED overload light comes on. I just put a brand new Inverter in it. Since it sat awhile with a bad...
As silly as this sounds, Harbor freight toold generators by "Predator" will shut down if the generator is not on level ground, and the oil level is not at the desired level, crazy but there is an inbuilt oil level sensor. maybe this might be the answer. hope iy helps, good luck.
Oct 19, 2013 | Motorcycles
Honda eu 6500 Error e21. First time using it and the machine is new. How to fix it? Sorry there wasn't category for generator
check oil levels as generator will not start if oil level is low. this is a built in safety device on most generators and one of the leading causes of returns to stores />
Aug 03, 2013 | Garden
Honda eb5000 generator
I have a EB-5000 model B 50 Honda generator the high idle works but can't get it to idle down, I change the switch because it was broke, I looked all springs are there, when I put my finger on the governor rod and pull it back idles down, any suggestions
Apr 16, 2013 | Honda Eb5000 Eb7000 5000 7000 Generator...
Powerboss 6500 won't run tools
powerboss generator wont start,,fresh fuel,fire to plug,clean float bowl,,,,,,honda gtx 390 motor,,,,13 hp,,,help
Oct 14, 2010 | McCulloch 13HP 338 Cc Portable Generator #...
I have a honda 6500 generator. before startup main main circuit b
you needsto replace the main breaker you can get the part at your honda dealer
Jan 24, 2010 | Hammering
I have a 6500 lp onan marquis generator in my rv. It starts then stops after 15 seconds or so. I did a code check on it using the manual and it read code 47. Controller not reading generator running. Any...
ONANS ARE PRETTY QUIRKY AS IT IS NOT CONSUMER FRIENDLY. THE GENSET IS DESIGNED FOR ROUTINE AND SIMPLE MAINTENANCE PERFORMED BY THE OWNER, AFTER THAT, U WILL NEED TO TAKE IT TO THE NEAREST DEALER OR CUMMINS DIESEL REPAIR SHOP.
Jan 10, 2010 | Watts Onan Portable Generator - 5000 ,...
Generator starts but does not generate power
Sep 25, 2009 | Honda Electrical Supplies
Electrical Supplies Logo
43 people viewed this question
Top Electrical Supplies Experts
Craig Butler
Craig Butler
Steve
Gene Haynes
Are you an Electrical Supply Expert? Answer questions, earn points and help others
