Question about Reddy Heater-30,000 BTU Propane Forced-Air Heater
How work reddy 30,000 btu propane model tb 100 have no manual
  • 188 Answers
SOURCE: 150,000 BTU propane Reddy Heater shuts off after ignition
Is there a frost line on your LP tank, if so you may need to replace the tank with a larger tank or refill your tank. This can happen if the tank your using is too low or too small (use 100 lb tank or greater). If there is no frost line it may be an issue with the thermocouple. The manufacturer offers a service manual and owner's manuals on there site. This should assist you... www.desatech.com Thank you
Posted on Jan 28, 2010
hardrocko
  • 1476 Answers
SOURCE: L.P. Propane Heater not staying lit
Sounds like you have a bad gas hold on valve. I have a tip at http://www.fixya.com/support/r4258201-fix_gas_reddy_heaters_will_not_continue which explains the problem, how to fix it and where to get the parts. Let me know if you need more help.
Thanks for using FixYa and for the generous rating.
hardrocko
Posted on Jul 30, 2010
heatman101
  • 43501 Answers
SOURCE: WHERE CAN WE GET OUR HEATER REPAIRED. IT STOPS
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
Posted on Feb 20, 2011
heatman101
  • 43501 Answers
SOURCE: i have a reddy heater
heatman101
  • 767 Answers
SOURCE: my reddy heater pro 100 wont stay lit when i let
Hello my name is Heath it will be my pleasure to assist you. First thing to do is go to the furnace and look in the small peep hole in the lower blower door and see if there is an led light that is flashing a certain number of blinks record the number and look for a diagnostic chart on the inside of the blower door or the upper side panel of the furnace if there is no flash code present you can try resetting the power to the furnace and see if the furnace will fire up.
Posted on Sep 09, 2011
Yellow flame how to adjust it
You need to adjust the air shutter control on the open end of the burner.
For more information on your Reddy Heater and how to service it go to www.desatech.com Look for the Owners Manuals section and enter the Model Number of your heater. You can then download and print the entire Owners Manual.
Hope this helps you. Please let me know.
Feb 15, 2011 | Reddy Heater-30,000 BTU Propane Forced-Air...
30000 btu reddy heater is throwing flame way out of the heater
The gas pressure is way to high... you need to adjust the regulator to a low pressure or replace the regulator...
Propane, LP, or Natural Gas Regulator Problems
heatman101
Dec 10, 2010 | Reddy Heater-30,000 BTU Propane Forced-Air...
L.P. Propane Heater not staying lit Fairly new heater (Reddy) 30,000 BTU Piezo Igniter not functioning use long match and unit fires nice. plug in /turn on blower good once I let go of primer valve button...
hardrocko
Jul 30, 2010 | Reddy HEATER RLP30 30,000-BTU PORTABLE LP...
Jan 28, 2010 | Reddy HEATER RLP100 100,000-BTU PORTABLE...
Reddy heater rlp 100
Sounds like the thermocouple is not working or the flame is not hitting the thermocouple. It may take 30 seconds of flame or longer to keep it on. Check for a loose connection at the gas valve.
Either a 30# or 110# tank of propane will work. You might even get by for a short period of time using a gas grill tank, depending upon how cold it is outside.
Oct 26, 2007 | Reddy Heater-30,000 BTU Propane Forced-Air...
Reddy Heater-30,000 BTU Propane Forced-Air Heater Logo
53 people viewed this question
Top Reddy Heating & Cooling Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mack Baxter
T bone 1963
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
